Pi4 running 16bit colour not 32bit
Posted: Sat Nov 02, 2019 11:42 am
by aceycv8
i'm trialing the software for a cctv solution and i'm noticing i can't run my PI4 in 32 bit colour and the colour seems to be washed out in a terminal service.
attached are the configs
can anyway assist on why i can't get full colour from my PI
[ httpd] [ 12.259132] Internal HTTP Server, WTware 5.8.72/RPi
[ httpd] [ 12.268429] Reread settings.
[ initrd] [ 12.268538] Unpack /bootmedia/packages/pi2-f.
[ httpd] [ 12.268642] Everyone can control terminal by HTTP.
[ KERNEL] [ 12.393099] random: crng init done
[ gm] [ 12.394211] WTware 5.8.72/RPi session manager.
[ gm] [ 12.460157] EV_REL flag found. Add mouse event1: USB Optical Mouse.
[ gm] [ 12.460269] Add keyboard event0: Dell Dell USB Entry Keyboard.
[ gm] [ 12.460360] Display mode: 1680x1050, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 12.757149] Framebuffer device found.
[ gm] [ 12.757193] LINELENBYTES 3360
[ gm] [ 12.757229] VLEN 3528000
[ gm] [ 12.758294] Use /lib/ui16.so.
[ gm] [ 12.770819] Copy /bootmedia/configs/vhusbdarm to /vh/vhusbdarm.
/--- FILE "/vh/config.ini" -----------------------
| ServerName=wtwDCA6322F3FD9
| Hostname=wtwDCA6322F3FD9
| UseAVAHI=0
| AllowedDevices=68e/ca
[ gm] [ 12.781568] Run '/vh/vhusbdarm -b -c /vh/config.ini -r /tmp/vh.out', log '', env '', pid ''.
[ pfac] [ 12.781784] Run /vh/vhusbdarm -b -c /vh/config.ini -r /tmp/vh.out.
[ pfac] [ 12.781830] Ok, PID 809.
[ VirtualHere] [ 12.847106] Wed Oct 23 00:00:10 2019 LOG_INFO >>> Starting VirtualHere USB Server v4.0.5 (Built: Oct 18 2019, 17:41:59)<<<
[ VirtualHere] [ 12.847146] Wed Oct 23 00:00:10 2019 LOG_INFO Using configuration /vh/config.ini
[ pfac] [ 12.847566] Process pid 809 terminated, status 00000000.
[ gm] [ 12.854739] Run '/sbin/resolver 0x702f20 dns [10.30.81.110]', log '', env '', pid ''.
[ pfac] [ 12.854851] Run /sbin/resolver 0x702f20 dns [10.30.81.110].
[ gm] [ 12.854885] Nobody can control terminal by VNC.
[ pfac] [ 12.854930] Ok, PID 811.
[ gm] [ 12.857012] 10.30.81.110 => 10.30.81.110.
[ pfac] [ 12.857181] Process pid 811 terminated, status 00000000.
[ gm] [ 12.859937] Free ram before fork terminal client /sbin/rdpclient (session 1): 3760508 Kb.
[ pfac] [ 12.860156] Run /sbin/rdpclient 1.
[ gm] [ 12.860182] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 12.860229] Ok, PID 812.
[ rdpclient 812] [ 12.865082] RDP Terminal Client, WTware 5.8.72/RPi, pipe 1, pid 812.
[ rdpclient 812] [ 12.865471] Use /lib/ui16.so.
[ rdpclient 812] [ 12.866536] Make RDP session with 10.30.81.110, port 3389.
[ rdpclient 812] [ 12.866702] Username: "xxxx".
[ rdpclient 812] [ 12.866764] Password: present.
[ rdpclient 812] [ 12.866805] No PIN.
[ rdpclient 812] [ 12.866845] No domain.
[ rdpclient 812] [ 12.866884] No shell.
[ rdpclient 812] [ 12.866924] No directory.
[ rdpclient 812] [ 12.866962] Window: 1616x1050@16.
[ rdpclient 812] [ 12.867003] PFlags 0x0000002F.
[ rdpclient 812] [ 12.867044] Keyboard 00000409:00000000.
[ rdpclient 812] [ 12.867084] My hostname "wtwDCA6322F3FD9".
[ rdpclient 812] [ 12.867123] TCP: connecting to 10.30.81.110:3389.
[ rdpclient 812] [ 12.868402] TCP: connection with 10.30.81.110:3389 established.
[ rdpclient 812] [ 12.868448] Turn keepalive on.
[ rdpclient 812] [ 12.868923] Free ram after buffers allocation: 3759812 KB.
[ rdpclient 812] [ 12.882597] Reconnect with NLA enabled.
[ rdpclient 812] [ 12.882641] TCP: reconnecting to 10.30.81.110:3389.
[ rdpclient 812] [ 12.883868] TCP: connection with 10.30.81.110:3389 established.
[ rdpclient 812] [ 12.883907] Turn keepalive on.
[ rdpclient 812] [ 12.895213] Server supports GFX Pipeline.
[ rdpclient 812] [ 12.895264] NLA.
[ rdpclient 812] [ 12.895311] SSL/TLS.
[ VirtualHere] [ 12.912656] Wed Oct 23 00:00:10 2019 LOG_INFO Server licensed to=unlicensed max_devices=1
[ VirtualHere] [ 12.912798] Wed Oct 23 00:00:10 2019 LOG_INFO Using large URB's
[ VirtualHere] [ 12.913908] Wed Oct 23 00:00:10 2019 LOG_INFO Listening on all network interfaces at TCP port 7575
[ rdpclient 812] [ 13.036839] Enable font smoothing and Desktop Composition.
[ rdpclient 812] [ 13.253340] GFX codec.
[ rdpclient 812] [ 14.280189] Run 4 tile threads.
[ rdpclient 812] [ 14.318548] errorInfo 0x00000000.
[ rdpclient 812] [ 14.667852] SessionId 0x00000002: xxxx.
WTware config:
connection
displayname=JUNWS003
server=10.30.81.110
user=
onerror = quiet
vhusb = on
vhusb = UseAVAHI
vhusb = 068e:00ca
redraw_delay=100
scale_factor = 100
bpp = 32
Pi config.txt
core_freq_min=500
disable_overscan=1
disable_splash=1
gpu_mem_1024=256
max_framebuffers=2
[pi4]
max_framebuffers=2
[all]
i have tried to set my hdmi modes as the following but it still does 16bit
hdmi_group=2
hdmi_mode=58
framebuffer_ignore_alpha=1
framebuffer_depth=32
Re: Pi4 running 16bit colour not 32bit
Posted: Sat Nov 02, 2019 11:36 pm
Show me full log, please.
https://wtware.com/logs.html
Posted: Sun Nov 03, 2019 12:36 am
by aceycv8
Hi -
here is the full log
WTware 5.8.72/RPi supervisor.
[ KERNEL] [ 0.000000] Linux version 4.19.80-v7l (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #9 SMP Wed Oct 23 11:42:47 EDT 2019
[ KERNEL] [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ KERNEL] [ 0.000000] cma: Reserved 64 MiB at 0x0000000037400000
[ KERNEL] [ 0.000000] On node 0 totalpages: 1012736
[ KERNEL] [ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ KERNEL] [ 0.000000] random: get_random_bytes called from 0xc0a009e0 with crng_init=0
[ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011200
[ KERNEL] [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm2708_fb.fbwidth=1680 bcm2708_fb.fbheight=1050 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:2F:3F:D9 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 quiet wtboot=mmc
[ KERNEL] [ 0.000000] Memory: 3937688K/4050944K available (6144K kernel code, 148K rwdata, 664K rodata, 6144K init, 372K bss, 47720K reserved, 65536K cma-reserved, 3198976K highmem)
[ KERNEL] [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ KERNEL] [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ KERNEL] [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ KERNEL] [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ KERNEL] [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (8160 kB)
[ KERNEL] [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (6144 kB)
[ KERNEL] [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 149 kB)
[ KERNEL] [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 373 kB)
[ KERNEL] [ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ KERNEL] [ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ KERNEL] [ 0.000016] Switching to timer-based delay loop, resolution 18ns
[ KERNEL] [ 0.000188] Console: colour dummy device 80x30
[ KERNEL] [ 0.000204] console [tty0] enabled
[ KERNEL] [ 0.000237] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ KERNEL] [ 0.000253] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.000375] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000886] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.001185] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ KERNEL] [ 0.001564] Setting up static identity map for 0x200000 - 0x20003c
[ KERNEL] [ 0.001658] rcu: Hierarchical SRCU implementation.
[ KERNEL] [ 0.002153] smp: Bringing up secondary CPUs ...
[ KERNEL] [ 0.002708] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ KERNEL] [ 0.003343] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ KERNEL] [ 0.003957] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ KERNEL] [ 0.004043] smp: Brought up 1 node, 4 CPUs
[ KERNEL] [ 0.004053] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ KERNEL] [ 0.004059] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.004065] CPU: Virtualization extensions available.
[ KERNEL] [ 0.004523] devtmpfs: initialized
[ KERNEL] [ 0.012732] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ KERNEL] [ 0.013024] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.013040] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 0.014547] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.015458] NET: Registered protocol family 16
[ KERNEL] [ 0.017321] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.021172] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.058204] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ KERNEL] [ 0.060322] vgaarb: loaded
[ KERNEL] [ 0.060786] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.060879] usbcore: registered new interface driver hub
[ KERNEL] [ 0.060964] usbcore: registered new device driver usb
[ KERNEL] [ 0.074055] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-10-21 16:47, variant start
[ KERNEL] [ 0.084023] raspberrypi-firmware soc:firmware: Firmware hash is 8c7c951122d2cae572e891f04ddf287078ff2f11
[ KERNEL] [ 0.095364] clocksource: Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.102793] NET: Registered protocol family 2
[ KERNEL] [ 0.103237] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ KERNEL] [ 0.103253] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.103306] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.103365] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.103462] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.103491] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.103623] NET: Registered protocol family 1
[ KERNEL] [ 0.103652] PCI: CLS 0 bytes, default 64
[ KERNEL] [ 1.816516] Initialise system trusted keyrings
[ KERNEL] [ 1.816692] workingset: timestamp_bits=30 max_order=20 bucket_order=0
[ KERNEL] [ 1.884132] Key type asymmetric registered
[ KERNEL] [ 1.884140] Asymmetric key parser 'x509' registered
[ KERNEL] [ 1.884203] bounce: pool size: 64 pages
[ KERNEL] [ 1.884260] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ KERNEL] [ 1.884269] io scheduler noop registered
[ KERNEL] [ 1.884406] io scheduler cfq registered (default)
[ KERNEL] [ 1.924913] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ KERNEL] [ 1.924932] brcm-pcie fd500000.pcie: could not get clock
[ KERNEL] [ 1.924977] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ KERNEL] [ 1.925005] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ KERNEL] [ 1.965385] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ KERNEL] [ 1.965651] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ KERNEL] [ 1.965666] pci_bus 0000:00: root bus resource [bus 00-01]
[ KERNEL] [ 1.965680] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ KERNEL] [ 1.965718] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ KERNEL] [ 1.965803] pci 0000:00:00.0: PME# supported from D0 D3hot
[ KERNEL] [ 1.968720] PCI: bus0: Fast back to back transfers disabled
[ KERNEL] [ 1.968736] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ KERNEL] [ 1.968948] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ KERNEL] [ 1.968995] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ KERNEL] [ 1.969114] pci 0000:01:00.0: PME# supported from D0 D3cold
[ KERNEL] [ 1.971937] PCI: bus1: Fast back to back transfers disabled
[ KERNEL] [ 1.971952] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ KERNEL] [ 1.971988] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ KERNEL] [ 1.972004] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ KERNEL] [ 1.972026] pci 0000:00:00.0: PCI bridge to [bus 01]
[ KERNEL] [ 1.972038] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ KERNEL] [ 1.972202] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ KERNEL] [ 1.972410] pcieport 0000:00:00.0: Signaling PME with IRQ 53
[ KERNEL] [ 1.972656] pcieport 0000:00:00.0: AER enabled with IRQ 53
[ KERNEL] [ 1.972889] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ KERNEL] [ 1.973367] bcm2708_fb soc:fb: FB found 1 display(s)
[ KERNEL] [ 1.989462] Console: switching to colour frame buffer device 210x65
[ KERNEL] [ 1.994511] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1680x1050
[ KERNEL] [ 1.996345] iproc-rng200 fe104000.rng: hwrng registered
[ KERNEL] [ 1.996528] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ KERNEL] [ 1.997091] vc-sm: Videocore shared memory driver
[ KERNEL] [ 1.997587] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ KERNEL] [ 1.998457] zram: Added device: zram0
[ KERNEL] [ 2.002811] libphy: Fixed MDIO Bus: probed
[ KERNEL] [ 2.003119] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ KERNEL] [ 2.003163] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ KERNEL] [ 2.055073] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ KERNEL] [ 2.055212] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
[ KERNEL] [ 2.055775] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ KERNEL] [ 2.055787] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.055797] usb usb1: Product: xHCI Host Controller
[ KERNEL] [ 2.055806] usb usb1: Manufacturer: Linux 4.19.80-v7l xhci-hcd
[ KERNEL] [ 2.055814] usb usb1: SerialNumber: 0000:01:00.0
[ KERNEL] [ 2.056286] hub 1-0:1.0: USB hub found
[ KERNEL] [ 2.056327] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 2.056707] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ KERNEL] [ 2.056732] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ KERNEL] [ 2.056767] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ KERNEL] [ 2.057066] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ KERNEL] [ 2.057081] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.057090] usb usb2: Product: xHCI Host Controller
[ KERNEL] [ 2.057103] usb usb2: Manufacturer: Linux 4.19.80-v7l xhci-hcd
[ KERNEL] [ 2.057112] usb usb2: SerialNumber: 0000:01:00.0
[ KERNEL] [ 2.057560] hub 2-0:1.0: USB hub found
[ KERNEL] [ 2.057601] hub 2-0:1.0: 4 ports detected
[ KERNEL] [ 2.058701] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 2.084257] dwc_otg fe980000.usb: base=(ptrval)
[ KERNEL] [ 2.284444] Core Release: 2.80a
[ KERNEL] [ 2.284455] Setting default values for core params
[ KERNEL] [ 2.284474] Finished setting default values for core params
[ KERNEL] [ 2.484764] Using Buffer DMA mode
[ KERNEL] [ 2.484771] Periodic Transfer Interrupt Enhancement - disabled
[ KERNEL] [ 2.484778] Multiprocessor Interrupt Enhancement - disabled
[ KERNEL] [ 2.484786] OTG VER PARAM: 0, OTG VER FLAG: 0
[ KERNEL] [ 2.484816] Dedicated Tx FIFOs mode
[ KERNEL] [ 2.485484] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = f3866000 dma = 0x00000000f7548000 len=9024
[ KERNEL] [ 2.485507] FIQ FSM acceleration enabled for :
[ KERNEL] [ 2.485507] Non-periodic Split Transactions
[ KERNEL] [ 2.485507] Periodic Split Transactions
[ KERNEL] [ 2.485507] High-Speed Isochronous Endpoints
[ KERNEL] [ 2.485507] Interrupt/Control Split Transaction hack enabled
[ KERNEL] [ 2.485516] dwc_otg: Microframe scheduler enabled
[ KERNEL] [ 2.485569] WARN::hcd_init_fiq:457: FIQ on core 1
[ KERNEL] [ 2.485585] WARN::hcd_init_fiq:458: FIQ ASM at c04fb97c length 36
[ KERNEL] [ 2.485600] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
[ KERNEL] [ 2.485633] dwc_otg fe980000.usb: DWC OTG Controller
[ KERNEL] [ 2.485660] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[ KERNEL] [ 2.485686] dwc_otg fe980000.usb: irq 37, io mem 0x00000000
[ KERNEL] [ 2.485732] Init: Port Power? op_state=1
[ KERNEL] [ 2.485739] Init: Power Port (0)
[ KERNEL] [ 2.485890] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ KERNEL] [ 2.485902] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.485911] usb usb3: Product: DWC OTG Controller
[ KERNEL] [ 2.485921] usb usb3: Manufacturer: Linux 4.19.80-v7l dwc_otg_hcd
[ KERNEL] [ 2.485930] usb usb3: SerialNumber: fe980000.usb
[ KERNEL] [ 2.486383] hub 3-0:1.0: USB hub found
[ KERNEL] [ 2.486417] hub 3-0:1.0: 1 port detected
[ KERNEL] [ 2.486996] dwc_otg: FIQ enabled
[ KERNEL] [ 2.487002] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 2.487008] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 2.487019] Module dwc_common_port init
[ KERNEL] [ 2.487347] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 2.488131] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ KERNEL] [ 2.488298] bcm2835-cpufreq: min=600000 max=1500000
[ KERNEL] [ 2.488799] sdhci: Secure Digital Host Controller Interface driver
[ KERNEL] [ 2.488805] sdhci: Copyright(c) Pierre Ossman
[ KERNEL] [ 2.489180] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ KERNEL] [ 2.489446] sdhci-pltfm: SDHCI platform and OF driver helper
[ KERNEL] [ 2.489870] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 2.490245] usbcore: registered new interface driver usbhid
[ KERNEL] [ 2.490249] usbhid: USB HID core driver
[ KERNEL] [ 2.490826] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ KERNEL] [ 2.492129] [vc_sm_connected_init]: start
[ KERNEL] [ 2.501479] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 2.501954] NET: Registered protocol family 17
[ KERNEL] [ 2.502050] Registering SWP/SWPB emulation handler
[ KERNEL] [ 2.502298] Loading compiled-in X.509 certificates
[ KERNEL] [ 2.505121] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ KERNEL] [ 2.505543] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ KERNEL] [ 2.505823] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ KERNEL] [ 2.505827] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ KERNEL] [ 2.531382] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ KERNEL] [ 2.547957] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ KERNEL] [ 2.549492] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.551138] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.553897] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ KERNEL] [ 2.555889] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.563342] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ KERNEL] [ 2.563529] of_cfs_init
[ KERNEL] [ 2.563592] of_cfs_init: OK
[ KERNEL] [ 2.587263] Freeing unused kernel memory: 6144K
[ KERNEL] [ 2.623914] random: fast init done
[ KERNEL] [ 2.651345] Run /init as init process
[ KERNEL] [ 2.651918] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ KERNEL] [ 2.653510] mmc1: new high speed SDIO card at address 0001
[ KERNEL] [ 2.696421] mmc0: new ultra high speed DDR50 SDHC card at address 0007
[ KERNEL] [ 2.696771] mmcblk0: mmc0:0007 SD32G 28.8 GiB
[ KERNEL] [ 2.697761] mmcblk0: p1
[ hotplug] [ 2.694092] Block device 179:0. No action.
[ hotplug] [ 2.694131] Block device 179:1. No action.
[ KERNEL] [ 2.836538] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ KERNEL] [ 2.836543] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ KERNEL] [ 2.836547] usb 1-1: Product: USB2.0 Hub
[ KERNEL] [ 2.837869] hub 1-1:1.0: USB hub found
[ KERNEL] [ 2.838132] hub 1-1:1.0: 4 ports detected
[ hotplug] [ 2.915469] Block device 254:0. No action.
[ pfac] [ 2.955193] Run /sbin/initrd.
[ pfac] [ 2.955449] Ok, PID 755.
[ initrd] [ 2.960563] WTware 5.8.72/RPi shell.
[ initrd] [ 2.960868] Load font 'ter-c32b.psf', console 105x32.
[ initrd] [ 2.976439] HDD/MMC/SD boot.
[ KERNEL] [ 2.995587] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ KERNEL] [ 3.025890] usb 2-1: New USB device found, idVendor=0424, idProduct=5744, bcdDevice= 2.86
[ KERNEL] [ 3.025902] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ KERNEL] [ 3.025912] usb 2-1: Product: USB5744
[ KERNEL] [ 3.025922] usb 2-1: Manufacturer: Microchip Tech
[ KERNEL] [ 3.028088] hub 2-1:1.0: USB hub found
[ KERNEL] [ 3.028158] hub 2-1:1.0: 2 ports detected
[ KERNEL] [ 3.155393] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
[ KERNEL] [ 3.286024] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2744, bcdDevice= 2.86
[ KERNEL] [ 3.286036] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 3.286046] usb 1-1.1: Product: USB2744
[ KERNEL] [ 3.286056] usb 1-1.1: Manufacturer: Microchip Tech
[ KERNEL] [ 3.287355] hub 1-1.1:1.0: USB hub found
[ KERNEL] [ 3.287427] hub 1-1.1:1.0: 4 ports detected
[ KERNEL] [ 4.015398] usb 1-1.1.3: new low-speed USB device number 4 using xhci_hcd
[ KERNEL] [ 4.155243] usb 1-1.1.3: New USB device found, idVendor=413c, idProduct=2107, bcdDevice= 1.15
[ KERNEL] [ 4.155255] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 4.155264] usb 1-1.1.3: Product: Dell USB Entry Keyboard
[ KERNEL] [ 4.155274] usb 1-1.1.3: Manufacturer: Dell
[ KERNEL] [ 4.163279] input: Dell Dell USB Entry Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/0003:413C:2107.0001/input/input0
[ KERNEL] [ 4.226418] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-0000:01:00.0-1.1.3/input0
[ KERNEL] [ 4.345387] usb 1-1.1.4: new low-speed USB device number 5 using xhci_hcd
[ KERNEL] [ 4.482041] usb 1-1.1.4: New USB device found, idVendor=0461, idProduct=4d81, bcdDevice= 2.00
[ KERNEL] [ 4.482053] usb 1-1.1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ KERNEL] [ 4.482063] usb 1-1.1.4: Product: USB Optical Mouse
[ KERNEL] [ 4.491358] input: USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.4/1-1.1.4:1.0/0003:0461:4D81.0002/input/input1
[ KERNEL] [ 4.491698] hid-generic 0003:0461:4D81.0002: input,hidraw1: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:01:00.0-1.1.4/input0
[ initrd] [ 4.792577] Success: /dev/mmcblk0p1 mounted to /bootmedia.
| #hdmi_enable_4kp60=1
| #hdmi_enable_4k=1
| core_freq_min=500
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=2
| #hdmi_mode=81
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| #gpu_mem_1024=256
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| [pi4]
| max_framebuffers=2
| [all]
| #hdmi_group=2
| #hdmi_mode=58
| # 800x600: hdmi_mode=9
| # 1024x768: hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768: hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900: hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768: hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| #[HDMI:0]
| # hdmi_group=2
| # hdmi_mode=42
| #[HDMI:1]
| # hdmi_group=2
| # hdmi_mode=58
| hdmi_group=2
| hdmi_mode=58
[ initrd] [ 4.836501] Do not cache package files.
[ initrd] [ 4.836600] WTpassword present: c4e1bc6d19f9f2d258c1ee33d89e471a.
[ initrd] [ 4.868389] USB: 0424:5744 Standard Microsystems Corp. Hub.
[ initrd] [ 4.868444] USB: 0424:2744 Standard Microsystems Corp. Hub.
[ initrd] [ 4.868478] USB: 2109:3431 VIA Labs, Inc. Hub.
[ initrd] [ 4.868520] USB: 413c:2107 Dell Computer Corp..
[ initrd] [ 4.868554] USB: 0461:4d81 Primax Electronics, Ltd Dell N889 Optical Mouse.
| clientIP=10.30.81.250
| config=local
| setupPassword=c4e1bc6d19f9f2d258c1ee33d89e471a
| netmedia=ethernet
| routerIP=10.30.81.254
| nameserverIP=10.30.80.50
[ initrd] [ 6.732152] Load Ethernet drivers.
[ initrd] [ 6.732244] modprobe genet.
[ KERNEL] [ 6.745065] bcmgenet fd580000.genet: failed to get enet clock
[ KERNEL] [ 6.745081] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ KERNEL] [ 6.745098] bcmgenet fd580000.genet: failed to get enet-wol clock
[ KERNEL] [ 6.745117] bcmgenet fd580000.genet: failed to get enet-eee clock
[ KERNEL] [ 6.745137] bcmgenet: Skipping UMAC reset
[ KERNEL] [ 6.745471] unimac-mdio unimac-mdio.-19: DMA mask not set
[ KERNEL] [ 6.765364] libphy: bcmgenet MII bus: probed
[ KERNEL] [ 6.808424] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ KERNEL] [ 6.810925] bcmgenet: Skipping UMAC reset
[ KERNEL] [ 6.925672] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ KERNEL] [ 8.005534] bcmgenet fd580000.genet eth0: Link is Down
[ KERNEL] [ 12.165512] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control off
[ initrd] [ 12.228724] WTpassword present: c4e1bc6d19f9f2d258c1ee33d89e471a.
[ pfac] [ 12.230487] Run /sbin/httpd.
[ initrd] [ 12.230543] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[ pfac] [ 12.230652] Ok, PID 810.
[ initrd] [ 12.230708] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[ initrd] [ 12.231724] Common local disk config:
| #turnoffmenu=on
| #connection
| #displayname=CCTV Server
| #server=10.33.80.1
| #usb=068e:00ca
| server=10.30.81.110
| user=
| onerror = quiet
| vhusb = on
| vhusb = UseAVAHI
| vhusb = 068e:00ca
| redraw_delay=100
| scale_factor = 100
| bpp = 32
| #graphic = abcdefg
| #bpp=32
| #connection
| #displayname=Enter server address
| #server=--new--
| onerror=quiet
| vhusb=068e:00ca
| redraw_delay=100
| bpp=32
| displayName=JUNWS003
| server=10.30.81.110
| user=
| scale_factor=100
[ initrd] [ 12.233638] Hostname: "wtwDCA6322F3FD9".
[ initrd] [ 12.233736] [NTP] 42 DHCP option is not set.
[ httpd] [ 12.239106] Internal HTTP Server, WTware 5.8.72/RPi
[ httpd] [ 12.248595] Reread settings.
[ initrd] [ 12.248705] Unpack /bootmedia/packages/pi2-f.
[ httpd] [ 12.248819] Everyone can control terminal by HTTP.
[ KERNEL] [ 12.381416] random: crng init done
[ gm] [ 12.378583] WTware 5.8.72/RPi session manager.
[ gm] [ 12.440114] EV_REL flag found. Add mouse event1: USB Optical Mouse.
[ gm] [ 12.440215] Add keyboard event0: Dell Dell USB Entry Keyboard.
[ gm] [ 12.440303] Display mode: 1680x1050, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 12.730921] Framebuffer device found.
[ gm] [ 12.730967] LINELENBYTES 3360
[ gm] [ 12.731001] VLEN 3528000
[ gm] [ 12.732030] Use /lib/ui16.so.
[ gm] [ 12.744496] Copy /bootmedia/configs/vhusbdarm to /vh/vhusbdarm.
| UseAVAHI=0
[ gm] [ 12.755249] Run '/vh/vhusbdarm -b -c /vh/config.ini -r /tmp/vh.out', log '', env '', pid ''.
[ pfac] [ 12.755311] Run /vh/vhusbdarm -b -c /vh/config.ini -r /tmp/vh.out.
[ pfac] [ 12.755440] Ok, PID 812.
[ VirtualHere] [ 12.808827] Wed Oct 23 00:00:10 2019 LOG_INFO >>> Starting VirtualHere USB Server v4.0.5 (Built: Oct 18 2019, 17:41:59)<<<
[ VirtualHere] [ 12.808868] Wed Oct 23 00:00:10 2019 LOG_INFO Using configuration /vh/config.ini
[ pfac] [ 12.809222] Process pid 812 terminated, status 00000000.
[ gm] [ 12.814516] Run '/sbin/resolver 0x1f5df20 dns [10.30.81.110]', log '', env '', pid ''.
[ pfac] [ 12.814569] Run /sbin/resolver 0x1f5df20 dns [10.30.81.110].
[ pfac] [ 12.814666] Ok, PID 814.
[ gm] [ 12.814716] Nobody can control terminal by VNC.
[ gm] [ 12.816987] 10.30.81.110 => 10.30.81.110.
[ pfac] [ 12.817136] Process pid 814 terminated, status 00000000.
[ gm] [ 12.819991] Free ram before fork terminal client /sbin/rdpclient (session 1): 3942636 Kb.
[ pfac] [ 12.820049] Run /sbin/rdpclient 1.
[ gm] [ 12.820069] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 12.820176] Ok, PID 815.
[ rdpclient 815] [ 12.825128] RDP Terminal Client, WTware 5.8.72/RPi, pipe 1, pid 815.
[ rdpclient 815] [ 12.825491] Use /lib/ui16.so.
[ rdpclient 815] [ 12.826536] Make RDP session with 10.30.81.110, port 3389.
[ rdpclient 815] [ 12.826684] Username: "xxxx".
[ rdpclient 815] [ 12.826779] Password: present.
[ rdpclient 815] [ 12.826823] No PIN.
[ rdpclient 815] [ 12.826866] No domain.
[ rdpclient 815] [ 12.826913] No shell.
[ rdpclient 815] [ 12.826954] No directory.
[ rdpclient 815] [ 12.826997] Window: 1616x1050@16.
[ rdpclient 815] [ 12.827034] PFlags 0x0000002F.
[ rdpclient 815] [ 12.827089] Keyboard 00000409:00000000.
[ rdpclient 815] [ 12.827133] My hostname "wtwDCA6322F3FD9".
[ rdpclient 815] [ 12.827178] TCP: connecting to 10.30.81.110:3389.
[ rdpclient 815] [ 12.830078] TCP: connection with 10.30.81.110:3389 established.
[ rdpclient 815] [ 12.830141] Turn keepalive on.
[ rdpclient 815] [ 12.830710] Free ram after buffers allocation: 3942384 KB.
[ rdpclient 815] [ 12.849113] Reconnect with NLA enabled.
[ rdpclient 815] [ 12.849198] TCP: reconnecting to 10.30.81.110:3389.
[ rdpclient 815] [ 12.850715] TCP: connection with 10.30.81.110:3389 established.
[ rdpclient 815] [ 12.850770] Turn keepalive on.
[ rdpclient 815] [ 12.864472] Server supports GFX Pipeline.
[ rdpclient 815] [ 12.864540] NLA.
[ rdpclient 815] [ 12.864591] SSL/TLS.
[ VirtualHere] [ 12.876102] Wed Oct 23 00:00:10 2019 LOG_INFO Server licensed to=unlicensed max_devices=1
[ VirtualHere] [ 12.876238] Wed Oct 23 00:00:10 2019 LOG_INFO Using large URB's
[ VirtualHere] [ 12.877310] Wed Oct 23 00:00:10 2019 LOG_INFO Listening on all network interfaces at TCP port 7575
[ rdpclient 815] [ 12.945798] Enable font smoothing and Desktop Composition.
[ rdpclient 815] [ 13.191362] GFX codec.
[ rdpclient 815] [ 14.435033] Run 4 tile threads.
[ rdpclient 815] [ 14.499703] errorInfo 0x00000000.
[ rdpclient 815] [ 14.859257] SessionId 0x00000002: xxxx.
Posted: Tue Nov 12, 2019 3:01 am
by aceycv8
@aka
Any ideas or anything to try?
thank you
Posted: Tue Nov 12, 2019 1:10 pm
Try wtware version 5.8.78. Show me the same log if it still doesn't work. Real color depth is in the end of the log, line:
Posted: Sun Nov 17, 2019 3:48 am
by aceycv8
thank you Aka - this seems to have helped with the new version
