Error Microphone usb desconnected erro IM tired
Fabio Oliveira
Post by Fabio Oliveira »
Good afternoon.
We use WTware with an RDP client and have enabled the audio and microphone feature. However, when the USB device is disconnected, after a while it disconnects the session and displays the message "I'm tired." How can I solve this issue?
WTware_B8.27.EB.40.D8.40_2025-08-05_14-43-51.txt
(13.19 KiB) Downloaded 1315 times
Re: Error Microphone usb desconnected erro IM tired
Here is logging manual: http://wtware.com/logs.html
Four simple steps. The problem usually is solved when you do them.
Show me full log here or to support@wtware.com if it won't help.
Also, do not unplug sound device. It never helps and may makes worse.
