Multiple Session Configuration Question
Posted: Mon Feb 29, 2016 6:41 am
by onyxintellect
My config.wtc in a RPI2 is as below. It start ups just fine but upon actually clicking one of the connections it says there is no server IP address specified.
bpp=32
display=1920x1080, 60 Hz
timezone=UTC
clienthostname=TERM1
turnoffmenu=on
infobox=lshift
connection PC1
connection PC2
I created 2 files, PC1.wtc and PC2.wtc. I placed them both in the config directory. Each of these files has a server and user line like detailed below but with different IP addresses for each system.
server=10.0.0.20
user=test:\x70\x61\x73\x73\x77\x6f\x72\x64
I've also tried creating a Connections directory and placing the PC1.wtc & PC2.wtc files in it to no avail. If I specify a server connection in the config.wtc file it connects to that server without issue but I'm wanting to be able to select from different computers. Am I doing something wrong in trying to configure multiple RDP sessions that I'm able to select which one is connected?
Thanks for any help you can provide.
Re: Multiple Session Configuration Question
Posted: Mon Feb 29, 2016 9:10 pm
WTware uses connection names when downloads config files from TFTP. With local disk configs, WTware skips "config compilation" and reads single config file as is. Please, try this:
timezone=UTC
turnoffmenu=on
infobox=lshift
connection
displayName=It's a first connection.
server=10.0.0.20
connection
displayName=It's a second connection.
server=10.0.0.21
PS: we should write manual about config structure...
PPS: RPI2 ignores bpp= and display=. Modes other than default 1920x1080x16bit should be configured in config.txt on SD, here is an instruction https://www.raspberrypi.org/documentati ... fig-txt.md
Posted: Sun Mar 06, 2016 5:18 pm
by onyxintellect
Thanks for the reply. That worked to get the menu based connections working.
I would like to do a few other things like use menu.gif, wait.gif, & popup.gif as well as define a custom background color. Are those options supported?
http://winterminal.com takes you to http://wtware.com/docs5/config.html but as you indicated previously not all the options apply to RPI2.
Thanks again for you help.
Posted: Sun Mar 13, 2016 2:56 pm
I tested it with wtware 5.4.20 and it works.
WTware treats gif images like text configs. If RPI2 loads configs from TFTP (network boot or local boot), it downloads gifs from TFTP server, folder C:\ProgramData\WTware\Graphic\sample.
If RPI2 boots from SD and stores config on SD, you should copy all C:\ProgramData\WTware\Graphic\sample folder into graphic folder on SD.
In both cases, add to config file:
skin=sample
