Then i will install wteare v.5.8.88 on thin client INIT TR2340, show this:
An Error occurred while terminal boot
ERROR: INTERNAL ERROR
Wtware 5.8.88
File:setup.cpp
Line:851
Please, report this information to Wtware tech support.
Plase, any help for this?
Thanks!
INSTALATION ERROR Line 851
Re: INSTALATION ERROR Line 851
So, the initialization of the pendrive is ok, fully functional, but after I try to install it, error 851 occurred. I follow the guidance, to read the log file, I verify that it does not proceed because it is not the FAT file system ... I will try format some ways in the FAT file system and report here. Thank you wtware support for answering my email. (Text by google translation, sorry errors
Problem solved!
I discovered the problem, in addition to being the FAT file system, the terminal I was trying to install has only 32 megabytes of internal space. Not 32 Gigabytes as I thought ... Just for flash drive now. (text by google translator...)
