Boot Network Card Errors
Posted: Wed Oct 31, 2007 12:26 pm
I am having a problem booting WTWare Lite using a CD on a HP DC7700
I can boot using the CD on a HP DX2000 computer fine.
I have also now tried both versions 4.21 and 4.3.60 so see if there was a difference but I got the same error message.
When the Computer boots off the CD, it comes up with the WTWare loading Terminal Screen and then errors with:
Error Network Card Not Found. If Intel EtherExpress or ISA NE 2000-Compatible card is used, then it should be configured to work with port 300.
NIC1 PCIID 8086:104a
NIC2 PCIID 0000:0000
Please correct the error to continue.
Any ideas??
Thank you for your help
James
Any ideas??
James
