Error
gbsinformatica
Error
Post by gbsinformatica »
Good afternoon, could you help me? I have the following problem:
"Server requires 16 bit color depth
Windows Server is able to work with up to 32 bit color..."
Can you tell me if it's a WTWare configuration error or is it a server configuration?
Re: Error
It may be fixed either in WTWare configuration or in a server configuration. In message box there is tool name and path to fix on server. On WTware side, add "bpp=16" to config.
Show me the log after the error if nothing of this helps: https://wtware.com/logs.html
gbsinformatica
Re: Error
Good afternoon, I managed to settle in parts. I noticed that this error happens in the latest version 5.8.62. I even put "bpp = 16", and even changed it inside the config.txt file, but the error remains, I didn't make the change on the server. But all right, I went back to using a version before 5.8.62. Thanks :)
