2 Monitor Setup
Posted: Thu Oct 31, 2019 6:00 pm
by Cincopyro
I'm trying to setup a pi 4 to use 2 monitors when connecting to a windows RDP session my config is:
infobox=always, shutdown, reboot
display=1920x1080, HDMI
server=192.168.223.128
M2_display=1920x1080, HDMI
video=i915(F)
M2_position=right
managed=on
connection
M2_next screen
connection
When connecting to the RDP session both monitors are used as in both show the login screen but once I input login creds it will only display windows on one of the screens and the other will stay on the WTware login screen. Not sure what I'm doing wrong here based on the documentation for multi-monitor setups I think my config is correct.
Logs:
WTware v.5.8.66/RPi
WTware 5.8.66/RPi supervisor.
[        KERNEL] [    0.000000] Linux version 4.19.73-v7l (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #6 SMP Sun Sep 22 04:45:22 EDT 2019
[        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[        KERNEL] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[        KERNEL] [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[        KERNEL] [    0.000000] cma: Reserved 64 MiB at 0x0000000037400000
[        KERNEL] [    0.000000] On node 0 totalpages: 1012736
[        KERNEL] [    0.000000]   DMA zone: 1536 pages used for memmap
[        KERNEL] [    0.000000]   DMA zone: 0 pages reserved
[        KERNEL] [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[        KERNEL] [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
[        KERNEL] [    0.000000] random: get_random_bytes called from 0xc0a009e0 with crng_init=0
[        KERNEL] [    0.000000] percpu: Embedded 15 pages/cpu s29132 r8192 d24116 u61440
[        KERNEL] [    0.000000] pcpu-alloc: s29132 r8192 d24116 u61440 alloc=15*4096
[        KERNEL] [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011200
[        KERNEL] [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:19:EE:97 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 quiet wtboot=mmc
[        KERNEL] [    0.000000] Memory: 3937688K/4050944K available (6144K kernel code, 148K rwdata, 664K rodata, 6144K init, 372K bss, 47720K reserved, 65536K cma-reserved, 3198976K highmem)
[        KERNEL] [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[        KERNEL] [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[        KERNEL] [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[        KERNEL] [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[        KERNEL] [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (8160 kB)
[        KERNEL] [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (6144 kB)
[        KERNEL] [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 149 kB)
[        KERNEL] [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 373 kB)
[        KERNEL] [    0.000000] rcu: Hierarchical RCU implementation.
[        KERNEL] [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[        KERNEL] [    0.000000] GIC: Using split EOI/Deactivate mode
[        KERNEL] [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[        KERNEL] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[        KERNEL] [    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[        KERNEL] [    0.000016] Switching to timer-based delay loop, resolution 18ns
[        KERNEL] [    0.000192] Console: colour dummy device 80x30
[        KERNEL] [    0.000210] console [tty0] enabled
[        KERNEL] [    0.000243] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[        KERNEL] [    0.000260] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000382] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000399] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000900] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001208] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001598] Setting up static identity map for 0x200000 - 0x20003c
[        KERNEL] [    0.001694] rcu: Hierarchical SRCU implementation.
[        KERNEL] [    0.002203] smp: Bringing up secondary CPUs ...
[        KERNEL] [    0.002792] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003462] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004103] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004189] smp: Brought up 1 node, 4 CPUs
[        KERNEL] [    0.004199] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[        KERNEL] [    0.004206] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004212] CPU: Virtualization extensions available.
[        KERNEL] [    0.004670] devtmpfs: initialized
[        KERNEL] [    0.012887] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[        KERNEL] [    0.013183] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.013199] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.014716] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.015643] NET: Registered protocol family 16
[        KERNEL] [    0.017826] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.021692] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[        KERNEL] [    0.057708] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[        KERNEL] [    0.059437] vgaarb: loaded
[        KERNEL] [    0.059670] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.059727] usbcore: registered new interface driver hub
[        KERNEL] [    0.059793] usbcore: registered new device driver usb
[        KERNEL] [    0.074188] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-09-12 16:29, variant start
[        KERNEL] [    0.084183] raspberrypi-firmware soc:firmware: Firmware hash is 1a1172e606ae6e16d13a6da2c7834ee06f69c48f
[        KERNEL] [    0.095339] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.102866] NET: Registered protocol family 2
[        KERNEL] [    0.103369] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[        KERNEL] [    0.103391] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.103444] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.103505] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.103622] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.103648] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.103778] NET: Registered protocol family 1
[        KERNEL] [    0.103803] PCI: CLS 0 bytes, default 64
[        KERNEL] [    1.818985] Initialise system trusted keyrings
[        KERNEL] [    1.819140] workingset: timestamp_bits=30 max_order=20 bucket_order=0
[        KERNEL] [    1.859058] Key type asymmetric registered
[        KERNEL] [    1.859068] Asymmetric key parser 'x509' registered
[        KERNEL] [    1.859137] bounce: pool size: 64 pages
[        KERNEL] [    1.859202] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    1.859211] io scheduler noop registered
[        KERNEL] [    1.859406] io scheduler cfq registered (default)
[        KERNEL] [    1.915550] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[        KERNEL] [    1.915574] brcm-pcie fd500000.pcie: could not get clock
[        KERNEL] [    1.915646] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[        KERNEL] [    1.915691] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
[        KERNEL] [    1.975395] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[        KERNEL] [    1.975606] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[        KERNEL] [    1.975620] pci_bus 0000:00: root bus resource [bus 00-01]
[        KERNEL] [    1.975634] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[        KERNEL] [    1.975668] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[        KERNEL] [    1.975758] pci 0000:00:00.0: PME# supported from D0 D3hot
[        KERNEL] [    1.978633] PCI: bus0: Fast back to back transfers disabled
[        KERNEL] [    1.978656] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[        KERNEL] [    1.978815] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[        KERNEL] [    1.978864] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[        KERNEL] [    1.978988] pci 0000:01:00.0: PME# supported from D0 D3cold
[        KERNEL] [    1.981788] PCI: bus1: Fast back to back transfers disabled
[        KERNEL] [    1.981804] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[        KERNEL] [    1.981842] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[        KERNEL] [    1.981859] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[        KERNEL] [    1.981881] pci 0000:00:00.0: PCI bridge to [bus 01]
[        KERNEL] [    1.981894] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[        KERNEL] [    1.982058] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[        KERNEL] [    1.982218] pcieport 0000:00:00.0: Signaling PME with IRQ 53
[        KERNEL] [    1.982359] pcieport 0000:00:00.0: AER enabled with IRQ 53
[        KERNEL] [    1.982484] pci 0000:01:00.0: enabling device (0140 -> 0142)
[        KERNEL] [    1.982880] bcm2708_fb soc:fb: FB found 2 display(s)
[        KERNEL] [    2.026518] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    2.037435] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
[        KERNEL] [    2.072815] bcm2708_fb soc:fb: Registered framebuffer for display 1, size 1920x1080
[        KERNEL] [    2.074732] iproc-rng200 fe104000.rng: hwrng registered
[        KERNEL] [    2.074952] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.075510] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.075973] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[        KERNEL] [    2.076886] zram: Added device: zram0
[        KERNEL] [    2.079347] libphy: Fixed MDIO Bus: probed
[        KERNEL] [    2.079625] xhci_hcd 0000:01:00.0: xHCI Host Controller
[        KERNEL] [    2.079674] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.132434] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[        KERNEL] [    2.132701] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
[        KERNEL] [    2.132968] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[        KERNEL] [    2.132982] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.132999] usb usb1: Product: xHCI Host Controller
[        KERNEL] [    2.133021] usb usb1: Manufacturer: Linux 4.19.73-v7l xhci-hcd
[        KERNEL] [    2.133034] usb usb1: SerialNumber: 0000:01:00.0
[        KERNEL] [    2.133836] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.133879] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.134303] xhci_hcd 0000:01:00.0: xHCI Host Controller
[        KERNEL] [    2.134344] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[        KERNEL] [    2.134367] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[        KERNEL] [    2.134582] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[        KERNEL] [    2.134594] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.134606] usb usb2: Product: xHCI Host Controller
[        KERNEL] [    2.134615] usb usb2: Manufacturer: Linux 4.19.73-v7l xhci-hcd
[        KERNEL] [    2.134624] usb usb2: SerialNumber: 0000:01:00.0
[        KERNEL] [    2.135627] hub 2-0:1.0: USB hub found
[        KERNEL] [    2.135674] hub 2-0:1.0: 4 ports detected
[        KERNEL] [    2.136982] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.162614] dwc_otg fe980000.usb: base=(ptrval)
[        KERNEL] [    2.362851] Core Release: 2.80a
[        KERNEL] [    2.362866] Setting default values for core params
[        KERNEL] [    2.362895] Finished setting default values for core params
[        KERNEL] [    2.563229] Using Buffer DMA mode
[        KERNEL] [    2.563237] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.563243] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.563253] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.563288] Dedicated Tx FIFOs mode
[        KERNEL] [    2.564013] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = f52af000 dma = 0x00000000f7544000 len=9024
[        KERNEL] [    2.564049] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.564049] Non-periodic Split Transactions
[        KERNEL] [    2.564049] Periodic Split Transactions
[        KERNEL] [    2.564049] High-Speed Isochronous Endpoints
[        KERNEL] [    2.564049] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.564058] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.564121] WARN::hcd_init_fiq:457: FIQ on core 1
[        KERNEL] [    2.564138] WARN::hcd_init_fiq:458: FIQ ASM at c04fadcc length 36
[        KERNEL] [    2.564155] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
[        KERNEL] [    2.564196] dwc_otg fe980000.usb: DWC OTG Controller
[        KERNEL] [    2.564243] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[        KERNEL] [    2.564278] dwc_otg fe980000.usb: irq 37, io mem 0x00000000
[        KERNEL] [    2.564332] Init: Port Power? op_state=1
[        KERNEL] [    2.564339] Init: Power Port (0)
[        KERNEL] [    2.564505] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[        KERNEL] [    2.564517] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.564527] usb usb3: Product: DWC OTG Controller
[        KERNEL] [    2.564536] usb usb3: Manufacturer: Linux 4.19.73-v7l dwc_otg_hcd
[        KERNEL] [    2.564545] usb usb3: SerialNumber: fe980000.usb
[        KERNEL] [    2.565081] hub 3-0:1.0: USB hub found
[        KERNEL] [    2.565119] hub 3-0:1.0: 1 port detected
[        KERNEL] [    2.565827] dwc_otg: FIQ enabled
[        KERNEL] [    2.565837] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.565846] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.565859] Module dwc_common_port init
[        KERNEL] [    2.566309] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.567253] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.567488] bcm2835-cpufreq: min=600000 max=1500000
[        KERNEL] [    2.568139] sdhci: Secure Digital Host Controller Interface driver
[        KERNEL] [    2.568146] sdhci: Copyright(c) Pierre Ossman
[        KERNEL] [    2.568663] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[        KERNEL] [    2.568998] sdhci-pltfm: SDHCI platform and OF driver helper
[        KERNEL] [    2.569629] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.569989] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.569993] usbhid: USB HID core driver
[        KERNEL] [    2.570629] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[        KERNEL] [    2.573302] [vc_sm_connected_init]: start
[        KERNEL] [    2.583746] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.584258] NET: Registered protocol family 17
[        KERNEL] [    2.584345] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.584586] Loading compiled-in X.509 certificates
[        KERNEL] [    2.587458] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[        KERNEL] [    2.587734] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[        KERNEL] [    2.588006] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.588011] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[        KERNEL] [    2.613621] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[        KERNEL] [    2.630623] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    2.632153] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    2.633682] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    2.636496] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    2.638019] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    2.645359] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[        KERNEL] [    2.645556] of_cfs_init
[        KERNEL] [    2.645637] of_cfs_init: OK
[        KERNEL] [    2.669981] Freeing unused kernel memory: 6144K
[        KERNEL] [    2.705797] random: fast init done
[        KERNEL] [    2.715392] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[        KERNEL] [    2.731591] Run /init as init process
[        KERNEL] [    2.734767] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    2.785818] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[        KERNEL] [    2.786192] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[        KERNEL] [    2.788242]  mmcblk0: p1
[       hotplug] [    2.784763] Block device 179:0. No action.
[       hotplug] [    2.784921] Block device 179:1. No action.
[        KERNEL] [    2.916522] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[        KERNEL] [    2.916528] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[        KERNEL] [    2.916532] usb 1-1: Product: USB2.0 Hub
[        KERNEL] [    2.919089] hub 1-1:1.0: USB hub found
[        KERNEL] [    2.919377] hub 1-1:1.0: 4 ports detected
[       hotplug] [    3.031011] Block device 254:0. No action.
[          pfac] [    3.042477] Run /sbin/initrd.
[          pfac] [    3.043090] Ok, PID 757.
[        initrd] [    3.048448] WTware 5.8.66/RPi shell.
[        initrd] [    3.048808] Load font 'ter-c32b.psf', console 120x33.
[        initrd] [    3.058704] HDD/MMC/SD boot.
[        KERNEL] [    3.245375] usb 1-1.3: new low-speed USB device number 3 using xhci_hcd
[        KERNEL] [    3.383091] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c016, bcdDevice= 3.40
[        KERNEL] [    3.383103] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    3.383114] usb 1-1.3: Product: Optical USB Mouse
[        KERNEL] [    3.383123] usb 1-1.3: Manufacturer: Logitech
[        KERNEL] [    3.392567] input: Logitech Optical USB Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C016.0001/input/input0
[        KERNEL] [    3.392938] hid-generic 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:01:00.0-1.3/input0
[        KERNEL] [    3.495372] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
[        KERNEL] [    3.633127] usb 1-1.4: New USB device found, idVendor=045e, idProduct=0752, bcdDevice= 3.00
[        KERNEL] [    3.633140] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    3.633151] usb 1-1.4: Product: Wired Keyboard 400
[        KERNEL] [    3.633161] usb 1-1.4: Manufacturer: Microsoft
[        KERNEL] [    3.643031] input: Microsoft Wired Keyboard 400 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:0752.0002/input/input1
[        KERNEL] [    3.706704] hid-generic 0003:045E:0752.0002: input,hidraw1: USB HID v1.11 Keyboard [Microsoft Wired Keyboard 400] on usb-0000:01:00.0-1.4/input0
[        initrd] [    4.278777] Success: /dev/mmcblk0p1 mounted to /bootmedia.
| # https://www.raspberrypi.org/documentation/configuration/config-txt/README.md
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| [pi4]
| max_framebuffers=2
| [all]
| #hdmi_group=2
| #hdmi_mode=58
| # 800x600:   hdmi_mode=9
| # 1024x768:  hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768:  hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900:  hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768:  hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| # https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
| #[HDMI:0]
| # hdmi_group=2
| # hdmi_mode=42
| #[HDMI:1]
| # hdmi_group=2
| # hdmi_mode=58
[        initrd] [    4.309832] Do not cache package files.
[        initrd] [    4.309938] WTpassword present: 8b6109e3948ba73428d7da9d0901c89b.
[        initrd] [    4.345474] USB: 046d:c016 Logitech, Inc. Optical Wheel Mouse.
[        initrd] [    4.345530] USB: 2109:3431 VIA Labs, Inc. Hub.
[        initrd] [    4.345563] USB: 045e:0752 Microsoft Corp. Wired Keyboard 400.
| clientIP = *
| config = local
| setupPassword = 8b6109e3948ba73428d7da9d0901c89b
[        initrd] [    6.229024] Load Ethernet drivers.
[        initrd] [    6.229138] modprobe genet.
[        KERNEL] [    6.240877] bcmgenet fd580000.genet: failed to get enet clock
[        KERNEL] [    6.240885] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[        KERNEL] [    6.240891] bcmgenet fd580000.genet: failed to get enet-wol clock
[        KERNEL] [    6.240899] bcmgenet fd580000.genet: failed to get enet-eee clock
[        KERNEL] [    6.240914] bcmgenet: Skipping UMAC reset
[        KERNEL] [    6.241026] unimac-mdio unimac-mdio.-19: DMA mask not set
[        KERNEL] [    6.255348] libphy: bcmgenet MII bus: probed
[        KERNEL] [    6.308745] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[        KERNEL] [    6.310949] bcmgenet: Skipping UMAC reset
[        KERNEL] [    6.415643] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[        KERNEL] [    7.445489] bcmgenet fd580000.genet eth0: Link is Down
[        KERNEL] [   11.605499] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control off
[        initrd] [   11.618852] WTpassword present: 8b6109e3948ba73428d7da9d0901c89b.
[        initrd] [   11.941894] dhcp: 376 bytes from 192.168.223.250.
[        initrd] [   11.941993] 00000000:000001640000000000110000C0A8DFFAFFFFFFFF004300440164000002010600  ...d................C.D.d......
[        initrd] [   11.942079] 00000020:67458B6B0000000000000000C0A8DF98C0A8DFFA00000000DCA63219EE970000  gE.k......................2....
[        initrd] [   11.942164] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.942248] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.942331] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.942415] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.942497] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.942580] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.942662] 00000100:0000000000000000638253633501020104FFFFFF003A040001FA403B04000375  ........c.Sc5........:....@;...u
[        initrd] [   11.942744] 00000120:F033040003F4803604C0A8DFFA0304C0A8DF010604CE8299210F0E7777776F72  .3.....6................!..wwwor
[        initrd] [   11.942827] 00000140:6B732E6C6F63616C002A04CE8299504226687474703A2F2F70726F762E777777  ks.local.*....PB&http://prov.www
[        initrd] [   11.942911] 00000160:6F726B732E636F6D2F70726F762F7777776F726B732F00FF                  orks.com/prov/wwworks/..
[        initrd] [   13.140199] dhcp: 376 bytes from 192.168.223.250.
[        initrd] [   13.140297] 00000000:000001640000000000110000C0A8DFFAFFFFFFFF004300440164000002010600  ...d................C.D.d......
[        initrd] [   13.140382] 00000020:67458B6B0000000000000000C0A8DF980000000000000000DCA63219EE970000  gE.k......................2....
[        initrd] [   13.140465] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.140549] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.140632] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.140714] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.140796] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.140878] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.140960] 00000100:0000000000000000638253633501053A040001FA403B04000375F033040003F4  ........c.Sc5..:....@;...u.3....
[        initrd] [   13.141042] 00000120:803604C0A8DFFA0104FFFFFF000304C0A8DF010604CE8299210F0E7777776F72  .6......................!..wwwor
[        initrd] [   13.141124] 00000140:6B732E6C6F63616C002A04CE8299504226687474703A2F2F70726F762E777777  ks.local.*....PB&http://prov.www
[        initrd] [   13.141208] 00000160:6F726B732E636F6D2F70726F762F7777776F726B732F00FF                  orks.com/prov/wwworks/..
[        initrd] [   13.200098] [DHCP] DHCP server address 192.168.223.250.
[        initrd] [   13.200189] [DHCP] IP 192.168.223.152 mask 255.255.255.0.
[        initrd] [   13.200270] [DHCP] Default gateway 192.168.223.1.
[        initrd] [   13.200364] [DHCP] DNS 206.130.153.33.
[        initrd] [   13.200459] [DHCP] NTP 206.130.153.80.
[        initrd] [   13.200558] [DHCP] Domain wwworks.local.
[        initrd] [   13.200639] [DHCP] Doesn't understand value 'http://prov.wwworks.com/prov/wwworks/' in 066 DHCP option.
[        initrd] [   13.200723] [DHCP] TFTP from siaddr 192.168.223.250.
[        initrd] [   13.200805] [DHCP] TFTP 192.168.223.250.
[        initrd] [   13.200885] [DHCP] No boot file from DHCP.
[        initrd] [   13.200964] [DHCP] TFTP binary "", configs prefix "", using "/" slash.
[          pfac] [   13.202486] Run /sbin/httpd.
[        initrd] [   13.202561] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   13.202674] Ok, PID 806.
[        initrd] [   13.202719] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[        initrd] [   13.205298] Common local disk config:
| display=1920x1080
| M2_next screen
| display=1920x1080
| M2_next screen
[        initrd] [   13.207134] Hostname: "wtwDCA63219EE97".
[         httpd] [   13.211849] Internal HTTP Server, WTware 5.8.66/RPi
[        initrd] [   13.560395] Run '/bin/sh /tmp/ntpdate', log '/tmp/ntp.out', env '', pid ''.
[          pfac] [   13.560530] Run /bin/sh /tmp/ntpdate.
[          pfac] [   13.560780] Ok, PID 807.
[         httpd] [   13.566800] Reread settings.
[        initrd] [   13.566947] Unpack /bootmedia/packages/pi2-f.
[         httpd] [   13.567111] Everyone can control terminal by HTTP.
[           NTP] [   13.567236] ntpd: sending query to 206.130.153.80
[           NTP] [   13.574046] ntpd: reply from 206.130.153.80: offset:+3422934.154008 delay:0.006384 status:0x24 strat:2 refid:0x83006cce rootdelay:0.003235 reach:0x01
[        KERNEL] [   13.686660] random: crng init done
[            gm] [   13.684015] WTware 5.8.66/RPi session manager.
[            gm] [   13.684534] Add keyboard event1: Microsoft Wired Keyboard 400.
[            gm] [   13.750119] EV_REL flag found. Add mouse event0: Logitech Optical USB Mouse.
[            gm] [   13.750242] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   13.750337] M2 mode: 1920x1080, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   14.041240] Framebuffer device found.
[            gm] [   14.041297] LINELENBYTES 7680
[            gm] [   14.041333] VLEN 8294400
[            gm] [   14.041370] Second framebuffer device found.
[            gm] [   14.041406] LINELENBYTES 7680
[            gm] [   14.041442] VLEN 8294400
[            gm] [   14.042506] Use /lib/ui32.so.
[            gm] [   14.141936] Run '/sbin/resolver 0x218e278 dns [192.168.223.128]', log '', env '', pid ''.
[          pfac] [   14.142080] Run /sbin/resolver 0x218e278 dns [192.168.223.128].
[          pfac] [   14.142355] Ok, PID 811.
[          pfac] [   14.146364] Process pid 811 terminated, status 00000000.
[            gm] [   14.158268] Run '/sbin/resolver 0x218f410 dns [192.168.223.128]', log '', env '', pid ''.
[          pfac] [   14.158403] Run /sbin/resolver 0x218f410 dns [192.168.223.128].
[          pfac] [   14.158676] Ok, PID 812.
[            gm] [   14.158798] Nobody can control terminal by VNC.
[            gm] [   14.158929] 192.168.223.128 => 192.168.223.128.
[          pfac] [   14.161977] Process pid 812 terminated, status 00000000.
[            gm] [   14.163931] Free ram before fork terminal client /sbin/rdpclient (session 1): 3931976 Kb.
[          pfac] [   14.163972] Run /sbin/rdpclient 1.
[            gm] [   14.163998] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   14.164080] Ok, PID 813.
[ rdpclient 813] [   14.169081] RDP Terminal Client, WTware 5.8.66/RPi, pipe 1, pid 813.
[ rdpclient 813] [   14.169313] Use /lib/ui32.so.
[ rdpclient 813] [   14.170230] Make RDP session with 192.168.223.128, port 3389.
[ rdpclient 813] [   14.170396]  No username.
[ rdpclient 813] [   14.170475]  No password.
[ rdpclient 813] [   14.170532]  No PIN.
[ rdpclient 813] [   14.170580]  No domain.
[ rdpclient 813] [   14.170623]  No shell.
[ rdpclient 813] [   14.170665]  No directory.
[ rdpclient 813] [   14.170706]  Window: 1856x1080@24.
[ rdpclient 813] [   14.170749]  PFlags 0x0000002F.
[ rdpclient 813] [   14.170794]  Keyboard 00000409:00000000.
[ rdpclient 813] [   14.170835]  My hostname "wtwDCA63219EE97".
[ rdpclient 813] [   14.170894] TCP: connecting to 192.168.223.128:3389.
[ rdpclient 813] [   14.171533] TCP: connection with 192.168.223.128:3389 established.
[ rdpclient 813] [   14.171677] Turn keepalive on.
[ rdpclient 813] [   14.172779] Free ram after buffers allocation: 3931220 KB.
[            gm] [   14.177518] 192.168.223.128 => 192.168.223.128.
[            gm] [   14.180710] Free ram before fork terminal client /sbin/rdpclient (session 2): 3931220 Kb.
[          pfac] [   14.180762] Run /sbin/rdpclient 2.
[            gm] [   14.180783] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   14.180906] Ok, PID 814.
[ rdpclient 814] [   14.186096] RDP Terminal Client, WTware 5.8.66/RPi, pipe 2, pid 814.
[ rdpclient 814] [   14.186313] Use /lib/ui32.so.
[ rdpclient 814] [   14.187491] Make RDP session with 192.168.223.128, port 3389.
[ rdpclient 814] [   14.187657]  No username.
[ rdpclient 814] [   14.187716]  No password.
[ rdpclient 814] [   14.187760]  No PIN.
[ rdpclient 814] [   14.187806]  No domain.
[ rdpclient 814] [   14.187851]  No shell.
[ rdpclient 814] [   14.187895]  No directory.
[ rdpclient 814] [   14.187942]  Window: 1856x1080@24.
[ rdpclient 814] [   14.187986]  PFlags 0x0000002F.
[ rdpclient 814] [   14.188037]  Keyboard 00000409:00000000.
[ rdpclient 814] [   14.188080]  My hostname "wtwDCA63219EE97".
[ rdpclient 814] [   14.188124] TCP: connecting to 192.168.223.128:3389.
[ rdpclient 814] [   14.188308] TCP: connection with 192.168.223.128:3389 established.
[ rdpclient 814] [   14.188397] Turn keepalive on.
[ rdpclient 814] [   14.189586] Free ram after buffers allocation: 3930464 KB.
[           NTP] [   15.576158] ntpd: sending query to 206.130.153.80
[           NTP] [   15.582041] ntpd: reply from 206.130.153.80: offset:+3422934.154007 delay:0.005695 status:0x24 strat:2 refid:0x83006cce rootdelay:0.003235 reach:0x03
[          pfac] [   15.670142] Process pid 807 terminated, status 00000000.
[           NTP] [   15.670234] ntpd: setting time to 2019-10-31 14:49:06.998718 (offset +3422934.154007s)
[           NTP] [   15.670271] hwclock: can't open '/dev/misc/rtc': No such file or directory
[ rdpclient 813] [   19.153411] Reconnect with NLA enabled.
[ rdpclient 813] [   19.153702] TCP: reconnecting to 192.168.223.128:3389.
[ rdpclient 813] [   19.154275] TCP: connection with 192.168.223.128:3389 established.
[ rdpclient 813] [   19.154441] Turn keepalive on.
[ rdpclient 813] [   19.160461] Server supports GFX Pipeline.
[ rdpclient 813] [   19.160767] NLA.
[ rdpclient 813] [   19.160913] SSL/TLS.
[ rdpclient 813] [   19.182770] Enable font smoothing and Desktop Composition.
[ rdpclient 813] [   19.335719] GFX codec.
[ rdpclient 813] [   19.558822] SessionId 0x00000003: WWWORKS\ksawchuk.
[ rdpclient 813] [   22.181720] Run 4 tile threads.
[ rdpclient 813] [  107.228601] errorInfo 0x00000005.
[ rdpclient 813] [  107.228755] ERRINFO_DISCONNECTED_BY_OTHERCONNECTION: Another user connected to the server, forcing the disconnection of the current connection.
[ rdpclient 813] [  107.471506] Receive Disconnect Provider Ultimatum.
[ rdpclient 813] [  107.471629] Remote session disconnected, for another user
has connected to this session.
[            gm] [  107.480462] Final message: Remote session disconnected, for another user
[          pfac] [  107.485907] Process pid 813 terminated, status 00000009.
Send WTCU discover to 192.168.223.128.
Re: 2 Monitor Setup
Posted: Fri Nov 01, 2019 1:31 pm
...my config is:
From manual about logs https://wtware.com/logs.html
2. Remove all unnecessary lines from config. For example, if you have problem with usb barcode scanner, leave only server= and serial= parameters and remove all other lines.
After removing all unnecessary lines your config should be:
managed=on
Try it.
Re: 2 Monitor Setup
Posted: Fri Nov 01, 2019 4:02 pm
by Cincopyro
Thank you and I apologize, I've made the following changes:
a) Updated my WTware to 5.8.72
b) updated to the same on the pi
Rebooted the pi and logged into my terminal, both screens work now. I just hope me ignoring the basics will help others...again sorry for failing to do the basics before posting I appreciate your help WTware is an amazing product.
