WTWare on Nvidia ION VGA chipset
lmicalle
Post by lmicalle »
Hi there,
I am trying to get WTWare running on a Foxconn Netbox - http://www.foxconnchannel.com/Product/B ... index.html - which has an NVidia ION chipset for VGA (PCI vendor code 10de:087d).
I can currently get the software running with the following:
resolution = 1024x768
bpp = 32
refresh = 60
video = vesa(X)
but I only see 256 colour (8 bit) quality from the Windows RDP sessions. If I change bpp to 24, I get no display.
I have tried nvidiafb(F), nv(X), NV3(S), NV3(T) and none of these work. VESA(S) and VESA(T) also do not work.
If I can get this working in 24 bit colour then I may be purchasing some licenses.
regards
Lawrence
lmicalle
Re: WTWare on Nvidia ION VGA chipset
Post by lmicalle »
actually... 24 bit does not work - no display, but 32bit shows the test pattern with no problems, it's just RDP that does not give me full colour.
