Pi4 Dual Screen -> no Sleep
Adem
Post by Adem »
Hi, i'm using wtware in a rpi4, i set already sleep=10 but after 10 mins only the screen goes black, they are new monitors. i also tried standby.
what can i do?
Re: Pi4 Dual Screen -> no Sleep
Install new wtware version and make a log with error.
https://wtware.com/logs.html
Adem
Post by Adem »
here my log, i have already latest version
WTware v.5.8.72/RPi
WTware 5.8.72/RPi supervisor.
[        KERNEL] [    0.000000] Linux version 4.19.80-v7l (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #9 SMP Wed Oct 23 11:42:47 EDT 2019
[        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[        KERNEL] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[        KERNEL] [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[        KERNEL] [    0.000000] cma: Reserved 64 MiB at 0x0000000037400000
[        KERNEL] [    0.000000] On node 0 totalpages: 1012736
[        KERNEL] [    0.000000]   DMA zone: 1536 pages used for memmap
[        KERNEL] [    0.000000]   DMA zone: 0 pages reserved
[        KERNEL] [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[        KERNEL] [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
[        KERNEL] [    0.000000] random: get_random_bytes called from 0xc0a009e0 with crng_init=0
[        KERNEL] [    0.000000] percpu: Embedded 15 pages/cpu s29132 r8192 d24116 u61440
[        KERNEL] [    0.000000] pcpu-alloc: s29132 r8192 d24116 u61440 alloc=15*4096
[        KERNEL] [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011200
[        KERNEL] [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:1B:99:C2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 quiet wtboot=mmc
[        KERNEL] [    0.000000] Memory: 3937688K/4050944K available (6144K kernel code, 148K rwdata, 664K rodata, 6144K init, 372K bss, 47720K reserved, 65536K cma-reserved, 3198976K highmem)
[        KERNEL] [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[        KERNEL] [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[        KERNEL] [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[        KERNEL] [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[        KERNEL] [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (8160 kB)
[        KERNEL] [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (6144 kB)
[        KERNEL] [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 149 kB)
[        KERNEL] [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 373 kB)
[        KERNEL] [    0.000000] rcu: Hierarchical RCU implementation.
[        KERNEL] [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[        KERNEL] [    0.000000] GIC: Using split EOI/Deactivate mode
[        KERNEL] [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[        KERNEL] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[        KERNEL] [    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[        KERNEL] [    0.000016] Switching to timer-based delay loop, resolution 18ns
[        KERNEL] [    0.000191] Console: colour dummy device 80x30
[        KERNEL] [    0.000209] console [tty0] enabled
[        KERNEL] [    0.000242] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[        KERNEL] [    0.000258] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000383] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000399] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000902] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001206] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001596] Setting up static identity map for 0x200000 - 0x20003c
[        KERNEL] [    0.001693] rcu: Hierarchical SRCU implementation.
[        KERNEL] [    0.002195] smp: Bringing up secondary CPUs ...
[        KERNEL] [    0.002782] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003450] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004094] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004180] smp: Brought up 1 node, 4 CPUs
[        KERNEL] [    0.004189] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[        KERNEL] [    0.004196] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004202] CPU: Virtualization extensions available.
[        KERNEL] [    0.004669] devtmpfs: initialized
[        KERNEL] [    0.012920] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[        KERNEL] [    0.013215] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.013231] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.014753] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.015686] NET: Registered protocol family 16
[        KERNEL] [    0.017790] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.021690] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[        KERNEL] [    0.059248] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[        KERNEL] [    0.061459] vgaarb: loaded
[        KERNEL] [    0.061924] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.062021] usbcore: registered new interface driver hub
[        KERNEL] [    0.062104] usbcore: registered new device driver usb
[        KERNEL] [    0.080059] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-10-21 16:47, variant start
[        KERNEL] [    0.090056] raspberrypi-firmware soc:firmware: Firmware hash is 8c7c951122d2cae572e891f04ddf287078ff2f11
[        KERNEL] [    0.101330] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.110793] NET: Registered protocol family 2
[        KERNEL] [    0.111310] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[        KERNEL] [    0.111328] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.111382] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.111444] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.111552] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.111578] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.111707] NET: Registered protocol family 1
[        KERNEL] [    0.111732] PCI: CLS 0 bytes, default 64
[        KERNEL] [    1.829142] Initialise system trusted keyrings
[        KERNEL] [    1.829236] workingset: timestamp_bits=30 max_order=20 bucket_order=0
[        KERNEL] [    1.894515] Key type asymmetric registered
[        KERNEL] [    1.894527] Asymmetric key parser 'x509' registered
[        KERNEL] [    1.894606] bounce: pool size: 64 pages
[        KERNEL] [    1.894687] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    1.894697] io scheduler noop registered
[        KERNEL] [    1.894846] io scheduler cfq registered (default)
[        KERNEL] [    1.943204] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[        KERNEL] [    1.943223] brcm-pcie fd500000.pcie: could not get clock
[        KERNEL] [    1.943268] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[        KERNEL] [    1.943293] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
[        KERNEL] [    2.001349] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[        KERNEL] [    2.001635] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[        KERNEL] [    2.001649] pci_bus 0000:00: root bus resource [bus 00-01]
[        KERNEL] [    2.001664] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[        KERNEL] [    2.001704] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[        KERNEL] [    2.001791] pci 0000:00:00.0: PME# supported from D0 D3hot
[        KERNEL] [    2.004713] PCI: bus0: Fast back to back transfers disabled
[        KERNEL] [    2.004731] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[        KERNEL] [    2.004951] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[        KERNEL] [    2.004999] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[        KERNEL] [    2.005124] pci 0000:01:00.0: PME# supported from D0 D3cold
[        KERNEL] [    2.007974] PCI: bus1: Fast back to back transfers disabled
[        KERNEL] [    2.007991] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[        KERNEL] [    2.008029] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[        KERNEL] [    2.008046] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[        KERNEL] [    2.008068] pci 0000:00:00.0: PCI bridge to [bus 01]
[        KERNEL] [    2.008080] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[        KERNEL] [    2.008258] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[        KERNEL] [    2.008475] pcieport 0000:00:00.0: Signaling PME with IRQ 53
[        KERNEL] [    2.008727] pcieport 0000:00:00.0: AER enabled with IRQ 53
[        KERNEL] [    2.008966] pci 0000:01:00.0: enabling device (0140 -> 0142)
[        KERNEL] [    2.009492] bcm2708_fb soc:fb: FB found 2 display(s)
[        KERNEL] [    2.033155] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    2.039280] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
[        KERNEL] [    2.056076] bcm2708_fb soc:fb: Registered framebuffer for display 1, size 1920x1080
[        KERNEL] [    2.057932] iproc-rng200 fe104000.rng: hwrng registered
[        KERNEL] [    2.058133] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.058977] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.059768] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[        KERNEL] [    2.060952] zram: Added device: zram0
[        KERNEL] [    2.065895] libphy: Fixed MDIO Bus: probed
[        KERNEL] [    2.066228] xhci_hcd 0000:01:00.0: xHCI Host Controller
[        KERNEL] [    2.066265] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.120334] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[        KERNEL] [    2.120510] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
[        KERNEL] [    2.120719] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[        KERNEL] [    2.120731] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.120741] usb usb1: Product: xHCI Host Controller
[        KERNEL] [    2.120750] usb usb1: Manufacturer: Linux 4.19.80-v7l xhci-hcd
[        KERNEL] [    2.120758] usb usb1: SerialNumber: 0000:01:00.0
[        KERNEL] [    2.121246] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.121322] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.121721] xhci_hcd 0000:01:00.0: xHCI Host Controller
[        KERNEL] [    2.121748] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[        KERNEL] [    2.121780] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[        KERNEL] [    2.122044] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[        KERNEL] [    2.122057] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.122066] usb usb2: Product: xHCI Host Controller
[        KERNEL] [    2.122075] usb usb2: Manufacturer: Linux 4.19.80-v7l xhci-hcd
[        KERNEL] [    2.122084] usb usb2: SerialNumber: 0000:01:00.0
[        KERNEL] [    2.122620] hub 2-0:1.0: USB hub found
[        KERNEL] [    2.122658] hub 2-0:1.0: 4 ports detected
[        KERNEL] [    2.123772] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.149336] dwc_otg fe980000.usb: base=(ptrval)
[        KERNEL] [    2.349546] Core Release: 2.80a
[        KERNEL] [    2.349556] Setting default values for core params
[        KERNEL] [    2.349578] Finished setting default values for core params
[        KERNEL] [    2.549898] Using Buffer DMA mode
[        KERNEL] [    2.549907] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.549914] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.549924] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.549957] Dedicated Tx FIFOs mode
[        KERNEL] [    2.550532] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = f3ec3000 dma = 0x00000000f7544000 len=9024
[        KERNEL] [    2.550559] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.550559] Non-periodic Split Transactions
[        KERNEL] [    2.550559] Periodic Split Transactions
[        KERNEL] [    2.550559] High-Speed Isochronous Endpoints
[        KERNEL] [    2.550559] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.550568] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.550624] WARN::hcd_init_fiq:457: FIQ on core 1
[        KERNEL] [    2.550639] WARN::hcd_init_fiq:458: FIQ ASM at c04fb97c length 36
[        KERNEL] [    2.550654] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
[        KERNEL] [    2.550690] dwc_otg fe980000.usb: DWC OTG Controller
[        KERNEL] [    2.550721] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[        KERNEL] [    2.550750] dwc_otg fe980000.usb: irq 37, io mem 0x00000000
[        KERNEL] [    2.550801] Init: Port Power? op_state=1
[        KERNEL] [    2.550808] Init: Power Port (0)
[        KERNEL] [    2.550969] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[        KERNEL] [    2.550981] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.550990] usb usb3: Product: DWC OTG Controller
[        KERNEL] [    2.550999] usb usb3: Manufacturer: Linux 4.19.80-v7l dwc_otg_hcd
[        KERNEL] [    2.551009] usb usb3: SerialNumber: fe980000.usb
[        KERNEL] [    2.551547] hub 3-0:1.0: USB hub found
[        KERNEL] [    2.551582] hub 3-0:1.0: 1 port detected
[        KERNEL] [    2.552180] dwc_otg: FIQ enabled
[        KERNEL] [    2.552187] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.552193] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.552206] Module dwc_common_port init
[        KERNEL] [    2.552619] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.553454] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.553718] bcm2835-cpufreq: min=600000 max=1500000
[        KERNEL] [    2.554319] sdhci: Secure Digital Host Controller Interface driver
[        KERNEL] [    2.554327] sdhci: Copyright(c) Pierre Ossman
[        KERNEL] [    2.554784] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[        KERNEL] [    2.555135] sdhci-pltfm: SDHCI platform and OF driver helper
[        KERNEL] [    2.555792] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.556194] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.556198] usbhid: USB HID core driver
[        KERNEL] [    2.556817] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[        KERNEL] [    2.558062] [vc_sm_connected_init]: start
[        KERNEL] [    2.567623] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.568091] NET: Registered protocol family 17
[        KERNEL] [    2.568188] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.568416] Loading compiled-in X.509 certificates
[        KERNEL] [    2.571316] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[        KERNEL] [    2.572991] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[        KERNEL] [    2.573320] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.573325] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[        KERNEL] [    2.599902] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[        KERNEL] [    2.618711] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    2.620248] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    2.622082] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    2.624841] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    2.626374] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    2.631325] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[        KERNEL] [    2.631526] of_cfs_init
[        KERNEL] [    2.631612] of_cfs_init: OK
[        KERNEL] [    2.655635] Freeing unused kernel memory: 6144K
[        KERNEL] [    2.707311] Run /init as init process
[        KERNEL] [    2.709387] random: fast init done
[        KERNEL] [    2.721314] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[        KERNEL] [    2.753489] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    2.764516] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[        KERNEL] [    2.764874] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[        KERNEL] [    2.766923]  mmcblk0: p1
[       hotplug] [    2.767281] Block device 179:0. No action.
[       hotplug] [    2.768377] Block device 179:1. No action.
[        KERNEL] [    2.912856] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[        KERNEL] [    2.912870] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[        KERNEL] [    2.912880] usb 1-1: Product: USB2.0 Hub
[        KERNEL] [    2.914691] hub 1-1:1.0: USB hub found
[        KERNEL] [    2.914907] hub 1-1:1.0: 4 ports detected
[       hotplug] [    2.980703] Block device 254:0. No action.
[          pfac] [    3.016304] Run /sbin/initrd.
[          pfac] [    3.016449] Ok, PID 754.
[        initrd] [    3.021572] WTware 5.8.72/RPi shell.
[        initrd] [    3.021944] Load font 'ter-c32b.psf', console 120x33.
[        initrd] [    3.039339] HDD/MMC/SD boot.
[        KERNEL] [    3.251321] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[        KERNEL] [    3.391866] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
[        KERNEL] [    3.391879] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    3.391889] usb 1-1.3: Product: USB Receiver
[        KERNEL] [    3.391899] usb 1-1.3: Manufacturer: Logitech
[        KERNEL] [    3.416827] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input2
[        KERNEL] [    3.576003] input: Logitech Anywhere MX as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:1017.0004/input/input0
[        KERNEL] [    3.576318] logitech-hidpp-device 0003:046D:1017.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech Anywhere MX] on usb-0000:01:00.0-1.3:1
[        KERNEL] [    3.661311] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
[        KERNEL] [    3.801805] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
[        KERNEL] [    3.801817] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    3.801828] usb 1-1.4: Product: USB Receiver
[        KERNEL] [    3.801837] usb 1-1.4: Manufacturer: Logitech
[        KERNEL] [    3.828026] logitech-djreceiver 0003:046D:C52B.0007: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.4/input2
[        KERNEL] [    3.976594] input: Logitech K750 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0007/0003:046D:4002.0008/input/input1
[        KERNEL] [    3.977529] logitech-hidpp-device 0003:046D:4002.0008: input,hidraw3: USB HID v1.11 Keyboard [Logitech K750] on usb-0000:01:00.0-1.4:1
[        initrd] [    4.211688] Success: /dev/mmcblk0p1 mounted to /bootmedia.
| # https://www.raspberrypi.org/documentation/configuration/config-txt/README.md
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| [pi4]
| max_framebuffers=2
| [all]
| #hdmi_group=2
| #hdmi_mode=58
| # 800x600:   hdmi_mode=9
| # 1024x768:  hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768:  hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900:  hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768:  hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| # https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
| [HDMI:0]
| hdmi_group=2
| hdmi_mode=82
| [HDMI:1]
| hdmi_group=2
| hdmi_mode=82
| # hdmi_group=2
| # hdmi_mode=82
[        initrd] [    4.243141] Do not cache package files.
[        initrd] [    4.243246] WTpassword present: 4e3689473178731681d33738ff1d4057.
[        initrd] [    4.282612] USB: 046d:c52b Logitech, Inc. Unifying Receiver.
[        initrd] [    4.282665] USB: 2109:3431 VIA Labs, Inc. Hub.
| clientIP=*
| config=local
| netmedia=ethernet
| setupPassword=4e3689473178731681d33738ff1d4057
[        initrd] [    6.153809] Load Ethernet drivers.
[        initrd] [    6.153901] modprobe genet.
[        KERNEL] [    6.163173] bcmgenet fd580000.genet: failed to get enet clock
[        KERNEL] [    6.163190] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[        KERNEL] [    6.163212] bcmgenet fd580000.genet: failed to get enet-wol clock
[        KERNEL] [    6.163228] bcmgenet fd580000.genet: failed to get enet-eee clock
[        KERNEL] [    6.163248] bcmgenet: Skipping UMAC reset
[        KERNEL] [    6.163471] unimac-mdio unimac-mdio.-19: DMA mask not set
[        KERNEL] [    6.181296] libphy: bcmgenet MII bus: probed
[        KERNEL] [    6.224438] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[        KERNEL] [    6.226501] bcmgenet: Skipping UMAC reset
[        KERNEL] [    6.321620] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[        KERNEL] [    7.351412] bcmgenet fd580000.genet eth0: Link is Down
[        KERNEL] [   11.511459] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[        initrd] [   11.529172] WTpassword present: 4e3689473178731681d33738ff1d4057.
[        initrd] [   12.730135] dhcp: 422 bytes from 192.168.1.1.
[        initrd] [   12.730236] 00000000:000001920000000000110000C0A80101C0A80125004300440192000002010600  ..................%.C.D........
[        initrd] [   12.730326] 00000020:67458B6B0000000000000000C0A80125C0A8010100000000DCA6321B99C20000  gE.k...........%..........2....
[        initrd] [   12.730414] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.730499] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.730583] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.730668] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.730754] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.730839] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.730923] 00000100:000000000000000063825363350102E706352E382E3732F1402C882B0F409CE8  ........c.Sc5....5.8.72.@,.+.@..
[        initrd] [   12.731008] 00000120:4F1966B1AA8280D6AB77955A7A0C3A06E2564D297A75506FE96AE23B430CA8CC  Of......w.Zz.:..VM)zuPo.j.;C...
[        initrd] [   12.731093] 00000140:16786F4A1B439C39229E43E9F0245CB9888A28DE89BAF652010104FFFFFF0003  xoJC.9".C..$\...(....R........
[        initrd] [   12.731178] 00000160:04C0A801010604C0A801010F04686F6D657D2600000DE9210406303031334338  .............home}&....!..0013C8
[        initrd] [   12.731263] 00000180:050D333431303249303037363837360608505342343231324E3604C0A8010133  ..34102I0076876..PSB4212N6.....3
[        initrd] [   12.731348] 000001a0:0400015180FF                                                      ...Q..
[        initrd] [   13.910185] dhcp: 422 bytes from 192.168.1.1.
[        initrd] [   13.910283] 00000000:000001920000000000110000C0A80101C0A80125004300440192000002010600  ..................%.C.D........
[        initrd] [   13.910369] 00000020:67458B6B0000000000000000C0A80125C0A8010100000000DCA6321B99C20000  gE.k...........%..........2....
[        initrd] [   13.910455] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.910539] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.910624] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.910708] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.910793] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.910878] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.910962] 00000100:000000000000000063825363350105E706352E382E37323604C0A80101F140CD  ........c.Sc5....5.8.726......@.
[        initrd] [   13.911047] 00000120:28EBCE3714181FB7DEE24E101D71D813C6931A48952CEFE683666C3181CE7764  (..7...Nq...H.,...fl1..wd
[        initrd] [   13.911131] 00000140:FCDA5B1D60FD2865FED22AB423BE571AC70152C04BEE3ACFE63925BA11A40101  ..[`.(e..*.#.W..R.K.:..9%....
[        initrd] [   13.911232] 00000160:04FFFFFF000304C0A801010604C0A801010F04686F6D657D2600000DE9210406  ...................home}&....!..
[        initrd] [   13.911318] 00000180:303031334338050D333431303249303037363837360608505342343231324E33  0013C8..34102I0076876..PSB4212N3
[        initrd] [   13.911402] 000001a0:0400015180FF                                                      ...Q..
[        initrd] [   13.960089] [DHCP] DHCP server address 192.168.1.1.
[        initrd] [   13.960180] [DHCP] IP 192.168.1.37 mask 255.255.255.0.
[        initrd] [   13.960262] [DHCP] Default gateway 192.168.1.1.
[        initrd] [   13.960345] [DHCP] DNS 192.168.1.1.
[        initrd] [   13.960427] [DHCP] Domain home.
[        initrd] [   13.960509] [DHCP] TFTP from siaddr 192.168.1.1.
[        initrd] [   13.960591] [DHCP] TFTP 192.168.1.1.
[        initrd] [   13.960673] [DHCP] No boot file from DHCP.
[        initrd] [   13.960755] [DHCP] TFTP binary "", configs prefix "", using "/" slash.
[          pfac] [   13.962059] Run /sbin/httpd.
[        initrd] [   13.962131] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   13.962260] Ok, PID 826.
[        initrd] [   13.962316] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[        initrd] [   13.964730] Common local disk config:
| server=192.168.1.35
| sleep=1
| sound=on
| keyboard=de-ch
| user=SM-PC-01:L1983iridon
| disk=usb
| server=192.168.1.35
| sleep=1
| sound=on
| keyboard=de-ch
| disk=usb
[        initrd] [   13.966244] Hostname: "wtwDCA6321B99C2".
[         httpd] [   13.970721] Internal HTTP Server, WTware 5.8.72/RPi
[        initrd] [   14.220253] [NTP] 42 DHCP option is not set.
[         httpd] [   14.224954] Reread settings.
[        initrd] [   14.225064] Unpack /bootmedia/packages/pi2-f.
[         httpd] [   14.225185] Everyone can control terminal by HTTP.
[        KERNEL] [   14.340487] random: crng init done
[            gm] [   14.341803] WTware 5.8.72/RPi session manager.
[            gm] [   14.342300] Add keyboard event1: Logitech K750.
[            gm] [   14.342338] EV_REL flag found. Add mouse event0: Logitech Anywhere MX.
[            gm] [   14.342388] Display mode: 1920x1080, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   14.342427] M2 mode: 1920x1080, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   14.614865] Framebuffer device found.
[            gm] [   14.614911] LINELENBYTES 3840
[            gm] [   14.614947] VLEN 4147200
[            gm] [   14.614982] Second framebuffer device found.
[            gm] [   14.615018] LINELENBYTES 3840
[            gm] [   14.615052] VLEN 4147200
[            gm] [   14.615996] Use /lib/ui16.so.
[            gm] [   14.646628] Unpack /bootmedia/packages/pi2-alsa.
[            gm] [   14.787730] modprobe snd-bcm2835.
[        KERNEL] [   14.794940] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[            gm] [   14.796643] modprobe snd-usb-audio.
[        KERNEL] [   14.797308] bcm2835_audio soc:audio: card created with 8 channels
|   0: [ 0]   : control
|  18: [ 0- 2]: digital audio playback
|  33:        : timer
[        KERNEL] [   14.806110] usbcore: registered new interface driver snd-usb-audio
[            gm] [   14.805708] /dev/snd//controlC0 character device.
[            gm] [   14.805769] /dev/snd//pcmC0D2p character device.
[          pfac] [   14.805809] Run /sbin/rdpsnd sndvol 100 100 50.
[            gm] [   14.805829] /dev/snd//pcmC0D1p character device.
[            gm] [   14.805865] /dev/snd//pcmC0D0p character device.
[            gm] [   14.805901] /dev/snd//timer character device.
[          pfac] [   14.805945] Ok, PID 848.
[            gm] [   14.805975] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[          pfac] [   14.806027] Run /sbin/rdpsnd 1 0 100 0 -1.
[            gm] [   14.806054] Run sound daemon.
[          pfac] [   14.806091] Ok, PID 849.
[            gm] [   14.806114] Run '/sbin/rdpsnd 1 0 100 0 -1', log '', env '', pid ''.
[            gm] [   14.806149] Load ISO 9660 and UDF CDROM filesystem drivers.
[            gm] [   14.806186] modprobe udf.
[        rdpsnd] [   14.808722] RDP Sound Redirector, WTware 5.8.72/RPi.
[        sndvol] [   14.810450] Card 'ALSA'/'bcm2835 ALSA'.
[        sndvol] [   14.810507] Mixer name: 'Broadcom Mixer'.
[        sndvol] [   14.810547] Components: ''.
[        sndvol] [   14.810586] Controls: 5.
[        sndvol] [   14.810624] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   14.810662] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   14.810700] ALSA: control 'PCM Playback Route'.
[        sndvol] [   14.810738] ALSA: control 'IEC958 Playback Default'.
[        sndvol] [   14.810776] ALSA: control 'IEC958 Playback Con Mask'.
[          pfac] [   14.811311] Process pid 848 terminated, status 00000000.
[            gm] [   14.814489] modprobe isofs.
[            gm] [   14.818442] Load usb storage driver.
[            gm] [   14.818505] modprobe scsi_mod.
[            gm] [   14.824270] modprobe usb-storage.
[        KERNEL] [   14.824785] SCSI subsystem initialized
[            gm] [   14.829490] modprobe uas.
[        KERNEL] [   14.830336] usbcore: registered new interface driver usb-storage
[            gm] [   14.833583] modprobe sd_mod.
[        KERNEL] [   14.834447] usbcore: registered new interface driver uas
[            gm] [   14.837746] Load EXFAT filesystem driver.
[            gm] [   14.837811] modprobe fuse.
[            gm] [   14.843060] modprobe exfat.
[        KERNEL] [   14.843674] fuse init (API version 7.27)
[        KERNEL] [   14.848703] exFAT: Version 1.2.9
[            gm] [   14.945343] Run '/sbin/resolver 0xb57ed8 dns [192.168.1.35]', log '', env '', pid ''.
[          pfac] [   14.945423] Run /sbin/resolver 0xb57ed8 dns [192.168.1.35].
[            gm] [   14.945446] Nobody can control terminal by VNC.
[          pfac] [   14.945598] Ok, PID 887.
[          pfac] [   14.949007] Process pid 887 terminated, status 00000000.
[            gm] [   14.949532] 192.168.1.35 => 192.168.1.35.
[            gm] [   14.959749] Free ram before fork terminal client /sbin/rdpclient (session 1): 3933848 Kb.
[          pfac] [   14.959810] Run /sbin/rdpclient 1.
[            gm] [   14.959829] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   14.959965] Ok, PID 888.
[ rdpclient 888] [   14.965228] RDP Terminal Client, WTware 5.8.72/RPi, pipe 1, pid 888.
[ rdpclient 888] [   14.965743] Use /lib/ui16.so.
[ rdpclient 888] [   14.966854] Redirect sound.
[ rdpclient 888] [   14.967555] Make RDP session with 192.168.1.35, port 3389.
[ rdpclient 888] [   14.967738]  Username: "SM-PC-01".
[ rdpclient 888] [   14.967817]  Password: present.
[ rdpclient 888] [   14.967884]  No PIN.
[ rdpclient 888] [   14.967946]  No domain.
[ rdpclient 888] [   14.968006]  No shell.
[ rdpclient 888] [   14.968064]  No directory.
[ rdpclient 888] [   14.968128]  Window: 1856x1080@16.
[ rdpclient 888] [   14.968198]  Second monitor: [1856:0..3711:1079].
[ rdpclient 888] [   14.968267]  PFlags 0x0000002F.
[ rdpclient 888] [   14.968332]  Keyboard 00000807:00000000.
[ rdpclient 888] [   14.968394]  My hostname "wtwDCA6321B99C2".
[ rdpclient 888] [   14.968457] TCP: connecting to 192.168.1.35:3389.
[ rdpclient 888] [   14.970215] TCP: connection with 192.168.1.35:3389 established.
[ rdpclient 888] [   14.970294] Turn keepalive on.
[ rdpclient 888] [   14.970877] Free ram after buffers allocation: 3933344 KB.
[ rdpclient 888] [   14.979319] Reconnect with NLA enabled.
[ rdpclient 888] [   14.979407] TCP: reconnecting to 192.168.1.35:3389.
[ rdpclient 888] [   14.979843] TCP: connection with 192.168.1.35:3389 established.
[ rdpclient 888] [   14.979899] Turn keepalive on.
[ rdpclient 888] [   14.985993] Server supports GFX Pipeline.
[ rdpclient 888] [   14.986057] NLA.
[ rdpclient 888] [   14.986110] SSL/TLS.
[ rdpclient 888] [   15.011964] Enable font smoothing and Desktop Composition.
[ rdpclient 888] [   15.120133] GFX codec.
[ rdpclient 888] [   15.366771] SessionId 0x00000001: SM-PC-01\SM-PC-01.
[ rdpclient 888] [   17.250380] Run 4 tile threads.
[        KERNEL] [   38.845120] logitech-hidpp-device 0003:046D:1017.0004: HID++ 1.0 device connected.
[        KERNEL] [   39.453354] logitech-hidpp-device 0003:046D:4002.0008: HID++ 2.0 device connected.
[ rdpclient 888] [  122.620933] errorInfo 0x0000000c.
[ rdpclient 888] [  122.621080] ERRINFO_LOGOFF_BY_USER: The disconnection was initiated by the user logging off his or her session on the server.
[ rdpclient 888] [  122.796474] Receive Disconnect Provider Ultimatum.
[            gm] [  122.796594] TSClient (sessionId 1, pid 888) gracefully end.
[        rdpsnd] [  122.812622] Link lost.
[          pfac] [  122.812770] Process pid 888 terminated, status 00000009.
[            gm] [  122.817170] Run '/sbin/resolver 0xb57ed8 dns [192.168.1.35]', log '', env '', pid ''.
[          pfac] [  122.817216] Run /sbin/resolver 0xb57ed8 dns [192.168.1.35].
[          pfac] [  122.817491] Ok, PID 904.
[          pfac] [  122.820807] Process pid 904 terminated, status 00000000.
[            gm] [  122.821379] 192.168.1.35 => 192.168.1.35.
[            gm] [  122.831637] Free ram before fork terminal client /sbin/rdpclient (session 2): 3933768 Kb.
[          pfac] [  122.831712] Run /sbin/rdpclient 2.
[            gm] [  122.831732] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  122.831859] Ok, PID 905.
[ rdpclient 905] [  122.836885] RDP Terminal Client, WTware 5.8.72/RPi, pipe 2, pid 905.
[ rdpclient 905] [  122.837229] Use /lib/ui16.so.
[ rdpclient 905] [  122.838049] Redirect sound.
[ rdpclient 905] [  122.838290] Make RDP session with 192.168.1.35, port 3389.
[ rdpclient 905] [  122.838386]  Username: "SM-PC-01".
[ rdpclient 905] [  122.838440]  Password: present.
[ rdpclient 905] [  122.838484]  No PIN.
[ rdpclient 905] [  122.838526]  No domain.
[ rdpclient 905] [  122.838570]  No shell.
[ rdpclient 905] [  122.838614]  No directory.
[ rdpclient 905] [  122.838657]  Window: 1856x1080@16.
[ rdpclient 905] [  122.838698]  Second monitor: [1856:0..3711:1079].
[ rdpclient 905] [  122.838741]  PFlags 0x0000002F.
[ rdpclient 905] [  122.838784]  Keyboard 00000807:00000000.
[ rdpclient 905] [  122.838830]  My hostname "wtwDCA6321B99C2".
[ rdpclient 905] [  122.838872] TCP: connecting to 192.168.1.35:3389.
[ rdpclient 905] [  122.839538] TCP: connection with 192.168.1.35:3389 established.
[ rdpclient 905] [  122.839663] Turn keepalive on.
[ rdpclient 905] [  122.840830] Free ram after buffers allocation: 3932852 KB.
[ rdpclient 905] [  122.848985] Reconnect with NLA enabled.
[ rdpclient 905] [  122.849037] TCP: reconnecting to 192.168.1.35:3389.
[ rdpclient 905] [  122.849715] TCP: connection with 192.168.1.35:3389 established.
[ rdpclient 905] [  122.849755] Turn keepalive on.
[ rdpclient 905] [  122.858144] Server supports GFX Pipeline.
[ rdpclient 905] [  122.858196] NLA.
[ rdpclient 905] [  122.858243] SSL/TLS.
[ rdpclient 905] [  122.866680] SSL_ERROR_SYSCALL
[ rdpclient 905] [  122.866811]              rdpclient-tcp.cpp (  496): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 905] [  122.866918]              rdpclient-tcp.cpp (  539): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 905] [  122.867021] NLA connection failed.
Turn off NLA on server:
https://wtware.com/win/nla.html
[            gm] [  122.867135] Final message: NLA connection failed.
[        rdpsnd] [  122.867909] Link lost.
[          pfac] [  122.868105] Process pid 905 terminated, status 00000009.
[            gm] [  126.834770] Run '/sbin/resolver 0xb57ed8 dns [192.168.1.35]', log '', env '', pid ''.
[          pfac] [  126.834937] Run /sbin/resolver 0xb57ed8 dns [192.168.1.35].
[          pfac] [  126.835275] Ok, PID 906.
[            gm] [  126.839448] 192.168.1.35 => 192.168.1.35.
[          pfac] [  126.839508] Process pid 906 terminated, status 00000000.
[            gm] [  126.849645] Free ram before fork terminal client /sbin/rdpclient (session 3): 3933760 Kb.
[          pfac] [  126.849697] Run /sbin/rdpclient 3.
[            gm] [  126.849716] Run '/sbin/rdpclient 3', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  126.849823] Ok, PID 907.
[ rdpclient 907] [  126.854945] RDP Terminal Client, WTware 5.8.72/RPi, pipe 3, pid 907.
[ rdpclient 907] [  126.855278] Use /lib/ui16.so.
[ rdpclient 907] [  126.856088] Redirect sound.
[ rdpclient 907] [  126.856346] Make RDP session with 192.168.1.35, port 3389.
[ rdpclient 907] [  126.856438]  Username: "SM-PC-01".
[ rdpclient 907] [  126.856493]  Password: present.
[ rdpclient 907] [  126.856540]  No PIN.
[ rdpclient 907] [  126.856584]  No domain.
[ rdpclient 907] [  126.856628]  No shell.
[ rdpclient 907] [  126.856671]  No directory.
[ rdpclient 907] [  126.856715]  Window: 1856x1080@16.
[ rdpclient 907] [  126.856761]  Second monitor: [1856:0..3711:1079].
[ rdpclient 907] [  126.856804]  PFlags 0x0000002F.
[ rdpclient 907] [  126.856845]  Keyboard 00000807:00000000.
[ rdpclient 907] [  126.856889]  My hostname "wtwDCA6321B99C2".
[ rdpclient 907] [  126.856931] TCP: connecting to 192.168.1.35:3389.
[ rdpclient 907] [  156.886720] select () timed out.
[ rdpclient 907] [  156.886856]              rdpclient-tcp.cpp (  260): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 907] [  156.886961] Server 192.168.1.35, port 3389: connection rejected.
Make sure that terminal service works on this server.
Try to connect using mstsc.exe.
[            gm] [  156.887164] Final message: Server 192.168.1.35, port 3389: connection rejected.
[        rdpsnd] [  156.887668] Link lost.
[          pfac] [  156.887854] Process pid 907 terminated, status 00000009.
[            gm] [  221.312041] Run '/sbin/resolver 0xb57ed8 dns [192.168.1.35]', log '', env '', pid ''.
[          pfac] [  221.312153] Run /sbin/resolver 0xb57ed8 dns [192.168.1.35].
[          pfac] [  221.312454] Ok, PID 910.
[            gm] [  221.316283] 192.168.1.35 => 192.168.1.35.
[          pfac] [  221.316343] Process pid 910 terminated, status 00000000.
[            gm] [  221.326478] Free ram before fork terminal client /sbin/rdpclient (session 4): 3933728 Kb.
[          pfac] [  221.326532] Run /sbin/rdpclient 4.
[            gm] [  221.326552] Run '/sbin/rdpclient 4', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  221.326659] Ok, PID 911.
[ rdpclient 911] [  221.331813] RDP Terminal Client, WTware 5.8.72/RPi, pipe 4, pid 911.
[ rdpclient 911] [  221.332163] Use /lib/ui16.so.
[ rdpclient 911] [  221.332986] Redirect sound.
[ rdpclient 911] [  221.333222] Make RDP session with 192.168.1.35, port 3389.
[ rdpclient 911] [  221.333313]  Username: "SM-PC-01".
[ rdpclient 911] [  221.333369]  Password: present.
[ rdpclient 911] [  221.333413]  No PIN.
[ rdpclient 911] [  221.333456]  No domain.
[ rdpclient 911] [  221.333500]  No shell.
[ rdpclient 911] [  221.333542]  No directory.
[ rdpclient 911] [  221.333586]  Window: 1856x1080@16.
[ rdpclient 911] [  221.333631]  Second monitor: [1856:0..3711:1079].
[ rdpclient 911] [  221.333674]  PFlags 0x0000002F.
[ rdpclient 911] [  221.333717]  Keyboard 00000807:00000000.
[ rdpclient 911] [  221.333759]  My hostname "wtwDCA6321B99C2".
[ rdpclient 911] [  221.333834] TCP: connecting to 192.168.1.35:3389.
[ rdpclient 911] [  221.335297] TCP: connection with 192.168.1.35:3389 established.
[ rdpclient 911] [  221.335427] Turn keepalive on.
[ rdpclient 911] [  221.336225] Free ram after buffers allocation: 3933728 KB.
[ rdpclient 911] [  221.357389] Reconnect with NLA enabled.
[ rdpclient 911] [  221.357436] TCP: reconnecting to 192.168.1.35:3389.
[ rdpclient 911] [  221.358036] TCP: connection with 192.168.1.35:3389 established.
[ rdpclient 911] [  221.358076] Turn keepalive on.
[ rdpclient 911] [  221.377123] Server supports GFX Pipeline.
[ rdpclient 911] [  221.377258] NLA.
[ rdpclient 911] [  221.377376] SSL/TLS.
[ rdpclient 911] [  221.419177] Enable font smoothing and Desktop Composition.
[ rdpclient 911] [  221.914231] GFX codec.
[ rdpclient 911] [  222.039093] SessionId 0x00000001: SM-PC-01\SM-PC-01.
[ rdpclient 911] [  224.249185] Run 4 tile threads.
[            gm] [  394.352673] Power OFF monitor.
[            gm] [  934.741301] Power OFF monitor.
[ rdpclient 911] [14696.782035] errorInfo 0x00000005.
[ rdpclient 911] [14696.782167] ERRINFO_DISCONNECTED_BY_OTHERCONNECTION: Another user connected to the server, forcing the disconnection of the current connection.
[ rdpclient 911] [14697.055018] Receive Disconnect Provider Ultimatum.
[ rdpclient 911] [14697.055134] Remote session disconnected, for another user
has connected to this session.
[            gm] [14697.055656] Final message: Remote session disconnected, for another user
[          pfac] [14697.077880] Process pid 911 terminated, status 00000009.
[        rdpsnd] [14697.077977] Link lost.
Do these monitors go to sleep if you only connect each of them as a single monitor?
What monitors really do? Turn blank or nothing happends?
In official manual:
https://www.raspberrypi.org/documentati ... t/video.md
On the Raspberry Pi 4, setting hdmi_blanking=1 will not cause the HDMI output to be switched off, since this feature has not yet been implemented.
Adem
Post by Adem »
both screens just go blank, going not standby.
also when i connect just one of the screens.
what can i do?
Wait until Raspberry Pi Foundation implements it.
Adem
Post by Adem »
akatik wrote: Thu Nov 07, 2019 6:16 pm Wait until Raspberry Pi Foundation implements it.
is it now implemented? i have installed 6.0.2
Adem
Post by Adem »
are there any updates?
