Terminal: Raspberry Pi 4b running WTware 6.0.52
Server: Asrock Rack X470D4U/AMD 3700X 32Gb DDR4 running Proxmox PVE 6.4
I'm connecting to a Win 10 VM via RDP. After a fresh boot to the PVE server, the RPi/WTware will connect just fine. No problems. But after a couple of days, the RPi/WTware terminal will just get a connection refused error. I see that Proxmox does daily checks for new package updates. I can't be certain if this is a Proxmox issue or a WTware issue, but rebooting the PVE server fixes the issue every time.
Has anyone else run into this?
How do I resolve this issue?
Thanks in advance!
- Jim
Can't connect to VM after server update
Re: Can't connect to VM after server update
Send full wtware log to support@wtware.com - http://wtware.com/logs.html
