Linphone not pulling in custom config
Posted: Tue Dec 18, 2018 11:12 pm
by effin_dead_again
All,
I'm trying to get Linphone to pull in a custom config to set some parameters necessary for my SIP server but it doesn't seem to be pulling the file in and setting the settings. The only way I know how to confirm this is to run a command to list a parameter I specifically defined in the linphone config and see that the parameter is undefined according to linphone.
Here's my terminal config line:
SIP=0000:0000@<HOST_REDACTED>, config:linphone.wtc
Here's whats in my linphone.wtc file:
[sip]
media_encryption=srtp
use_ipv6=0
[rtp]
audio_rtp_port=5004
video_rtp_port=0
nortp_timeout=0
audio_jitt_comp=60
video_jitt_comp=60
audio_adaptive_jitt_comp_enabled=1
video_adaptive_jitt_comp_enabled=1
[video]
enabled=0
show_local=0
[audio_codec_0]
mime=opus
rate=8000
channels=1
enabled=1
[audio_codec_1]
mime=speex
rate=8000
channels=1
enabled=1
[audio_codec_2]
mime=PCMU
rate=8000
enabled=1
[audio_codec_5]
mime=1015
rate=8000
enabled=1
[sound]
The file has been placed in C:\Program Data\WTWare\Everyone
I see in the log that the file is being downloaded:
[            gm] [   19.076803] [TFTP] Download config file Everyone/linphone.wtc from <REDACTED>.
/--- FILE "/.linphonerc" -----------------------
| [sip]
| use_ipv6=0
| [rtp]
| audio_rtp_port=5004
| video_rtp_port=0
| nortp_timeout=0
| audio_jitt_comp=60
| video_jitt_comp=60
| [video]
| enabled=0
| show_local=0
| [audio_codec_0]
| mime=opus
| rate=8000
| channels=1
| enabled=1
| [audio_codec_1]
| mime=speex
| rate=8000
| channels=1
| enabled=1
| [audio_codec_2]
| mime=PCMU
| rate=8000
| enabled=1
| [audio_codec_5]
| mime=1015
| rate=8000
| enabled=1
| [sound]
| ringer_dev_id=ALSA: Sennheiser SC60 Control
| playback_dev_id=ALSA: Sennheiser SC60 Control
| capture_dev_id=ALSA: Sennheiser SC60 Control
But when I run the command param sip use_ipv6 I get the output:
current value: (undef)
This means that linphonec never read the value in which means it's not reading the file in. Any ideas?
Re: Linphone not pulling in custom config
Posted: Wed Dec 19, 2018 6:02 am
There is no ipv6 in wtware at all. Kernel compiled without ipv6.
Posted: Wed Dec 19, 2018 11:48 pm
by effin_dead_again
You've completely missed the point. I am trying to convey that linphonec is not pulling in the configuration that I am specifying in the config file. It is getting downloaded from the server but it is not getting applied to linphonec. The command I ran was a test to see if liphonec was pulling in the value I set in the config file that was specified. It is not using the values in the config file despite clearly downloading them from the server.
Posted: Thu Dec 20, 2018 11:57 am
Here is the manual about logs: https://wtware.com/logs.html
No words "remove everything interesting and leave only few lines".
Posted: Thu Dec 20, 2018 8:48 pm
by effin_dead_again
Attached.
Just an FYI, you are about half of a centimeter away from me buying another solution if you can't get that gnarly attitude under control. Perhaps you should change your auto-response to be something like: "The logs you have provided do not have enough information for us to research your issue. Please review the manual about logs here: https://wtware.com/logs.html and provide the full log output for our review."
It appears to me that linphonec isn't looking for the .linphonerc file in the location you are placing it but I am not familiar enough with the internals of WTWare to know any better. I will await your response.
Posted: Fri Dec 21, 2018 4:51 pm
We'll use your text as auto-response. Thank you.
There are no .linphonerc files other than the one that printed in log. Lot of errors in lines with [ SIP] mark comes from your (what is not gnarly form of the word "incorrect"?) config.
Posted: Fri Dec 21, 2018 7:23 pm
by effin_dead_again
I figured out the issue, but it was not because of an error in my config, but rather the lack of one option in the SIP section: ipv6_migration_done=1
Here is the config file that ultimately worked for me:
[audio_codec_0]
mime=opus
rate=48000
channels=1
enabled=1
[audio_codec_1]
mime=speex
rate=8000
channels=1
enabled=1
[audio_codec_2]
mime=SILK
rate=16000
channels=1
enabled=1
[audio_codec_3]
mime=BV16
rate=8000
channels=1
enabled=1
[audio_codec_4]
mime=GSM
rate=8000
channels=1
enabled=1
[audio_codec_5]
mime=G722
rate=8000
channels=1
enabled=1
[audio_codec_6]
mime=PCMU
rate=8000
channels=1
enabled=1
[audio_codec_7]
mime=PCMA
rate=8000
channels=1
enabled=1
[net]
adaptive_rate_control=1
mtu=0
[sip]
use_ipv6=0
[rtp]
nortp_timeout=0
[sound]
echocancellation=1
remote_ring=/usr/local/share/sounds/linphone/rings/ringback.wav
local_ring=/usr/local/share/sounds/linphone/rings/oldphone.wav
You can consider this issue resolved.
