Please suggest me a valid smartcard reader.
onit
Post by onit » Thu Jul 27, 2017 12:42 pm
I can'y figure out using a Smartcard reader..
I tried to many kind of hardware but no one is redirected..
can you suggest me some model that is certly tested and functional?
meybe on amazon..
Re: Please suggest me a valid smartcard reader.
Post by akatik » Thu Jul 27, 2017 3:14 pm
In this manual there's the list of supported smartcards:
http://wtware.com/docs5/config.html#smartcard
If any smartcard from this list doesn't work. specify in configuration file:
smartcard=<cardname>,debug
Then save and send us terminal log file:
http://wtware.com/logs.html
onit
Post by onit » Wed Aug 09, 2017 6:51 pm
So, I think there is definitely a problem with software or drivers..
I bought this smartcard reader:
http://amzn.eu/3dmgOpO
But the result is the same. The certificate card for digital signatures is not read.
Attached here are the logs,
please help
WTware_log smartcard_readeer.txt
(117.83 KiB) Downloaded 22 times
Post by akatik » Thu Aug 10, 2017 8:10 am
onit wrote:..there is definitely a problem with software or drivers..
Yes :(
onit wrote:I bought this smartcard reader:
http://wtware.com/docs5/smartcard.html
Read from "If yes, let's start:" and send me new log.
onit
Post by onit » Thu Aug 10, 2017 11:07 am
I will collect logs again in my next post..
But I already wrote you another mail with other log in 25 May... It was a not supported reader.
and no answer..
Now It's a supported hardware (omnikey 3021), so Where is the problem? The card?
onit
Post by onit » Thu Aug 10, 2017 5:30 pm
here we are with the logs (you also have an eMail..)
waiting for a feedback
thanks
LogsReaderOmnikey3021.zip
(22.35 KiB) Downloaded 18 times
Post by akatik » Fri Aug 11, 2017 7:42 am
It is not 3021. Don't believe letters on box. Device itself says it is "OMNIKEY 3x21 Smart Card Reader":
usb 1-1.2: new full-speed USB device number 4 using dwc_otg
usb 1-1.2: New USB device found, idVendor=076b, idProduct=3031
usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.2: Product: OMNIKEY 3x21 Smart Card Reader
usb 1-1.2: Manufacturer: HID Global
And libccid (linux smart card driver) says "idVendor: 0x076B idProduct: 0x3031" is "OMNIKEY 3x21 Smart Card Reader".
onit
Post by onit » Fri Aug 11, 2017 11:14 am
Thanks akatik for your reply,
So, Now It's a real problem for me..
in the past 25 may I send you log saying:
gm] [   11.438312] Run scard daemon. Supported cards:
[            gm] [   11.438436] EZCCID, EZ100PU.
[            gm] [   11.447204] Run '/sbin/rdpdr[scard] 0', log '/tmp/rdpdr[scard].out', env '', pid ''.
and ezzccid - EZCCID, EZ100PU is in your copatibility list...
Now I bought a Omnikey 3021 (It's write in the device and in the Box..) but it's not comptible... (cause wtware say 3x21 is different..
So.. we come back to my first question...
and where to buy them?
Thanks in advance.
Post by aka » Fri Aug 11, 2017 3:23 pm
Please, try this build with http://amzn.eu/3dmgOpO device:
http://pxe.ru/files/testing/201708111620.zip
In config:
smartcard=omni3x21,debug
Post by akatik » Fri Aug 11, 2017 3:48 pm
onit wrote:..in the past 25 may I send you log saying:
Send it once more, please. With recent wtware version.
onit
Post by onit » Mon Aug 14, 2017 2:12 pm
aka wrote:Please, try this build with http://amzn.eu/3dmgOpO device:
In config:
IT WORKS !!!
Question: WTWARE CONFIGURATOR write
smartcard=omni3021,debug
but you tell me to write omni3x21 (and ti works)
It's correct to edit and write 3x21 or it's the same ?
onit
Post by onit » Mon Aug 14, 2017 2:18 pm
Here we are.
Log attached here and sent via mail
LogsReaderEZ100PU.zip
(14.19 KiB) Downloaded 15 times
