Chrome Shares with spaces in share name
Posted: Fri Jul 31, 2020 2:43 pm
by fox-007
Hello Aka,
I wanted to redirect the download directory to the respective user directory on a Windows file server.
Basically, it works very well.
However, our shares have spaces in the share names.
The method with the quotation marks or with \040 .... does not work.
Do you have a solution for this?
Re: Chrome Shares with spaces in share name
Posted: Tue Aug 04, 2020 12:04 am
Posted: Tue Aug 04, 2020 2:29 pm
by fox-007
Thanks Aka,
but unfortunately I couldn't mount the share with this version either.
Here is my entry in the configuration file for the desired share.
chrome_share=\\192.168.168.107\home$\xxxxxxx\Eigene Dateien\Downloads, user xxxxxx@xxxxxx, password xxxxxxx
That does not work.
Here are the messages from the log:
[ rdpdr-scard] [ 13.136828] RDP Smart Card Redirector, WTware 6.0.9/RPi.
[ gm] [ 13.162775] [FILE CACHE] Take 'packages/pi2-scl' from cache.
[ gm] [ 13.162890] modprobe cifs.
[ gm] [ 13.180036] +--- Executing "/sbin/mount.cifs //192.168.168.107/home$\xxxxxx\Eigene\ Dateie /home/chromium/Downloads -o iocharset=utf8,vers=2.1,uid=1007,gid=1007,username=xxxxxxx@xxxxxx,password=xxxxxx
[ KERNEL] [ 13.180681] Key type cifs.idmap registered
[ KERNEL] [ 13.195699] CIFS: Attempting to mount //192.168.168.107/home$\xxxxxx\Eigene Dateie
[ gm] [ 13.209027] +- Errorlevel: 32, output:
[ KERNEL] [ 13.209968] CIFS VFS: cifs_mount failed w/return code = -2
| mount error(2): No such file or directory
| Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
[ gm] [ 13.209275] +------------------------
If I rename the folder and the entry in the configuration file from "Eigene Dateien" to "EigeneDateien" it works wonderfully.
Posted: Sun Aug 23, 2020 12:41 am
It mounts \EigeneDateien, but you ask for \EigeneDateien\Downloads
Please try this:
http://wtware.com/testing/202008221736.zip
Posted: Tue Sep 08, 2020 3:36 pm
by fox-007
Good work.
Paths with spaces such as "...\Eigene Dateien\Downloads" now also work.
Many thanks.
