Page 1 of 2
Wi-Fi roaming (I'm tired)
Posted: Thu Aug 27, 2020 11:14 am
by laesyar
In our warehouse, we have trucks driving around with terminal screens.
Normally they have Windows installed, but since that is labor sensitive because of Windows Updates, we are looking for different options.
We have tried WTware for a week now and it's looking pretty good.
However, there is one thing that is critical for us, which is Wi-Fi roaming and keeping a connection with the Remote Desktop Services server.
WTware is generally roaming fine, but there are multiple occasions per day that the connection is lost and WTware reports "I'm tired".
You have to imagine that these trucks drive past access points very fast, so I don't think it's strange that WTware gets "tired".
I'd like to know if there is anything I can do or try to make the connection more aggressive.
Maybe we could the suppress "I'm tired" message and just keep trying to (re)connect?
Otherwise things like different drivers or different driver settings could also be something that we can try?
Re: Wi-Fi roaming (I'm tired)
Posted: Thu Aug 27, 2020 4:03 pm
We need terminal log to find out what made wtware feel tired:
http://wtware.com/logs.html
Send it to
supprt@wtware.com
Posted: Tue Sep 08, 2020 10:02 am
by laesyar
Since last friday we are trying to get the error again.
Of course, the error never appears when you need it
So when we get the error I will reply it.
Also, I have been looking for roaming configuration with wpa_supplicant.
That could be set up with a simple argument:
"The above example will cause wpa_supplicant to scan every 30 seconds when the signal is weak (below -70), and every 3600 seconds otherwise. bgscan can be specified either in specific network blocks or globally for all networks." - source:
https://wiki.archlinux.org/index.php/wp ... nt#Roaming
I know I can create the wpa_supplicant.conf, but maybe it is cool if this could be configured from WTware Center.
Posted: Tue Sep 08, 2020 11:15 am
by laesyar
Just after my reply, the error appeared!
I have attached the log (anonymized) to this reply.
I also will try the bgscan argument in wpa_supplicant.conf to see if it works good.
Because now WTware will stay connected until the terminal is too far from the access point, resulting in a very low signal level.
eth0 IEEE 802.11 ESSID:"mywifissid"
Mode:Managed Frequency:5.18 GHz Access Point: AA:BB:CC:DD:EE:FF
Bit Rate=28.9 Mb/s Tx-Power=22 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=23/70 Signal level=-87 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:17 Missed beacon:0
Posted: Tue Sep 15, 2020 10:02 am
by laesyar
We have tried the bgscan argument for a couple of days now and it's looking pretty good.
The "I'm tired" message did not appear anymore, but we will test it more.
This is the wpa_supplicant.conf that we currently use:
network={
ssid="myssid"
scan_ssid=1
psk=securepsk
bgscan="simple:15:-70:90"
You can calculate the PSK on
this website if you don't want it to be plain text.
If I understand correctly, bgscan will trigger scanning for a better Wi-Fi signal when the signal goes below -70 dBm.
When it can't find a stronger signal, it will scan every 15 seconds.
When the signal is good, it will scan every 90 seconds to find an even better signal.
It is noticable in the logs too!
[ WPA] [ 2920.637855] eth0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=6000
[ WPA] [ 2924.119504] eth0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-75 noise=9999 txrate=86700
[ WPA] [ 2924.975511] eth0: SME: Trying to authenticate with aa:aa:aa:aa:aa:aa (SSID='myssid' freq=5220 MHz)
[ KERNEL] [ 2924.978211] eth0: disconnect from AP bb:bb:bb:bb:bb:bb for new auth to aa:aa:aa:aa:aa:aa
[ WPA] [ 2925.020308] eth0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-57 noise=9999 txrate=6000
[ WPA] [ 2925.050901] eth0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-54 noise=9999 txrate=6000
[ WPA] [ 2976.046336] eth0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-73 noise=9999 txrate=86700
[ WPA] [ 2979.760017] eth0: SME: Trying to authenticate with bb:bb:bb:bb:bb:bb (SSID='myssid' freq=5200 MHz)
[ KERNEL] [ 2979.762756] eth0: disconnect from AP aa:aa:aa:aa:aa:aa for new auth to bb:bb:bb:bb:bb:bb
Keep in mind that your log will be a lot bigger if you roam with the device all day.
Posted: Wed Sep 16, 2020 4:02 pm
by laesyar
We have multiple models of terminal touch screen.
The log in my previous reply is from a model with an Intel Wi-Fi chipset.
C 02:80 8086:24fd Network controller Network controller Intel Corporation Wireless 8265 / 8275
We have another model with a Broadcom BCM4322 Wi-Fi chipset.
C 02:80 14e4:432b Network controller Network controller Broadcom Inc. and subsidiaries BCM4322 802.11a/b/g/n Wireless LAN Controller
It seems that bgscan does not work correctly with the Broadcom Wi-Fi chipset, as you can see in this line from the log.
[ WPA] [17151.212379] bgscan simple: Failed to enable signal strength monitoring
@akatik do you know if the latest Broadcom driver is in WTware?
Is it possible to test the latest driver?
Edit on 23-9-2020: There are at least two options:
- The latest b43 driver will work good (firmware-b43-installer)
Debian package
Posted: Fri Sep 18, 2020 5:36 pm
by laesyar
I tried wpa_supplicant on debian on the same terminal model with the Broadcom BCM4322 chipset and the latest Broadcom b43 driver.
wpa_supplicant is there able to monitor the signal strength successfully.
In the attached log you can see the wpa_supplicant log from the debian installation.
So I think if the latest Broadcom STA drivers were added in WTware, that would solve the roaming problem for this model.
Posted: Fri Oct 09, 2020 8:36 am
Please, give me wtware log. With wtware log I'll tell which driver is running.
Under UEFI the latest (5+ years old...) Broadcom STA with debian patches should run, from this link:
https://salsa.debian.org/broadcom-sta-t ... adcom-sta/
Under Legacy BIOS there are different variants.
Did you use the same wpa_supplicant.conf for both debian and wtware?
Do you know command line flags passed to wpa_supplicant in Debian?
Posted: Tue Oct 13, 2020 5:07 pm
by laesyar
Thanks, I attached
- log.txt
- (80.06 KiB) Downloaded 2877 times
to this reply.
The unit does not support UEFI, so I can't install the WTware UEFI.
I think this is the command I used on debian (nothing special):
sudo wpa_supplicant -B -c /etc/wpa_supplicant.conf -i wlan0
The b43 driver (firmware-b43-installer) was the driver I used on debian.
Edit: I used the same wpa_supplicant.conf
Posted: Tue Oct 13, 2020 5:31 pm
laesyar wrote: Tue Oct 13, 2020 5:07 pm
Thanks, I attached the log to this reply.
modprobe wl
It's Broadcom STA with debian patches:
firmware-b43-installer download non-free firmwares for b43 driver. Please run in debian:
to find driver really used. lsmod should write b43 or wl.
Posted: Wed Oct 14, 2020 4:32 pm
by laesyar
Ah yes you are correct.
I needed to install debian again for lsmod output and it says that the b43 driver uses a non-free firmware.
Attached you can find the lsmod output.
Posted: Wed Oct 14, 2020 9:17 pm
Please try this build:
http://wtware.com/testing/202010141414.zip
It should use b43 for 14e4:432b.
Posted: Thu Oct 15, 2020 11:11 am
by laesyar
Yes! It works!
Broadcom is detected and B43 is loaded:
[ initrd] [ 11.163418] [WiFi] Do not load wl for 14e4:432b.
[ initrd] [ 11.194666] Found broadcom chip.
[ initrd] [ 11.194777] modprobe b43.
[ KERNEL] [ 11.228370] ssb: Found chip with id 0x4322, rev 0x01 and package 0x0A
[ KERNEL] [ 11.341015] b43-pci-bridge 0000:04:00.0: Sonics Silicon Backplane found on PCI device 0000:04:00.0
[ KERNEL] [ 11.353798] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ KERNEL] [ 11.365358] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ KERNEL] [ 11.378902] b43-phy0: Broadcom 4322 WLAN found (core revision 16)
[ KERNEL] [ 11.420327] b43-phy0: Found PHY: Analog 8, Type 4 (N), Revision 4
[ KERNEL] [ 11.420366] b43-phy0: Found Radio: Manuf 0x17F, ID 0x2056, Revision 3, Version 0
[ KERNEL] [ 11.436583] Broadcom 43xx driver loaded [ Features: PNL ]
[ KERNEL] [ 11.438857] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ initrd] [ 11.438313] modprobe brcmsmac.
[ KERNEL] [ 11.462547] b43 ssb0:0 eth0: renamed from wlan0
[ initrd] [ 11.478561] Failed to disable Wi-Fi Power Management.
It monitors signal strength correctly now:
[ WPA] [ 23.227948] eth0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-42 noise=0 txrate=18000
I will have someone test this WTware version with the B43 driver to confirm if it works stable for a couple of days and I will let you know the results.
Posted: Thu Oct 15, 2020 3:42 pm
by laesyar
After some testing, it seems that the Wi-Fi connection disconnects every minute or so.
The following happens in the log:
[ WPA] [ 263.881133] l2_packet_send - sendto: No buffer space available
[ KERNEL] [ 263.884444] eth0: deauthenticating from bb:bb:bb:bb:bb:bb by local choice (Reason: 1=UNSPECIFIED)
[ WPA] [ 263.921913] eth0: CTRL-EVENT-DISCONNECTED bssid=bb:bb:bb:bb:bb:bb reason=1 locally_generated=1
[ WPA] [ 263.922015] eth0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
[ WPA] [ 263.922146] eth0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="myssid" auth_failures=1 duration=10 reason=WRONG_KEY
[ WPA] [ 263.922385] nl80211: Failed to open /proc/sys/net/ipv6/conf/eth0/drop_unicast_in_l2_multicast: No such file or directory
[ WPA] [ 263.922581] nl80211: Failed to set IPv6 unicast in multicast filter
The PSK is correct, after a couple of seconds it automatically reconnects, after a minute it disconnects again.
Full log is attached to this reply.
Posted: Thu Oct 15, 2020 4:21 pm
Look ad Debian command output:
It there such line ?
b43-phy0: Loading firmware version 666.2 (2011-02-23 01:15:07)
