Hi Wtware Team!
I was using with sucess the IDBridge CT30 SmartCard reader in the old 5.6.22 version, but now after a update to versions 6.2.4x it doesn't work anymore. The settings are the same and also same Rasp Pi 3 hardware.
Log file in the attachments.
Can I get some support to use this SmartCard in the newest builds?
SmartCard reader doesn't work in recent builds
andrenoites
- wtware_support.txt
- LOG
- (40.47 KiB) Downloaded 2847 times
Re: SmartCard reader doesn't work in recent builds
Everything (card reader, card, server, user on server) it the same except wtware version? Will it work if you return back to 5.6.22?
I see no easy solution. Smart card redirection was rewritten since 5.6.x. If you have no time for long debugging, stay on old version.
If you have some time, give me debugging logs. Write into terminal config:
Reboot and reproduce error.
Save the log immediately after you see first incorrect behavior.
Then return back to 5.6.22. Write into terminal config:
Do the same things you do with 6.2.44 before it goes wrong. Save another log.
Logs with debugging may contain sensitive information. Send it to support@wtware.com, not to forum.
smartcard=gempctwin, debug, debug_pcscdSave the log immediately after you see first incorrect behavior.
smartcard=gempctwin, debugLogs with debugging may contain sensitive information. Send it to support@wtware.com, not to forum.
andrenoites
Reply sent by email. Thanks
Logs received. As soon as we have any solution, we'll send you response by e-mail
I can not find a bug that I can fix
We do things right. Somewhere on lower levels things goes wrong. Since 5.6.22, additional lower levels were added, and I can not revert changes back...
Here is similar error: https://github.com/LudovicRousseau/PCSC/issues/16 Same reader Gemalto GemPC Twin, same error text "state machine is DEAD". But it's 2017, and final solution "after that i have changed the libusb and ccid drivers version. and now error is fixed". Not a solution really.
Ok, I have changed the libusb and ccid drivers version too. Please try this build:
http://wtware.com/testing/202501100105/ ... ry.img.zip
In Raspberry Pi Imager CHOOSE OS -> Use custom -> Choose downloaded zip file.
andrenoites
Hi akatik!
The test version from the link you provided didn't work either
I will send the logs to the support@wtware.com email.
Thanks again por the support
