Dont Panic
PaulU
Dont Panic
Post by PaulU » Tue Aug 12, 2008 2:47 am
Hi Guys
I have a problem with the ION A503 Thin Client, Nothing But
WTware Lite Version 4.2.1 will even boot this little Geode Based system
Tried booting from "USB flash, and USB cdrom"
When i do get 4.2.1 to run up, i am then unable to carry out the install to hard drive or any configrations as the USB keyboard is not Found ?.
All versions from 4.2.1 onwards cause the A503 to hang including the Pro
version i tryed out.
It grinds to a halt giving the error message "Kernal Panic"
Is anyone aware of Problems with this small micro PC
Regards Paul
PaulU
More Info
Post by PaulU » Wed Aug 20, 2008 6:38 pm
Hi All,
During my continued testing with WTware lite, i found that a problem
seems to occur with the Tftp side of things, PXE booting fails and displays
an error mesage "Malformed RRQ", Stopping and disabling WTwares
TFTP service and reinstalling a new separate tftp server cured this problem,
BUT i still have the original problem above with my AMD Geode
systems...........
Regards Paul..
Post by aka » Wed Aug 27, 2008 6:19 pm
Please, try newer wtware versions. We have several Geode systems, and 4.4.x and 4.5.x versions work well on it.
PaulU
Post by PaulU » Wed Aug 27, 2008 9:50 pm
Hi Aka,
I shall try your advice and try the new version 4.5.13 which i
notice has just been posted.
Will let you know the results
Kind regards Paul
PaulU
Post by PaulU » Wed Aug 27, 2008 11:06 pm
Hi Aka,
Just loaded the new 4.5.13 Beta onto my NoteBook, then created a USB boot PenDrive and tryed to boot the Geode via The memory stick.
Whilst it does Boot I,m afraid it still just hangs and comes up with a Kernel error..
One of the main error messages states
Unable to handle kernel NULL pointer dereference at virtual address
0000001c
*pde = 00000000
Futher on it states...
Code 8b 48 1c 31 ff 31 f6 8b 11 8a 42 01 3c 02 74 0b 3c 14 75 0e
<0> Kernal panic: attempted to kill init!
Hope you can make some sense of this let's know what you think
Kind Regards Paul
P.S. if you need more info from the screen i will type it up by hand ...
PaulU
Post by PaulU » Thu Aug 28, 2008 1:10 pm
Hi All,
After my tests last night with the Beat Version 4.5.13 at home,
i decided to reinstall it and test again at work in the server room.
My test setup FAILED!!
Once again the Malformed RRQ error shows up, the only way around this
is to use Tftpd32 as the tftp server, and not the wtware Tftp server.
Once this issue was resolved i then found that when trying to PXE boot random machines in our IT suite, another error shows
The Message "Incorrect noddc value"
Any Ideas ??
Test Carried out on Dell Machines
Must remember this is a Beta..
And the software still don't like my Geode CPU's at all
Regards Paul...
Post by aka » Sat Aug 30, 2008 6:57 pm
What DHCP server do you use?
"Incorrect noddc value" is our fault, sorry. Fixed in 4.5.14.
And please give me more details abuot Geode board. Google doesn't know "ION A503".
PaulU
Post by PaulU » Sun Aug 31, 2008 12:51 am
Hi Aka,
Thankyou for the feedback, the DHCP server is our domain controller, using Win2k3 server standard.
Re: The ION A503
Here's a link to the unit
http://www.viglen.co.uk/webmail/pdfs/MPC-l.pdf
The Original Manafacturer is here
Model shown here is now the current Production Unit The ION A603
with full spesification list &chipset info
http://www.fic.com.tw/product/minipc.aspx
Best Regards Paul..
Re: Dont Panic
Post by aka » Wed Jul 15, 2009 11:31 am
Newer WTware version should fix this problem.
