Boot from DHCP error packages/wtpx.pkg
Posted: Fri Jul 03, 2009 10:00 am
i tried to Boot from DHCP but i get an error "failed to download packages/wtpx.pkg"
i use the TFTP client which is included into wtware.
logfile:
INFO : Got RRQ, 36 bytes.
INFO : 00000000: 70 72 6f 5c 34 2e 35 2e 32 39 5c 70 78 65 6c 69
INFO : 00000010: 6e 75 78 2e 30 00 6f 63 74 65 74 00 74 73 69 7a
INFO : 00000020: 65 00 30 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.0". Tsize is requested, blksize default.
INFO : Sending OASK (tsize 13340) to 192.100.100.32.
WARNING: Received opcode 5 from 192.100.100.32.
WARNING: 00000000: 00 05 00 00 54 46 54 50 20 41 62 6f 72 74 65 64
WARNING: 00000010: 00
INFO : Got RRQ, 41 bytes.
INFO : 00000010: 6e 75 78 2e 30 00 6f 63 74 65 74 00 62 6c 6b 73
INFO : 00000020: 69 7a 65 00 31 34 35 36 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.0". Tsize is not requested, blksize 1456 bytes.
INFO : Sending OASK (blksize 1456) to 192.100.100.32.
INFO : Transfer of file "pro\4.5.29\pxelinux.0" to 192.100.100.32 completed.
INFO : Connection to 192.100.100.32 closed.
INFO : Got RRQ, 72 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 30 31 2d 30 30 2d 31 64
INFO : 00000020: 2d 30 39 2d 31 32 2d 36 32 2d 30 37 00 6f 63 74
INFO : 00000030: 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69
INFO : 00000040: 7a 65 00 31 34 34 30 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.cfg\01-00-1d-09-12-62-07". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.100.100.32 file "C:\Programme\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\01-00-1d-09-12-62-07" not found.
INFO : Got RRQ, 60 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 36 34 36 34 32 30
INFO : 00000020: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
INFO : 00000030: 6c 6b 73 69 7a 65 00 31 34 34 30 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.cfg\C0646420". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.100.100.32 file "C:\Programme\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C0646420" not found.
INFO : Got RRQ, 59 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 36 34 36 34 32 00
INFO : 00000020: 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c
INFO : 00000030: 6b 73 69 7a 65 00 31 34 34 30 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.cfg\C064642". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.100.100.32 file "C:\Programme\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C064642" not found.
INFO : Got RRQ, 58 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 36 34 36 34 00 6f
INFO : 00000020: 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b
INFO : 00000030: 73 69 7a 65 00 31 34 34 30 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.cfg\C06464". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.100.100.32 file "C:\Programme\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C06464" not found.
INFO : Got RRQ, 57 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 36 34 36 00 6f 63
INFO : 00000020: 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73
INFO : 00000030: 69 7a 65 00 31 34 34 30 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.cfg\C0646". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.100.100.32 file "C:\Programme\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C0646" not found.
INFO : Got RRQ, 56 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 36 34 00 6f 63 74
INFO : 00000020: 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69
INFO : 00000030: 7a 65 00 31 34 34 30 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.cfg\C064". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.100.100.32 file "C:\Programme\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C064" not found.
INFO : Got RRQ, 55 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 36 00 6f 63 74 65
INFO : 00000020: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
INFO : 00000030: 65 00 31 34 34 30 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.cfg\C06". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.100.100.32 file "C:\Programme\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C06" not found.
INFO : Got RRQ, 54 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 00 6f 63 74 65 74
INFO : 00000020: 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65
INFO : 00000030: 00 31 34 34 30 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.cfg\C0". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.100.100.32 file "C:\Programme\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C0" not found.
INFO : Got RRQ, 53 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 00 6f 63 74 65 74 00
INFO : 00000020: 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00
INFO : 00000030: 31 34 34 30 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.cfg\C". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.100.100.32 file "C:\Programme\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C" not found.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 64 65 66 61 75 6c 74 00
INFO : 192.100.100.32 requests file "pro\4.5.29\pxelinux.cfg\default". Tsize is requested, blksize 1440 bytes.
INFO : Sending OASK (tsize 222, blksize 1440) to 192.100.100.32.
INFO : Transfer of file "pro\4.5.29\pxelinux.cfg\default" to 192.100.100.32 completed.
INFO : 00000000: 70 72 6f 5c 34 2e 35 2e 32 39 5c 77 74 73 68 65
INFO : 00000010: 6c 6c 2f 62 7a 49 6d 61 67 65 00 6f 63 74 65 74
INFO : 192.100.100.32 requests file "pro\4.5.29\wtshell\bzImage". Tsize is requested, blksize 1440 bytes.
INFO : Sending OASK (tsize 1147904, blksize 1440) to 192.100.100.32.
INFO : Transfer of file "pro\4.5.29\wtshell\bzImage" to 192.100.100.32 completed.
INFO : 00000010: 6c 6c 2f 77 74 73 68 65 6c 6c 00 6f 63 74 65 74
INFO : 192.100.100.32 requests file "pro\4.5.29\wtshell\wtshell". Tsize is requested, blksize 1440 bytes.
INFO : Sending OASK (tsize 1822720, blksize 1440) to 192.100.100.32.
INFO : Transfer of file "pro\4.5.29\wtshell\wtshell" to 192.100.100.32 completed.
INFO : Timeout occured while transfer "pro\4.5.29\pxelinux.0" to 192.100.100.32.
WARNING: Client 192.100.100.32 not responding. Connection closed.
INFO : 00000000: 70 72 6f 2f 34 2e 35 2e 32 39 2f 70 78 65 6c 69
INFO : 00000000: 70 72 6f 2f 34 2e 35 2e 32 39 2f 77 74 73 68 65
logfile:
