Page 1 of 3
Zotac ZBOX PI330 problem with 2 monitors
Posted: Mon Dec 18, 2017 1:03 pm
by geefox
tried to test wtware on a new client -> Zotac ZBOX PI330
There is a strange behaviour. The Zotac Box has 2 video outputs - hdmi and display port.
As you stated in an other thread, i should determine the output names for the config.wtc with following line:
video=intel(u)
display=1024x768
The results are HDMI1 and HDMI2
[             X] [   13.906252] [    13.905] (II) intel(0): Output HDMI1 using initial mode 1024x768 +0+0
[             X] [   13.906261] [    13.905] (II) intel(0): Output HDMI2 using initial mode 1024x768 +0+0
If I try to edit the config.wtf file to this, the screens stay black
video=intel(u)
display=1024x768, HDMI
M2_display=1024x768, HDMI2
I've attached the logfile for determining the config and one with the error.
best regards
Re: Zotac ZBOX PI330 problem with 2 monitors
Posted: Tue Dec 19, 2017 5:54 am
I don't understand why it does not work. Try new build: http://wtware.com/testing/201712181803.zip
Posted: Tue Dec 19, 2017 10:58 am
by geefox
tried the new build, but same effect.
[             X] [   14.840940] [    14.840] (II) intel(0): Output HDMI1 connected
[             X] [   14.840950] [    14.840] (II) intel(0): Output HDMI2 connected
adapted config file to above outputs. It looks like the client doesnt recognize the 2nd screen if I specify HDMI and HDMI2
Posted: Wed Dec 20, 2017 7:31 am
I have no ideas :( Google doesn't find this error "HDMI2 is an invalid output for screen"
Show me log with video=i915(f) and the same display= and m2_display=
Posted: Wed Dec 20, 2017 10:19 am
by geefox
tried it only with following, but there was an error. client couldnt detect graphic
video=i915(f)
display=1024x768
Posted: Wed Dec 27, 2017 4:35 pm
by geefox
hello,
maybe it helps if I send you one device, so you guys could test it?
Posted: Thu Dec 28, 2017 6:54 pm
It would be great. Mail me to aka@wtware.com and I'll give you address.
Posted: Wed Jan 03, 2018 11:18 am
by geefox
sent you the mail a few minutes ago - sorry for the late reply, but I was on vacation.
as written in the mail - do you have any "supported" or "featured" hardware models for 2x displayport or 1x hdmi /1x displayport - for example something like the zotac zbox?
best regards
Posted: Wed Jan 03, 2018 12:31 pm
Noone writes us "hardware works" when hardware works. Your log was first intel log we received this year where we can not run second display. Others should work. Try another manufacturer, not zodac. With intel graphic.
Posted: Thu Jan 04, 2018 3:17 pm
by geefox
so, we ordered one HP 260 G2 and one NEO Z83-4 for testing purposes.
I will give you feedback, if one or both are working :D
If both are not working, I think we will send you the hardware for further investigations
Posted: Thu Jan 11, 2018 10:48 am
Please, try 5.6.24. Perhaps, something changed in newer kernel.
Posted: Tue Jan 16, 2018 11:28 am
by geefox
hi, tried the new version, but same problem - i've attached you the logfile
Posted: Tue Jan 16, 2018 12:24 pm
by geefox
on the Minix device (http://minix.com.hk/en/products/neo-z83-4) we have a similar problem - when i run only the determine config below, the outputs are HDMI1 and DP2
video=intel(u)
display=1024x768
so i edited the config file to
video=intel(u)
M2_display=1024x768, DP2
but the second monitor connected over DP2 stays black.
I've attached you both logfiles, first for determining the proper ports, and second one with the final config
Posted: Tue Jan 16, 2018 1:49 pm
by geefox
and the same problem also for the HP 260 G2 - ive tried it with 5.6.24 and 5.6.23
the determine config listed the HDMI1 and DP1 port - so i used the following config:
intel=video(u)
but the second monitor stays black
Posted: Tue Jan 16, 2018 5:25 pm
What about "video=i915(f)" ?
