2-4K resolution possible?
Posted: Fri Mar 11, 2022 3:01 pm
we want to buy 2K or 4k monitors, but in the "Raspberry firmware config.txt" you can only set a maximum resolution of 1920x1200.
We currently need a resolution of 2560x1440 on only one display, the second display HDMI port is not used.
Later then a resolution of 3840 x 2160
We use Raspberry Pi 4 versions
