Dual Monitor via USB-C to DisplayPort
wetty
Post by wetty » Wed Aug 29, 2018 11:26 am
we use Intel NUC-Kit i3-7100U 2.4GHz HD620 NUC7I3BNK as Thin Clients booting via pxe.
A second Monitor is attached via a USB C to DisplayPort Adapter.
Even when no second Monitor is configured, the second Monitor shows the same screen as the Monitor on die HDMI Port.
I tried several M2 Settings but all failed to get the Dual Monitor workin as expected.
Video Settings:
video=intel(U)
display=1920x1080, 60 Hz, HDMI
Any Idea?
Regards
Thomas
Re: Dual Monitor via USB-C to DisplayPort
Post by akatik » Wed Aug 29, 2018 5:03 pm
I can not make any comments until you show me logs. At first, make log with video=i915(f) with both monitors attached.
wetty
Post by wetty » Wed Aug 29, 2018 6:17 pm
Whenever I try to save the log, it was send via email to wtware.
But I will try copy the log manually.
Post by akatik » Wed Aug 29, 2018 7:20 pm
It says - "send me by e-mail to Wtware". But it is not sent. You should send it by yourself.
Post by aka » Tue Sep 04, 2018 9:56 pm
video=i915(f)
display=1920x1080, DP
M2_display=1920x1080, DP2
wetty
Post by wetty » Fri Sep 07, 2018 4:35 pm
After disabling RemoteFX on our Windows 2008 R2 Terminal Server the two Monitors works with your settings.
Thanks a lot
