Connects to 2012 R2 as a Temporary Profile
SimonJ
Post by SimonJ » Mon Jun 18, 2018 4:34 am
I am testing WTWare ver. 5.8.20 using HP Thin Clients.
My template has ask_password = ON so that users don't have to put their password in twice. While this works, it always comes up as having loaded a Temporary Profile in their RDP session.
Change ask_password to Off and their session loads correctly (but they have entered in their password twice).
I have added loadbalanceinfo = tsv://MS Terminal Services Plugin.1.MyFarmCollectionName but still the same result.
I have added the IP address of the other Servers in the Farm in Server parameter but I suppose this is only for redundancy if a particular server was down.
I have the log file from the thin client... do I need to take out sensitive information before attaching it?
Simon J
Re: Connects to 2012 R2 as a Temporary Profile
Post by akatik » Sun Jun 24, 2018 8:33 pm
Send log to support@wtware.com if you think there is sensitive information.
SimonJ
Post by SimonJ » Tue Jul 03, 2018 7:59 am
I attached the full log file and emailed it to support@wtware.com on the 28th June.
I would appreciate you checking it out.
Thanks,
Simon
SimonJ
Post by SimonJ » Thu Sep 13, 2018 2:04 am
This issue has stopped happening. Nothing was changed, perhaps it is due to an update in versions or Windows Update from Microsoft.
Simon J
it@jzflowers
Post by it@jzflowers » Fri Jun 14, 2019 7:33 pm
Hello Simon, could you share your config file info? (Excluding any personal info of course) I’m repeatedly getting temp profile on a device and I need to try to see if it’s something I’ve missed
