Boot no sd card - how to undo
Posted: Sun Feb 25, 2018 7:58 am
by HereKittyKitty
i did the boot without using sd and it worked. but now i have no clue how to revert back to it not doing this.
everytime i plug in the RPi3, it trys to netboot i want to stop it go back to raspberry pi 3 normal factory settings
Re: Boot no sd card - how to undo
Posted: Sun Feb 25, 2018 12:09 pm
Install good, not broken boot SD. It netboots AFTER it fails to boot from SD.
Posted: Sun Feb 25, 2018 1:04 pm
by HereKittyKitty
is there away to remove WT from it so it dont even try? or im stuck with it now trying to NetBoot into WT only
Posted: Sun Feb 25, 2018 5:34 pm
After writing this programmable SD Pi will always:
- try to boot from SD
- if fails boot by network.
There is no undo and it's not related to wtware. While programming network boot, we execute this raspberry developer's manual:
https://www.raspberrypi.org/documentati ... des/msd.md
If you don't need network boot, insert good working SD with what you want to see on Raspberry.
