VNC Connection refused
lddj90
Post by lddj90 »
Hi
I have got some problems connection to my WTware Raspberry via VNC.
I configured “vnc=on”, but still get the connection refused error.
VNC Server: Raspberry WTware 5.8.54
RealVNC Viewer: Windows 10 Pro
Now I would like to be able to connect from my Host (Windows) to my Raspberry via VNC and then connect from the Raspberry via VPN to the office I work at. (So at home I don’t need a KMV Switch, nor need to change cables).
The firewall is correctly set up and allows connection from Host to Server. On my Raspberry after booting it immediately loads the OpenVPN file and prompts for authentication to connect to the VPN server.
Could it be possible the VNC Server doesn’t start? Or am I missing something? Thanks.
Re: VNC Connection refused
