App Crash in Startup
jcazeri
Post by jcazeri »
I'm having a specific problem with a remoteapp, everyone is working correctly, but a specific one when run generates an error on startup and doesn't open, when I see the logos on the Remote Server there is an id1000 of app crash. Running the same remoteapp via mtsc.exe works perfectly, follow the log with the error:
9-11-04-707| [ KERNEL] [ 114.554911] logitech-djreceiver 0003:046D:C52F.0009: device of type eQUAD step 4 DJ (0x04) connected on slot 1
19-11-04-707| [ KERNEL] [ 114.563613] input: Logitech M185 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.1/0003:046D:C52F.0009/0003:046D:4008.000A/input/input3
19-11-04-707| [ KERNEL] [ 114.563990] logitech-hidpp-device 0003:046D:4008.000A: input,hidraw2: USB HID v1.11 Mouse [Logitech M185] on usb-3f980000.usb-1.1.2/input1:1
19-11-05-467| [ KERNEL] [ 115.326941] logitech-hidpp-device 0003:046D:4008.000A: HID++ 2.0 device connected.
19-11-06-709| [ gm] [ 116.571541] Run '/sbin/resolver 0x21676a8 dns [xxx.xxx.xxx.xxx]', log '', env '', pid ''.
19-11-06-754| [ pfac] [ 116.572098] Run /sbin/resolver 0x21676a8 dns [xxx.xxx.xxx.xxx].
19-11-06-754| [ pfac] [ 116.572320] Ok, PID 880.
19-11-06-754| [ pfac] [ 116.577044] Process pid 880 terminated, status 00000000.
19-11-06-756| [ gm] [ 116.577697] xxx.xxx.xxx.xxx => xxx.xxx.xxx.xxx.
19-11-06-756| [ gm] [ 116.595279] Free ram before fork terminal client /sbin/rdpclient (session 2): 891432 Kb.
19-11-06-756| [ pfac] [ 116.595483] Run /sbin/rdpclient 2.
19-11-06-757| [ gm] [ 116.595514] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
19-11-06-757| [ pfac] [ 116.595676] Ok, PID 881.
19-11-06-757| [ rdpclient 881] [ 116.614126] RDP Terminal Client, WTware 6.0.36/RPi, pipe 2, pid 881.
19-11-06-757| [ rdpclient 881] [ 116.614618] Use /lib/ui16.so.
19-11-06-757| [ rdpclient 881] [ 116.615752] Make RDP session with xxx.xxx.xxx.xxx, port 25441.
19-11-06-757| [ rdpclient 881] [ 116.615959] Username: "br.braganca".
19-11-06-757| [ rdpclient 881] [ 116.616089] Password: present.
19-11-06-757| [ rdpclient 881] [ 116.616217] No PIN.
19-11-06-757| [ rdpclient 881] [ 116.616342] Domain: "cantoso".
19-11-06-757| [ rdpclient 881] [ 116.616466] Shell: "F:\LTS\LTS-DPH\LTS\LTS_FINANCEIRO_COPIAR.EXE".
19-11-06-757| [ rdpclient 881] [ 116.616596] No directory.
19-11-06-757| [ rdpclient 881] [ 116.616735] Window: 1856x1080@16.
19-11-06-757| [ rdpclient 881] [ 116.616863] PFlags 0x00000180.
19-11-06-757| [ rdpclient 881] [ 116.616988] Keyboard 00000416:00000000.
19-11-06-757| [ rdpclient 881] [ 116.617115] My hostname "wtwB827EB26BF0E".
19-11-06-765| [ rdpclient 881] [ 116.617241] TCP: connecting to xxx.xxx.xxx.xxx:25441.
19-11-06-804| [ rdpclient 881] [ 116.630127] TCP: connection with xxx.xxx.xxx.xxx:25441 established.
19-11-06-804| [ rdpclient 881] [ 116.630295] Turn keepalive on.
19-11-06-804| [ rdpclient 881] [ 116.631137] Free ram after buffers allocation: 890936 KB.
19-11-06-804| [ rdpclient 881] [ 116.661085] Process RDP server certificate.
19-11-06-804| [ rdpclient 881] [ 116.661217] RDP5 encryption (X.509).
19-11-07-479| [ rdpclient 881] [ 117.345790] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000034.
19-11-28-518| [ rdpclient 881] [ 138.382701] SessionId 0x00000034: cantoso\br.braganca.
19-11-58-298| [ rdpclient 881] [ 168.162096] errorInfo 0x00000000.
19-11-58-343| [ gm] [ 168.162314] TSClient (sessionId 2, pid 881) gracefully end.
19-11-58-343| [ rdpclient 881] [ 168.162350] Receive Disconnect Provider Ultimatum.
19-11-58-344| [ pfac] [ 168.166308] Process pid 881 terminated, status 00000009.
19-12-25-656| [ gm] [ 195.533637] Run '/sbin/resolver 0x21676a8 dns [xxx.xxx.xxx.xxx]', log '', env '', pid ''.
19-12-25-716| [ pfac] [ 195.534193] Run /sbin/resolver 0x21676a8 dns [xxx.xxx.xxx.xxx].
19-12-25-717| [ pfac] [ 195.534415] Ok, PID 882.
19-12-25-717| [ pfac] [ 195.539258] Process pid 882 terminated, status 00000000.
19-12-25-718| [ gm] [ 195.539746] xxx.xxx.xxx.xxx => xxx.xxx.xxx.xxx.
19-12-25-718| [ gm] [ 195.557445] Free ram before fork terminal client /sbin/rdpclient (session 3): 891388 Kb.
19-12-25-719| [ pfac] [ 195.557636] Run /sbin/rdpclient 3.
19-12-25-719| [ gm] [ 195.557666] Run '/sbin/rdpclient 3', log '/tmp/rdpclient.out', env '', pid ''.
19-12-25-719| [ pfac] [ 195.557837] Ok, PID 883.
19-12-25-720| [ rdpclient 883] [ 195.576152] RDP Terminal Client, WTware 6.0.36/RPi, pipe 3, pid 883.
19-12-25-720| [ rdpclient 883] [ 195.576637] Use /lib/ui16.so.
19-12-25-720| [ rdpclient 883] [ 195.577714] Make RDP session with xxx.xxx.xxx.xxx, port 25441.
19-12-25-720| [ rdpclient 883] [ 195.577919] Username: "br.braganca".
19-12-25-720| [ rdpclient 883] [ 195.578046] Password: present.
19-12-25-720| [ rdpclient 883] [ 195.578174] No PIN.
19-12-25-720| [ rdpclient 883] [ 195.578298] Domain: "cantoso".
19-12-25-720| [ rdpclient 883] [ 195.578426] Shell: "||Spark".
19-12-25-720| [ rdpclient 883] [ 195.578559] No directory.
19-12-25-720| [ rdpclient 883] [ 195.578690] Window: 1856x1080@16.
19-12-25-720| [ rdpclient 883] [ 195.578818] PFlags 0x00000180.
19-12-25-720| [ rdpclient 883] [ 195.578944] Keyboard 00000416:00000000.
19-12-25-720| [ rdpclient 883] [ 195.579070] My hostname "wtwB827EB26BF0E".
19-12-25-720| [ rdpclient 883] [ 195.579199] TCP: connecting to xxx.xxx.xxx.xxx:25441.
19-12-25-728| [ rdpclient 883] [ 195.590432] TCP: connection with xxx.xxx.xxx.xxx:25441 established.
19-12-25-774| [ rdpclient 883] [ 195.590666] Turn keepalive on.
19-12-25-774| [ rdpclient 883] [ 195.591275] Free ram after buffers allocation: 891388 KB.
19-12-25-774| [ rdpclient 883] [ 195.619923] Process RDP server certificate.
19-12-25-774| [ rdpclient 883] [ 195.620077] RDP5 encryption (X.509).
19-12-26-405| [ rdpclient 883] [ 196.278149] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000035.
19-12-47-397| [ rdpclient 883] [ 217.261013] SessionId 0x00000035: cantoso\br.braganca.
19-13-12-285| [ gm] [ 242.163920] Kill session 883.
19-13-12-346| [ rdpclient 883] [ 242.164065] Caught signal SIGTERM.
19-13-12-346| [ gm] [ 242.164242] Session terminated.
19-13-12-346| [ gm] [ 242.164869] Session is over. Final message: Session terminated.
19-13-12-346| [ pfac] [ 242.166825] Process pid 883 terminated, status 00000009.
19-17-51-358| Reboot.
19-18-01-485| [wtc.exe] Connection closed.
Re: App Crash in Startup
https://wtware.com/logs.html
2. Remove all lines from terminal configuration file. Absolutely all. Think what should be in configuration file to reproduce the error. For example, if you have problem with usb barcode scanner, specify only server= and serial= parameters. You will recover all your lines after as soon as we solve current problem.
Also, return config.txt to default state to run default 32-bit color. And send me full log to support@wtware.com
