digital audio capture, aka remote recording
marcostelecom
Post by marcostelecom » Tue Jan 09, 2018 5:41 pm
I have successful raspberry Pi 3 network boot with linux isc-dhcpd + linux tftp server, using RDP on VM server (vmware).
I use wtware configuration software in windows 10, and sync the wtc config files to tftpboot dir.
I ran the update firmware in raspberry pi, using raspian
But I can't see microphone in wtware rdp - device record.
I already config registry in windows 7, as ref: https://docs.microsoft.com/en-us/vsts/f ... io-capture
The logs say that the audio device is detect OK.
The sound in phone and volume control works well.
I try other sound= and microphone= combinations, without success.
One question: is this correct?
[ gm] [ 11.011491] Add keyboard event1: C-Media Electronics Inc. USB PnP Sound Device.
Keyboard event ? Are there volume control reference?
Well.... help me, please !
My full logs:
WTware 5.6.22/RPi supervisor.
[        KERNEL] [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  hide_setup quiet
[        KERNEL] [    0.000222] console [tty0] enabled
[        KERNEL] [    0.000252] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000384] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000391] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001288] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001624] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.001632] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001656] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.003169] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.003175] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003726] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.003733] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004278] CPU3: update cpu_capacity 1024
[        KERNEL] [    0.004284] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004362] Brought up 4 CPUs
[        KERNEL] [    0.004371] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.004375] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004378] CPU: Virtualization extensions available.
[        KERNEL] [    0.004915] devtmpfs: initialized
[        KERNEL] [    0.014605] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[        KERNEL] [    0.014986] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.015001] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.015483] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.016015] NET: Registered protocol family 16
[        KERNEL] [    0.017856] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.028015] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.111144] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.113478] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.113599] usbcore: registered new interface driver hub
[        KERNEL] [    0.113686] usbcore: registered new device driver usb
[        KERNEL] [    0.120149] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-11-17 15:19
[        KERNEL] [    0.122437] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.137418] NET: Registered protocol family 2
[        KERNEL] [    0.137991] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.138099] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.138283] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.138367] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138408] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138582] NET: Registered protocol family 1
[        KERNEL] [    2.246586] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    2.282384] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    2.282398] io scheduler noop registered
[        KERNEL] [    2.282403] io scheduler deadline registered (default)
[        KERNEL] [    2.293307] BCM2708FB: allocated DMA memory fad10000
[        KERNEL] [    2.293349] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    2.352041] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    2.389698] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    2.389900] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.390780] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.396632] zram: Added device: zram0
[        KERNEL] [    2.396671] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.624417] Core Release: 2.80a
[        KERNEL] [    2.624427] Setting default values for core params
[        KERNEL] [    2.624455] Finished setting default values for core params
[        KERNEL] [    2.824822] Using Buffer DMA mode
[        KERNEL] [    2.824828] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.824831] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.824839] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.824866] Dedicated Tx FIFOs mode
[        KERNEL] [    2.825333] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[        KERNEL] [    2.825361] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.825361] Non-periodic Split Transactions
[        KERNEL] [    2.825361] Periodic Split Transactions
[        KERNEL] [    2.825361] High-Speed Isochronous Endpoints
[        KERNEL] [    2.825361] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.825367] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.825411] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397d28
[        KERNEL] [    2.825420] WARN::hcd_init_fiq:460: FIQ ASM at 0x8039808c length 36
[        KERNEL] [    2.825429] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    2.825485] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    2.825519] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.825548] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    2.825594] Init: Port Power? op_state=1
[        KERNEL] [    2.825598] Init: Power Port (0)
[        KERNEL] [    2.825784] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    2.825794] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.825802] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    2.825809] usb usb1: Manufacturer: Linux 4.9.65 dwc_otg_hcd
[        KERNEL] [    2.825816] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    2.826568] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.826606] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.827316] dwc_otg: FIQ enabled
[        KERNEL] [    2.827320] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.827325] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.827340] Module dwc_common_port init
[        KERNEL] [    2.827722] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.829081] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.829587] bcm2835-cpufreq: min=600000 max=1200000
[        KERNEL] [    2.830668] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    2.833133] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[        KERNEL] [    2.835648] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    2.835826] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.836593] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.836601] usbhid: USB HID core driver
[        KERNEL] [    2.837775] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    2.844890] [vc_sm_connected_init]: start
[        KERNEL] [    2.852742] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.852996] NET: Registered protocol family 17
[        KERNEL] [    2.853159] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.853744] registered taskstats version 1
[        KERNEL] [    2.857874] sdhost: log_buf @ bad07000 (fad07000)
[        KERNEL] [    2.932453] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    2.934573] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.934577] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[        KERNEL] [    2.992496] of_cfs_init
[        KERNEL] [    2.992554] of_cfs_init: OK
[        KERNEL] [    3.004816] Freeing unused kernel memory: 5120K
[        KERNEL] [    3.041855] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    3.042552] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    3.103532] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.105037] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.107724] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    3.112617] mmc0: host does not support reading read-only switch, assuming write-enable
[        KERNEL] [    3.116064] mmc0: new high speed SDHC card at address aaaa
[        KERNEL] [    3.116504] mmcblk0: mmc0:aaaa SB32G 29.7 GiB
[        KERNEL] [    3.119033]  mmcblk0: p1 p2
[       hotplug] [    3.118577] Block device 179:2. No action.
[       hotplug] [    3.118745] Block device 179:0. No action.
[        KERNEL] [    3.120961] random: fast init done
[       hotplug] [    3.118908] Block device 179:1. No action.
[        KERNEL] [    3.197306] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    3.262508] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    3.262607] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    3.299476] Block device 254:0. No action.
[          pfac] [    3.337701] Run /sbin/initrd.
[          pfac] [    3.337757] Ok, PID 609.
[        initrd] [    3.339436] WTware shell 5.6.22/RPi
[        KERNEL] [    3.492592] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.492604] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.493069] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.493142] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.812470] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.942711] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    3.942722] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    4.042476] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.176516] usb 1-1.2: New USB device found, idVendor=2188, idProduct=0ae1
[        KERNEL] [    4.176528] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[        KERNEL] [    4.176535] usb 1-1.2: Product: USB OPTICAL MOUSE
[        KERNEL] [    4.182056] input: USB OPTICAL MOUSE  as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:2188:0AE1.0001/input/input0
[        KERNEL] [    4.182684] hid-generic 0003:2188:0AE1.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.282469] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[        KERNEL] [    4.420259] usb 1-1.4: New USB device found, idVendor=8086, idProduct=0808
[        KERNEL] [    4.420270] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.420278] usb 1-1.4: Product: USB PnP Sound Device
[        KERNEL] [    4.420285] usb 1-1.4: Manufacturer: C-Media Electronics Inc.
[        KERNEL] [    4.425818] input: C-Media Electronics Inc.       USB PnP Sound Device as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.3/0003:8086:0808.0002/input/input1
[        KERNEL] [    4.493006] hid-generic 0003:8086:0808.0002: input,hidraw1: USB HID v1.00 Device [C-Media Electronics Inc.       USB PnP Sound Device] on usb-3f980000.usb-1.4/input3
[        KERNEL] [    4.792467] usb 1-1.5: new low-speed USB device number 6 using dwc_otg
[        KERNEL] [    4.938885] usb 1-1.5: New USB device found, idVendor=1a2c, idProduct=2d23
[        KERNEL] [    4.938896] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.938903] usb 1-1.5: Product: USB Keyboard
[        KERNEL] [    4.938910] usb 1-1.5: Manufacturer: USB
[        KERNEL] [    4.949041] input: USB USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:1A2C:2D23.0003/input/input2
[        KERNEL] [    5.013736] hid-generic 0003:1A2C:2D23.0003: input,hidraw2: USB HID v1.10 Keyboard [USB USB Keyboard] on usb-3f980000.usb-1.5/input0
[        KERNEL] [    5.023636] input: USB USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:1A2C:2D23.0004/input/input3
[        KERNEL] [    5.093073] hid-generic 0003:1A2C:2D23.0004: input,hidraw3: USB HID v1.10 Device [USB USB Keyboard] on usb-3f980000.usb-1.5/input1
[        initrd] [    5.370524] Load ethernet drivers.
[        initrd] [    5.375475] modprobe smsc95xx.
[        KERNEL] [    5.385566] smsc95xx v1.0.5
[        KERNEL] [    5.476902] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:2a:5f:a3
[        KERNEL] [    5.477306] usbcore: registered new interface driver smsc95xx
[        KERNEL] [    5.564335] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[        KERNEL] [    7.007692] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[        initrd] [    8.260183] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [    8.260303] 00000000:0000013400000000001100000A0B001E0A0B00DD004300440134000002010600  ...4...............C.D.4......
[        initrd] [    8.260377] 00000020:67458B6B00000000000000000A0B00DD0A0B001E00000000B827EB2A5FA30000  gE.k....................'.*_...
[        initrd] [    8.260446] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.260514] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.260582] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [    8.260650] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.260717] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.260785] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        KERNEL] [    9.680903] random: crng init done
[        initrd] [   10.520171] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [   10.520298] 00000000:0000013400000000001100000A0B001E0A0B00DD004300440134000002010600  ...4...............C.D.4......
[        initrd] [   10.520370] 00000020:67458B6B00000000000000000A0B00DD0A0B001E00000000B827EB2A5FA30000  gE.k....................'.*_...
[        initrd] [   10.520438] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.520506] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.520573] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [   10.520641] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.520707] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.520774] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.560093] dhcp: server address 10.11.0.30.
[        initrd] [   10.560167] dhcp: 10.11.0.221/255.255.255.0.
[        initrd] [   10.560238] dhcp: default gateway 10.11.0.30.
[        initrd] [   10.560304] dhcp: DNS 8.8.8.8.
[        initrd] [   10.560369] dhcp: domain teste.com.br.
[        initrd] [   10.560434] dhcp: TFTP from 066 10.11.0.30.
[        initrd] [   10.560499] dhcp: TFTP 10.11.0.30.
[        initrd] [   10.560563] Use default TFTP prefix for Raspberry network boot.
[        initrd] [   10.560629] TFTP binary "5.6.22/", configs prefix "", using "/" slash.
[        initrd] [   10.572868] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
[        initrd] [   10.574927] WTpassword present: 4fdd7b466ab915c50d6ab85f.
[        initrd] [   10.612815] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   10.613275] Run /sbin/httpd.
[          pfac] [   10.613378] Ok, PID 657.
[         httpd] [   10.618209] HTTP Server, WTware 5.6.22/RPi
[        initrd] [   10.727871] USB: 1a2c:2d23 China Resource Semico Co., Ltd.
[        initrd] [   10.728015] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [   10.728093] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [   10.728165] USB: 8086:0808 Intel Corp..
[        initrd] [   10.728234] USB: 2188:0ae1 .
[        initrd] [   10.728302] [TFTP] Download config file Everyone/source.wtc from 10.11.0.30.
[        initrd] [   10.731582] [TFTP] It is not WTware5 TFTP server.
[        initrd] [   10.735597] [TFTP] Download config file Everyone/list.wtc from 10.11.0.30.
[        initrd] [   10.738504] [TFTP] Download config file Terminals/B8.27.EB.2A.5F.A3/config.wtc from 10.11.0.30.
| user=testuser
| server=192.168.24.96
| sound=on, hw:1:0
| skin=Papel
[        initrd] [   10.741106] [TFTP] Download config file Everyone/all.wtc from 10.11.0.30.
| domain=domaintest.local
| keyboard=pt-br
| language=pt-br,default
| skin=sample
| sound=on, hw:1:0
| keyboard=pt-br
| skin=Papel
| sound=on, hw:1:0
| user=testuser
[        initrd] [   10.744558] Hostname: "wtwB827EBXXXXXX".
[            gm] [   11.009890] WTware session manager 5.6.22/RPi.
[            gm] [   11.011279] Add keyboard event3: USB USB Keyboard.
[            gm] [   11.011371] Add keyboard event2: USB USB Keyboard.
[         httpd] [   11.011448] Reread settings.
[         httpd] [   11.011627] Everyone can control terminal by HTTP.
[            gm] [   11.080116] EV_REL flag found. Add mouse event0: USB OPTICAL MOUSE .
[            gm] [   11.080344] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   11.115881] Framebuffer device found.
[            gm] [   11.115959] LINELENBYTES 7680
[            gm] [   11.116032] VLEN 8294400
[            gm] [   11.152511] Use /lib/ui32.so.
[            gm] [   11.153149] [TFTP] Download config file Graphic/Papel/menu.png from 10.11.0.30.
[            gm] [   11.166406] [TFTP] Download config file Graphic/Papel/popup.png from 10.11.0.30.
[            gm] [   11.172068] [TFTP] Download config file Graphic/Papel/saver.png from 10.11.0.30.
[            gm] [   11.176756] [TFTP] Download config file Graphic/Papel/wait.png from 10.11.0.30.
[            gm] [   11.303200] [TFTP] Download and unpack file 5.6.22/pi2/localboot/packages/pi2-alsa from 10.11.0.30.
[            gm] [   11.929192] modprobe snd-bcm2835.
[            gm] [   11.948068] modprobe snd-usb-audio.
|   0: [ 0]   : control
|  32: [ 1]   : control
|  33:        : timer
[        KERNEL] [   11.989617] usbcore: registered new interface driver snd-usb-audio
[            gm] [   11.989661] /dev/snd/pcmC1D0c character device.
[            gm] [   11.989808] /dev/snd/pcmC1D0p character device.
[            gm] [   11.989925] /dev/snd/controlC1 character device.
[            gm] [   11.990098] /dev/snd/pcmC0D1p character device.
[          pfac] [   11.990182] Run /sbin/rdpsnd sndvol 100 100 50.
[            gm] [   11.990228] /dev/snd/pcmC0D0p character device.
[            gm] [   11.990301] /dev/snd/controlC0 character device.
[          pfac] [   11.990376] Ok, PID 688.
[            gm] [   11.990423] /dev/snd/timer character device.
[          pfac] [   11.990658] Run /sbin/rdpsnd 1 0 100 1 0.
[            gm] [   11.990762] Preconfigure ALSA.
[          pfac] [   11.990893] Ok, PID 689.
[            gm] [   11.990944] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[            gm] [   11.991047] Run sound daemon.
[            gm] [   11.991154] Run '/sbin/rdpsnd 1 0 100 1 0', log '', env '', pid ''.
[        rdpsnd] [   11.997332] RDP Sound Redirector, WTware 5.6.22/RPi.
[        rdpsnd] [   12.003988] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.4, full spe'.
[        rdpsnd] [   12.004193] Mixer name: 'USB Mixer'.
[        sndvol] [   12.004279] Card 'ALSA'/'bcm2835 ALSA'.
[        sndvol] [   12.004360] Mixer name: 'Broadcom Mixer'.
[        sndvol] [   12.004473] Components: ''.
[        sndvol] [   12.004553] Controls: 6.
[        sndvol] [   12.004650] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   12.004748] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.004829] ALSA: control 'PCM Playback Route'.
[        sndvol] [   12.004907] ALSA: control 'IEC958 Playback Default'.
[        sndvol] [   12.005009] ALSA: control 'IEC958 Playback Con Mask'.
[        sndvol] [   12.005110] ALSA: control 'IEC958 Playback PCM Stream'.
[        sndvol] [   12.005226] Inactive control IEC958 Playback PCM Stream'.
[        sndvol] [   12.005307] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.4, full spe'.
[        sndvol] [   12.005386] Mixer name: 'USB Mixer'.
[        sndvol] [   12.005484] Components: 'USB8086:0808'.
[        sndvol] [   12.005582] Controls: 7.
[        sndvol] [   12.005668] ALSA: control 'Playback Channel Map'.
[        sndvol] [   12.005770] ALSA: control 'Capture Channel Map'.
[        sndvol] [   12.005867] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.005964] ALSA: control 'PCM Playback Volume'.
[        rdpsnd] [   12.006135] Components: 'USB8086:0808'.
[        rdpsnd] [   12.006300] Controls: 7.
[        rdpsnd] [   12.006532] ALSA: control 'Playback Channel Map'.
[        sndvol] [   12.006594] ALSA: control 'Mic Capture Switch'.
[        sndvol] [   12.007029] ALSA: control 'Mic Capture Volume'.
[        rdpsnd] [   12.007221] ALSA: control 'Capture Channel Map'.
[        sndvol] [   12.007403] ALSA: control 'Auto Gain Control'.
[        rdpsnd] [   12.007535] ALSA: control 'PCM Playback Switch'.
[        rdpsnd] [   12.007704] ALSA: control 'PCM Playback Volume'.
[        rdpsnd] [   12.008781] ALSA: control 'Mic Capture Switch'.
[        rdpsnd] [   12.008925] ALSA: control 'Mic Capture Volume'.
[          pfac] [   12.009064] Process pid 688 terminated, status 00000000.
[        rdpsnd] [   12.009111] ALSA: control 'Auto Gain Control'.
[            gm] [   12.056243] Run '/sbin/resolver 0xa37ca0 dns [192.168.24.96]', log '', env '', pid ''.
[          pfac] [   12.056408] Run /sbin/resolver 0xa37ca0 dns [192.168.24.96].
[            gm] [   12.056520] Nobody can control terminal by VNC.
[          pfac] [   12.056694] Ok, PID 690.
[          pfac] [   12.062680] Process pid 690 terminated, status 00000000.
[            gm] [   12.069260] 192.168.24.96 => 192.168.24.96.
[            gm] [   12.081255] Free ram before fork terminal client /sbin/rdpclient (session 1): 920648 Kb.
[          pfac] [   12.081420] Run /sbin/rdpclient 1.
[            gm] [   12.081466] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   12.081629] Ok, PID 691.
[ rdpclient 691] [   12.089422] RDP Terminal Client, WTware 5.6.22/RPi, pipe 1, pid 691.
[ rdpclient 691] [   12.091953] Use /lib/ui32.so.
[ rdpclient 691] [   12.092228] Redirect sound.
[ rdpclient 691] [   12.093720] Make RDP session with 192.168.24.96, port 3389.
[ rdpclient 691] [   12.093936]  Username: "testuser".
[ rdpclient 691] [   12.094024]  No password.
[ rdpclient 691] [   12.094109]  No PIN.
[ rdpclient 691] [   12.094190]  Domain: "domaintest.local".
[ rdpclient 691] [   12.094272]  No shell.
[ rdpclient 691] [   12.094353]  No directory.
[ rdpclient 691] [   12.094518]  Window: 1920x1080@24.
[ rdpclient 691] [   12.094640]  PFlags 0x0000002F.
[ rdpclient 691] [   12.094753]  Keyboard 00000416:00000000.
[ rdpclient 691] [   12.094839]  My hostname "wtwB827EBXXXXXX".
[ rdpclient 691] [   12.094919] TCP: connecting to 192.168.24.96:3389.
[ rdpclient 691] [   12.139400] TCP: connection with 192.168.24.96:3389 established.
[ rdpclient 691] [   12.139586] Turn keepalive on.
[ rdpclient 691] [   12.139670] Free ram after buffers allocation: 919840 KB.
[ rdpclient 691] [   12.246202] Process RDP server certificate.
[ rdpclient 691] [   12.246302] RDP4 encryption.
[ rdpclient 691] [   12.613582] Enable font smoothing.
[ rdpclient 691] [   13.493917] 32-bit color.
[ rdpclient 691] [   29.066959] errorInfo 0x00000000.
[ rdpclient 691] [   30.028849] SessionId 0x00000038: DOMAINTEST\testuser.
Re: digital audio capture, aka remote recording
Post by akatik » Tue Jan 09, 2018 7:03 pm
There is no "microphone=on" in this log. Show me log with "microphone=on" after you try to capture sound.
marcostelecom
Post by marcostelecom » Tue Jan 09, 2018 11:00 pm
The log with "microphone=on" :
play audio in phone, OK; play volume control: OK
I search all "DisableAudioCapture" keys in register, and set to 0 (zero);
see no record devices in windows.
[        KERNEL] [    0.000209] Console: colour dummy device 80x30
[        KERNEL] [    0.000223] console [tty0] enabled
[        KERNEL] [    0.000239] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[        KERNEL] [    0.000253] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000392] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001233] Disabling memory control group subsystem
[        KERNEL] [    0.001287] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001622] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.001630] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001655] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.003164] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.003171] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003720] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.003727] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004272] CPU3: update cpu_capacity 1024
[        KERNEL] [    0.004279] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004357] Brought up 4 CPUs
[        KERNEL] [    0.004367] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.004371] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004374] CPU: Virtualization extensions available.
[        KERNEL] [    0.004911] devtmpfs: initialized
[        KERNEL] [    0.015484] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.016011] NET: Registered protocol family 16
[        KERNEL] [    0.017852] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.027999] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.111155] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.113489] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.113611] usbcore: registered new interface driver hub
[        KERNEL] [    0.113697] usbcore: registered new device driver usb
[        KERNEL] [    0.120155] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-11-17 15:19
[        KERNEL] [    0.122457] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.137350] NET: Registered protocol family 2
[        KERNEL] [    0.137920] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.138028] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.138212] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.138297] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138338] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138512] NET: Registered protocol family 1
[        KERNEL] [    2.243585] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    2.279128] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    2.279141] io scheduler noop registered
[        KERNEL] [    2.279146] io scheduler deadline registered (default)
[        KERNEL] [    2.286802] BCM2708FB: allocated DMA memory fad10000
[        KERNEL] [    2.286839] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    2.345957] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    2.383435] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    2.383641] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.384506] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.390542] zram: Added device: zram0
[        KERNEL] [    2.390606] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.618373] Core Release: 2.80a
[        KERNEL] [    2.618383] Setting default values for core params
[        KERNEL] [    2.618412] Finished setting default values for core params
[        KERNEL] [    2.818780] Using Buffer DMA mode
[        KERNEL] [    2.818785] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.818788] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.818796] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.818825] Dedicated Tx FIFOs mode
[        KERNEL] [    2.819431] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[        KERNEL] [    2.819456] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.819456] Non-periodic Split Transactions
[        KERNEL] [    2.819456] Periodic Split Transactions
[        KERNEL] [    2.819456] High-Speed Isochronous Endpoints
[        KERNEL] [    2.819456] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.819462] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.819508] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397d28
[        KERNEL] [    2.819518] WARN::hcd_init_fiq:460: FIQ ASM at 0x8039808c length 36
[        KERNEL] [    2.819528] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    2.819584] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    2.819619] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.819648] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    2.819695] Init: Port Power? op_state=1
[        KERNEL] [    2.819699] Init: Power Port (0)
[        KERNEL] [    2.819878] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    2.819888] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.819896] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    2.819903] usb usb1: Manufacturer: Linux 4.9.65 dwc_otg_hcd
[        KERNEL] [    2.819910] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    2.820654] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.820696] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.821388] dwc_otg: FIQ enabled
[        KERNEL] [    2.821393] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.821396] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.821409] Module dwc_common_port init
[        KERNEL] [    2.821807] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.823352] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.823816] bcm2835-cpufreq: min=600000 max=1200000
[        KERNEL] [    2.824898] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    2.827314] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[        KERNEL] [    2.829806] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    2.829965] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.830759] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.830769] usbhid: USB HID core driver
[        KERNEL] [    2.831952] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    2.839796] [vc_sm_connected_init]: start
[        KERNEL] [    2.847633] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.847925] NET: Registered protocol family 17
[        KERNEL] [    2.848070] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.848588] registered taskstats version 1
[        KERNEL] [    2.853162] sdhost: log_buf @ bad07000 (fad07000)
[        KERNEL] [    2.932482] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    2.934587] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.934591] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[        KERNEL] [    3.012535] of_cfs_init
[        KERNEL] [    3.012593] of_cfs_init: OK
[        KERNEL] [    3.026816] Freeing unused kernel memory: 5120K
[        KERNEL] [    3.033833] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    3.046363] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    3.047860] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.049353] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.052044] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    3.062740] mmc0: host does not support reading read-only switch, assuming write-enable
[        KERNEL] [    3.065721] mmc0: new high speed SDHC card at address aaaa
[        KERNEL] [    3.066128] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[        KERNEL] [    3.096483] random: fast init done
[        KERNEL] [    3.097549]  mmcblk0: p1 p2
[       hotplug] [    3.097101] Block device 179:0. No action.
[       hotplug] [    3.097189] Block device 179:2. No action.
[       hotplug] [    3.097335] Block device 179:1. No action.
[        KERNEL] [    3.142295] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    3.252500] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    3.252646] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    3.291144] Block device 254:0. No action.
[          pfac] [    3.358099] Run /sbin/initrd.
[          pfac] [    3.358640] Ok, PID 609.
[        initrd] [    3.362061] WTware shell 5.6.22/RPi
[        KERNEL] [    3.492751] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.492763] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.493523] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.494000] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.812486] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.942712] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    4.042487] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.176520] usb 1-1.2: New USB device found, idVendor=2188, idProduct=0ae1
[        KERNEL] [    4.176530] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[        KERNEL] [    4.176538] usb 1-1.2: Product: USB OPTICAL MOUSE
[        KERNEL] [    4.183794] input: USB OPTICAL MOUSE  as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:2188:0AE1.0001/input/input0
[        KERNEL] [    4.184342] hid-generic 0003:2188:0AE1.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.282495] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[        KERNEL] [    4.420268] usb 1-1.3: New USB device found, idVendor=8086, idProduct=0808
[        KERNEL] [    4.420279] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.420287] usb 1-1.3: Product: USB PnP Sound Device
[        KERNEL] [    4.420294] usb 1-1.3: Manufacturer: C-Media Electronics Inc.
[        KERNEL] [    4.425765] input: C-Media Electronics Inc.       USB PnP Sound Device as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.3/0003:8086:0808.0002/input/input1
[        KERNEL] [    4.493001] hid-generic 0003:8086:0808.0002: input,hidraw1: USB HID v1.00 Device [C-Media Electronics Inc.       USB PnP Sound Device] on usb-3f980000.usb-1.3/input3
[        KERNEL] [    4.792492] usb 1-1.4: new low-speed USB device number 6 using dwc_otg
[        KERNEL] [    4.938014] usb 1-1.4: New USB device found, idVendor=1a2c, idProduct=2124
[        KERNEL] [    4.938025] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.938032] usb 1-1.4: Product: USB Keyboard
[        KERNEL] [    4.938041] usb 1-1.4: Manufacturer: SEM
[        KERNEL] [    4.949034] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:1A2C:2124.0003/input/input2
[        KERNEL] [    5.073612] hid-generic 0003:1A2C:2124.0003: input,hidraw2: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-3f980000.usb-1.4/input0
[        KERNEL] [    5.085692] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:1A2C:2124.0004/input/input3
[        KERNEL] [    5.153125] hid-generic 0003:1A2C:2124.0004: input,hidraw3: USB HID v1.10 Device [SEM USB Keyboard] on usb-3f980000.usb-1.4/input1
[        initrd] [    5.510509] Load ethernet drivers.
[        initrd] [    5.515500] modprobe smsc95xx.
[        KERNEL] [    5.525711] smsc95xx v1.0.5
[        KERNEL] [    5.616260] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:aa:fa:2b
[        KERNEL] [    5.616451] usbcore: registered new interface driver smsc95xx
[        KERNEL] [    5.704692] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[        KERNEL] [    7.163892] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[        initrd] [    8.410179] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [    8.410299] 00000000:0000013400000000001100000A0B001E0A0B00DE004300440134000002010600  ...4...............C.D.4......
[        initrd] [    8.410376] 00000020:67458B6B00000000000000000A0B00DE0A0B001E00000000B827XXXXXXXX0000  gE.k....................'...+..
[        initrd] [    8.410445] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.410516] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.410584] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [    8.410653] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.410721] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.410789] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        KERNEL] [    9.671035] random: crng init done
[        initrd] [   10.650170] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [   10.650293] 00000000:0000013400000000001100000A0B001E0A0B00DE004300440134000002010600  ...4...............C.D.4......
[        initrd] [   10.650364] 00000020:67458B6B00000000000000000A0B00DE0A0B001E00000000B827XXXXXXXX0000  gE.k....................'...+..
[        initrd] [   10.650433] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.650500] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.650568] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [   10.650635] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.650703] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.650770] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.700089] dhcp: server address 10.11.0.30.
[        initrd] [   10.700164] dhcp: 10.11.0.222/255.255.255.0.
[        initrd] [   10.700234] dhcp: default gateway 10.11.0.30.
[        initrd] [   10.700301] dhcp: DNS 8.8.8.8.
[        initrd] [   10.700367] dhcp: domain test.com.br.
[        initrd] [   10.700433] dhcp: TFTP from 066 10.11.0.30.
[        initrd] [   10.700499] dhcp: TFTP 10.11.0.30.
[        initrd] [   10.700566] Use default TFTP prefix for Raspberry network boot.
[        initrd] [   10.700633] TFTP binary "5.6.22/", configs prefix "", using "/" slash.
[        initrd] [   10.712359] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
[        initrd] [   10.714249] WTpassword present: 4fdd7b466ab915c50d6ab85f84efab8e.
[        initrd] [   10.752151] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   10.752287] Run /sbin/httpd.
[          pfac] [   10.752564] Ok, PID 658.
[         httpd] [   10.757625] HTTP Server, WTware 5.6.22/RPi
[        initrd] [   10.867307] USB: 8086:0808 Intel Corp..
[        initrd] [   10.867461] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [   10.867540] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [   10.867616] USB: 1a2c:2124 China Resource Semico Co., Ltd.
[        initrd] [   10.867687] USB: 2188:0ae1 .
[        initrd] [   10.867757] [TFTP] Download config file Everyone/source.wtc from 10.11.0.30.
[        initrd] [   10.870395] [TFTP] It is not WTware5 TFTP server.
[        initrd] [   10.873867] [TFTP] Download config file Everyone/list.wtc from 10.11.0.30.
[        initrd] [   10.876540] [TFTP] Download config file Terminals/B8.27.EB.AA.FA.2B/config.wtc from 10.11.0.30.
| user=usertest
| sound=on, hw:1:0
| skin=Papel
| microphone=on
[        initrd] [   10.878569] [TFTP] Download config file Everyone/all.wtc from 10.11.0.30.
| keyboard=pt-br
| skin=sample
| sound=on, hw:1:0
| keyboard=pt-br
| skin=Papel
| sound=on, hw:1:0
| user=usertest
| microphone=on
[        initrd] [   10.881922] Hostname: "wtwB827XXXXXXXX".
[         httpd] [   11.155242] Reread settings.
[         httpd] [   11.155545] Everyone can control terminal by HTTP.
[            gm] [   11.159907] WTware session manager 5.6.22/RPi.
[            gm] [   11.161344] Add keyboard event3: SEM USB Keyboard.
[            gm] [   11.161436] Add keyboard event2: SEM USB Keyboard.
[            gm] [   11.161514] Add keyboard event1: C-Media Electronics Inc.       USB PnP Sound Device.
[            gm] [   11.230103] EV_REL flag found. Add mouse event0: USB OPTICAL MOUSE .
[            gm] [   11.230301] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   11.265782] Framebuffer device found.
[            gm] [   11.265863] LINELENBYTES 7680
[            gm] [   11.265936] VLEN 8294400
[            gm] [   11.302357] Use /lib/ui32.so.
[            gm] [   11.302990] [TFTP] Download config file Graphic/Papel/menu.png from 10.11.0.30.
[            gm] [   11.317306] [TFTP] Download config file Graphic/Papel/popup.png from 10.11.0.30.
[            gm] [   11.322970] [TFTP] Download config file Graphic/Papel/saver.png from 10.11.0.30.
[            gm] [   11.327582] [TFTP] Download config file Graphic/Papel/wait.png from 10.11.0.30.
[            gm] [   11.459963] [TFTP] Download and unpack file 5.6.22/pi2/localboot/packages/pi2-alsa from 10.11.0.30.
[            gm] [   12.082994] modprobe snd-bcm2835.
[            gm] [   12.103544] modprobe snd-usb-audio.
[        KERNEL] [   12.143559] usbcore: registered new interface driver snd-usb-audio
|   0: [ 0]   : control
|  32: [ 1]   : control
|  33:        : timer
[            gm] [   12.143898] /dev/snd/pcmC1D0c character device.
[            gm] [   12.143992] /dev/snd/pcmC1D0p character device.
[            gm] [   12.144089] /dev/snd/controlC1 character device.
[            gm] [   12.144174] /dev/snd/pcmC0D1p character device.
[            gm] [   12.144275] /dev/snd/pcmC0D0p character device.
[            gm] [   12.144359] /dev/snd/controlC0 character device.
[            gm] [   12.144435] /dev/snd/timer character device.
[            gm] [   12.144512] Preconfigure ALSA.
[            gm] [   12.144596] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[          pfac] [   12.144673] Run /sbin/rdpsnd sndvol 100 100 50.
[            gm] [   12.144718] Run sound daemon.
[            gm] [   12.144792] Run '/sbin/rdpsnd 1 0 100 1 0', log '', env '', pid ''.
[            gm] [   12.144876] Run microphone daemon.
[          pfac] [   12.144996] Ok, PID 689.
[            gm] [   12.145068] Run '/sbin/rdpaudin 0 100 1 0', log '', env '', pid ''.
[          pfac] [   12.145171] Run /sbin/rdpsnd 1 0 100 1 0.
[          pfac] [   12.145254] Ok, PID 690.
[          pfac] [   12.145354] Run /sbin/rdpaudin 0 100 1 0.
[          pfac] [   12.145432] Ok, PID 691.
[        sndvol] [   12.160391] Card 'ALSA'/'bcm2835 ALSA'.
[        sndvol] [   12.160549] Mixer name: 'Broadcom Mixer'.
[        rdpsnd] [   12.160594] RDP Sound Redirector, WTware 5.6.22/RPi.
[        sndvol] [   12.160676] Components: ''.
[        sndvol] [   12.160756] Controls: 6.
[        sndvol] [   12.160836] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   12.160915] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.160997] ALSA: control 'PCM Playback Route'.
[        sndvol] [   12.161077] ALSA: control 'IEC958 Playback Default'.
[        sndvol] [   12.161156] ALSA: control 'IEC958 Playback Con Mask'.
[        sndvol] [   12.161237] ALSA: control 'IEC958 Playback PCM Stream'.
[        sndvol] [   12.161316] Inactive control IEC958 Playback PCM Stream'.
[        sndvol] [   12.161397] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.3, full spe'.
[        sndvol] [   12.161480] Mixer name: 'USB Mixer'.
[        sndvol] [   12.161557] Components: 'USB8086:0808'.
[        sndvol] [   12.161637] Controls: 7.
[        sndvol] [   12.161714] ALSA: control 'Playback Channel Map'.
[        sndvol] [   12.161792] ALSA: control 'Capture Channel Map'.
[        sndvol] [   12.161871] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.161950] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   12.162030] ALSA: control 'Mic Capture Switch'.
[        sndvol] [   12.162127] ALSA: control 'Mic Capture Volume'.
[        sndvol] [   12.162206] ALSA: control 'Auto Gain Control'.
[      rdpaudin] [   12.162489] RDP Microphone Redirector, WTware 5.6.22/RPi.
[          pfac] [   12.169603] Process pid 689 terminated, status 00000000.
[      rdpaudin] [   12.169693] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.3, full spe'.
[        rdpsnd] [   12.169741] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.3, full spe'.
[      rdpaudin] [   12.169838] Mixer name: 'USB Mixer'.
[        rdpsnd] [   12.169882] Mixer name: 'USB Mixer'.
[      rdpaudin] [   12.169962] Components: 'USB8086:0808'.
[        rdpsnd] [   12.170047] Components: 'USB8086:0808'.
[      rdpaudin] [   12.170140] Controls: 7.
[        rdpsnd] [   12.170183] Controls: 7.
[      rdpaudin] [   12.170271] ALSA: control 'Playback Channel Map'.
[        rdpsnd] [   12.170315] ALSA: control 'Playback Channel Map'.
[      rdpaudin] [   12.170395] ALSA: control 'Capture Channel Map'.
[        rdpsnd] [   12.170438] ALSA: control 'Capture Channel Map'.
[      rdpaudin] [   12.170515] ALSA: control 'PCM Playback Switch'.
[        rdpsnd] [   12.170559] ALSA: control 'PCM Playback Switch'.
[      rdpaudin] [   12.170635] ALSA: control 'PCM Playback Volume'.
[        rdpsnd] [   12.170677] ALSA: control 'PCM Playback Volume'.
[      rdpaudin] [   12.170754] ALSA: control 'Mic Capture Switch'.
[        rdpsnd] [   12.170798] ALSA: control 'Mic Capture Switch'.
[      rdpaudin] [   12.170884] ALSA: control 'Mic Capture Volume'.
[        rdpsnd] [   12.170945] ALSA: control 'Mic Capture Volume'.
[      rdpaudin] [   12.171023] ALSA: control 'Auto Gain Control'.
[        rdpsnd] [   12.171065] ALSA: control 'Auto Gain Control'.
[            gm] [   12.226440] Run '/sbin/resolver 0x16efce0 dns [192.168.24.96]', log '', env '', pid ''.
[          pfac] [   12.226605] Run /sbin/resolver 0x16efce0 dns [192.168.24.96].
[          pfac] [   12.226898] Ok, PID 692.
[            gm] [   12.227009] Nobody can control terminal by VNC.
[          pfac] [   12.232343] Process pid 692 terminated, status 00000000.
[            gm] [   12.238797] 192.168.24.96 => 192.168.24.96.
[            gm] [   12.250599] Free ram before fork terminal client /sbin/rdpclient (session 1): 920060 Kb.
[          pfac] [   12.250765] Run /sbin/rdpclient 1.
[            gm] [   12.250810] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   12.251019] Ok, PID 693.
[ rdpclient 693] [   12.258424] RDP Terminal Client, WTware 5.6.22/RPi, pipe 1, pid 693.
[ rdpclient 693] [   12.259867] Use /lib/ui32.so.
[ rdpclient 693] [   12.261280] Redirect sound.
[ rdpclient 693] [   12.261543] Make RDP session with 192.168.24.96, port 3389.
[ rdpclient 693] [   12.261643]  Username: "usertest".
[ rdpclient 693] [   12.261728]  No password.
[ rdpclient 693] [   12.261805]  No PIN.
[ rdpclient 693] [   12.261883]  Domain: "domaintest.local".
[ rdpclient 693] [   12.262044]  No shell.
[ rdpclient 693] [   12.262129]  No directory.
[ rdpclient 693] [   12.262207]  Window: 1920x1080@24.
[ rdpclient 693] [   12.262291]  PFlags 0x0000002F.
[ rdpclient 693] [   12.262370]  Keyboard 00000416:00000000.
[ rdpclient 693] [   12.262453]  My hostname "wtwB827XXXXXXXX".
[ rdpclient 693] [   12.262537] TCP: connecting to 192.168.24.96:3389.
[ rdpclient 693] [   12.312214] TCP: connection with 192.168.24.96:3389 established.
[ rdpclient 693] [   12.312359] Turn keepalive on.
[ rdpclient 693] [   12.313157] Free ram after buffers allocation: 919672 KB.
[ rdpclient 693] [   12.489928] Process RDP server certificate.
[ rdpclient 693] [   12.490125] RDP4 encryption.
[ rdpclient 693] [   12.959870] Enable font smoothing.
[ rdpclient 693] [   13.996242] 32-bit color.
[ rdpclient 693] [   45.106272] errorInfo 0x00000000.
[ rdpclient 693] [   45.251234] SessionId 0x00000042: DOMAINTEST\usertest.
Post by akatik » Wed Jan 10, 2018 1:37 pm
The logs say that the audio device is detected OK.
Have you got microphone redirection connecting with mstsc.exe from another windows machine to the same server 192.168.24.96?
marcostelecom
Post by marcostelecom » Wed Jan 10, 2018 9:06 pm
HUmmm... Don't work...
How can I access the log /tmp/rdpclient.out
ssh access ?
I see that
rsh ... reboot
works;
But not
rsh ... cat /tmp/rdpclient.out
Any idea to log search in windows ?
Post by akatik » Thu Jan 11, 2018 10:40 am
All log messages are in log. /tmp/rdpcient.out is just a pipe.
Sound problem is on server side. On server Windows. If microphone won't be redirected with mstsc.exe from one windows to windows server, it will not be redirected in wtware too.
