i'm trialing the software for a cctv solution and i'm noticing i can't run my PI4 in 32 bit colour and the colour seems to be washed out in a terminal service.
attached are the configs
can anyway assist on why i can't get full colour from my PI
[ httpd] [ 12.259132] Internal HTTP Server, WTware 5.8.72/RPi
[ httpd] [ 12.268429] Reread settings.
[ initrd] [ 12.268538] Unpack /bootmedia/packages/pi2-f.
[ httpd] [ 12.268642] Everyone can control terminal by HTTP.
[ KERNEL] [ 12.393099] random: crng init done
[ gm] [ 12.394211] WTware 5.8.72/RPi session manager.
[ gm] [ 12.460157] EV_REL flag found. Add mouse event1: USB Optical Mouse.
[ gm] [ 12.460269] Add keyboard event0: Dell Dell USB Entry Keyboard.
[ gm] [ 12.460360] Display mode: 1680x1050, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 12.757149] Framebuffer device found.
[ gm] [ 12.757193] LINELENBYTES 3360
[ gm] [ 12.757229] VLEN 3528000
[ gm] [ 12.758294] Use /lib/ui16.so.
[ gm] [ 12.770819] Copy /bootmedia/configs/vhusbdarm to /vh/vhusbdarm.
/--- FILE "/vh/config.ini" -----------------------
| ServerName=wtwDCA6322F3FD9
| Hostname=wtwDCA6322F3FD9
| UseAVAHI=0
| AllowedDevices=68e/ca
[ gm] [ 12.781568] Run '/vh/vhusbdarm -b -c /vh/config.ini -r /tmp/vh.out', log '', env '', pid ''.
[ pfac] [ 12.781784] Run /vh/vhusbdarm -b -c /vh/config.ini -r /tmp/vh.out.
[ pfac] [ 12.781830] Ok, PID 809.
[ VirtualHere] [ 12.847106] Wed Oct 23 00:00:10 2019 LOG_INFO >>> Starting VirtualHere USB Server v4.0.5 (Built: Oct 18 2019, 17:41:59)<<<
[ VirtualHere] [ 12.847146] Wed Oct 23 00:00:10 2019 LOG_INFO Using configuration /vh/config.ini
[ pfac] [ 12.847566] Process pid 809 terminated, status 00000000.
[ gm] [ 12.854739] Run '/sbin/resolver 0x702f20 dns [10.30.81.110]', log '', env '', pid ''.
[ pfac] [ 12.854851] Run /sbin/resolver 0x702f20 dns [10.30.81.110].
[ gm] [ 12.854885] Nobody can control terminal by VNC.
[ pfac] [ 12.854930] Ok, PID 811.
[ gm] [ 12.857012] 10.30.81.110 => 10.30.81.110.
[ pfac] [ 12.857181] Process pid 811 terminated, status 00000000.
[ gm] [ 12.859937] Free ram before fork terminal client /sbin/rdpclient (session 1): 3760508 Kb.
[ pfac] [ 12.860156] Run /sbin/rdpclient 1.
[ gm] [ 12.860182] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 12.860229] Ok, PID 812.
[ rdpclient 812] [ 12.865082] RDP Terminal Client, WTware 5.8.72/RPi, pipe 1, pid 812.
[ rdpclient 812] [ 12.865471] Use /lib/ui16.so.
[ rdpclient 812] [ 12.866536] Make RDP session with 10.30.81.110, port 3389.
[ rdpclient 812] [ 12.866702] Username: "xxxx".
[ rdpclient 812] [ 12.866764] Password: present.
[ rdpclient 812] [ 12.866805] No PIN.
[ rdpclient 812] [ 12.866845] No domain.
[ rdpclient 812] [ 12.866884] No shell.
[ rdpclient 812] [ 12.866924] No directory.
[ rdpclient 812] [ 12.866962] Window: 1616x1050@16.
[ rdpclient 812] [ 12.867003] PFlags 0x0000002F.
[ rdpclient 812] [ 12.867044] Keyboard 00000409:00000000.
[ rdpclient 812] [ 12.867084] My hostname "wtwDCA6322F3FD9".
[ rdpclient 812] [ 12.867123] TCP: connecting to 10.30.81.110:3389.
[ rdpclient 812] [ 12.868402] TCP: connection with 10.30.81.110:3389 established.
[ rdpclient 812] [ 12.868448] Turn keepalive on.
[ rdpclient 812] [ 12.868923] Free ram after buffers allocation: 3759812 KB.
[ rdpclient 812] [ 12.882597] Reconnect with NLA enabled.
[ rdpclient 812] [ 12.882641] TCP: reconnecting to 10.30.81.110:3389.
[ rdpclient 812] [ 12.883868] TCP: connection with 10.30.81.110:3389 established.
[ rdpclient 812] [ 12.883907] Turn keepalive on.
[ rdpclient 812] [ 12.895213] Server supports GFX Pipeline.
[ rdpclient 812] [ 12.895264] NLA.
[ rdpclient 812] [ 12.895311] SSL/TLS.
[ VirtualHere] [ 12.912656] Wed Oct 23 00:00:10 2019 LOG_INFO Server licensed to=unlicensed max_devices=1
[ VirtualHere] [ 12.912798] Wed Oct 23 00:00:10 2019 LOG_INFO Using large URB's
[ VirtualHere] [ 12.913908] Wed Oct 23 00:00:10 2019 LOG_INFO Listening on all network interfaces at TCP port 7575
[ rdpclient 812] [ 13.036839] Enable font smoothing and Desktop Composition.
[ rdpclient 812] [ 13.253340] GFX codec.
[ rdpclient 812] [ 14.280189] Run 4 tile threads.
[ rdpclient 812] [ 14.318548] errorInfo 0x00000000.
[ rdpclient 812] [ 14.667852] SessionId 0x00000002: xxxx.
WTware config:
connection
displayname=JUNWS003
server=10.30.81.110
user=
onerror = quiet
vhusb = on
vhusb = UseAVAHI
vhusb = 068e:00ca
redraw_delay=100
scale_factor = 100
bpp = 32
Pi config.txt
core_freq_min=500
disable_overscan=1
disable_splash=1
gpu_mem_1024=256
max_framebuffers=2
[pi4]
max_framebuffers=2
[all]
i have tried to set my hdmi modes as the following but it still does 16bit
hdmi_group=2
hdmi_mode=58
framebuffer_ignore_alpha=1
framebuffer_depth=32
Pi4 running 16bit colour not 32bit
Re: Pi4 running 16bit colour not 32bit
Hi -
here is the full log
WTware 5.8.72/RPi supervisor.
[ KERNEL] [ 0.000000] Linux version 4.19.80-v7l (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #9 SMP Wed Oct 23 11:42:47 EDT 2019
[ KERNEL] [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ KERNEL] [ 0.000000] cma: Reserved 64 MiB at 0x0000000037400000
[ KERNEL] [ 0.000000] On node 0 totalpages: 1012736
[ KERNEL] [ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ KERNEL] [ 0.000000] random: get_random_bytes called from 0xc0a009e0 with crng_init=0
[ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011200
[ KERNEL] [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm2708_fb.fbwidth=1680 bcm2708_fb.fbheight=1050 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:2F:3F:D9 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 quiet wtboot=mmc
[ KERNEL] [ 0.000000] Memory: 3937688K/4050944K available (6144K kernel code, 148K rwdata, 664K rodata, 6144K init, 372K bss, 47720K reserved, 65536K cma-reserved, 3198976K highmem)
[ KERNEL] [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ KERNEL] [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ KERNEL] [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ KERNEL] [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ KERNEL] [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (8160 kB)
[ KERNEL] [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (6144 kB)
[ KERNEL] [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 149 kB)
[ KERNEL] [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 373 kB)
[ KERNEL] [ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ KERNEL] [ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ KERNEL] [ 0.000016] Switching to timer-based delay loop, resolution 18ns
[ KERNEL] [ 0.000188] Console: colour dummy device 80x30
[ KERNEL] [ 0.000204] console [tty0] enabled
[ KERNEL] [ 0.000237] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ KERNEL] [ 0.000253] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.000375] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000886] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.001185] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ KERNEL] [ 0.001564] Setting up static identity map for 0x200000 - 0x20003c
[ KERNEL] [ 0.001658] rcu: Hierarchical SRCU implementation.
[ KERNEL] [ 0.002153] smp: Bringing up secondary CPUs ...
[ KERNEL] [ 0.002708] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ KERNEL] [ 0.003343] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ KERNEL] [ 0.003957] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ KERNEL] [ 0.004043] smp: Brought up 1 node, 4 CPUs
[ KERNEL] [ 0.004053] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ KERNEL] [ 0.004059] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.004065] CPU: Virtualization extensions available.
[ KERNEL] [ 0.004523] devtmpfs: initialized
[ KERNEL] [ 0.012732] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ KERNEL] [ 0.013024] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.013040] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 0.014547] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.015458] NET: Registered protocol family 16
[ KERNEL] [ 0.017321] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.021172] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.058204] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ KERNEL] [ 0.060322] vgaarb: loaded
[ KERNEL] [ 0.060786] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.060879] usbcore: registered new interface driver hub
[ KERNEL] [ 0.060964] usbcore: registered new device driver usb
[ KERNEL] [ 0.074055] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-10-21 16:47, variant start
[ KERNEL] [ 0.084023] raspberrypi-firmware soc:firmware: Firmware hash is 8c7c951122d2cae572e891f04ddf287078ff2f11
[ KERNEL] [ 0.095364] clocksource: Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.102793] NET: Registered protocol family 2
[ KERNEL] [ 0.103237] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ KERNEL] [ 0.103253] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.103306] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.103365] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.103462] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.103491] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.103623] NET: Registered protocol family 1
[ KERNEL] [ 0.103652] PCI: CLS 0 bytes, default 64
[ KERNEL] [ 1.816516] Initialise system trusted keyrings
[ KERNEL] [ 1.816692] workingset: timestamp_bits=30 max_order=20 bucket_order=0
[ KERNEL] [ 1.884132] Key type asymmetric registered
[ KERNEL] [ 1.884140] Asymmetric key parser 'x509' registered
[ KERNEL] [ 1.884203] bounce: pool size: 64 pages
[ KERNEL] [ 1.884260] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ KERNEL] [ 1.884269] io scheduler noop registered
[ KERNEL] [ 1.884406] io scheduler cfq registered (default)
[ KERNEL] [ 1.924913] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ KERNEL] [ 1.924932] brcm-pcie fd500000.pcie: could not get clock
[ KERNEL] [ 1.924977] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ KERNEL] [ 1.925005] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ KERNEL] [ 1.965385] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ KERNEL] [ 1.965651] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ KERNEL] [ 1.965666] pci_bus 0000:00: root bus resource [bus 00-01]
[ KERNEL] [ 1.965680] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ KERNEL] [ 1.965718] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ KERNEL] [ 1.965803] pci 0000:00:00.0: PME# supported from D0 D3hot
[ KERNEL] [ 1.968720] PCI: bus0: Fast back to back transfers disabled
[ KERNEL] [ 1.968736] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ KERNEL] [ 1.968948] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ KERNEL] [ 1.968995] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ KERNEL] [ 1.969114] pci 0000:01:00.0: PME# supported from D0 D3cold
[ KERNEL] [ 1.971937] PCI: bus1: Fast back to back transfers disabled
[ KERNEL] [ 1.971952] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ KERNEL] [ 1.971988] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ KERNEL] [ 1.972004] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ KERNEL] [ 1.972026] pci 0000:00:00.0: PCI bridge to [bus 01]
[ KERNEL] [ 1.972038] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ KERNEL] [ 1.972202] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ KERNEL] [ 1.972410] pcieport 0000:00:00.0: Signaling PME with IRQ 53
[ KERNEL] [ 1.972656] pcieport 0000:00:00.0: AER enabled with IRQ 53
[ KERNEL] [ 1.972889] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ KERNEL] [ 1.973367] bcm2708_fb soc:fb: FB found 1 display(s)
[ KERNEL] [ 1.989462] Console: switching to colour frame buffer device 210x65
[ KERNEL] [ 1.994511] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1680x1050
[ KERNEL] [ 1.996345] iproc-rng200 fe104000.rng: hwrng registered
[ KERNEL] [ 1.996528] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ KERNEL] [ 1.997091] vc-sm: Videocore shared memory driver
[ KERNEL] [ 1.997587] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ KERNEL] [ 1.998457] zram: Added device: zram0
[ KERNEL] [ 2.002811] libphy: Fixed MDIO Bus: probed
[ KERNEL] [ 2.003119] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ KERNEL] [ 2.003163] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ KERNEL] [ 2.055073] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ KERNEL] [ 2.055212] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
[ KERNEL] [ 2.055775] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ KERNEL] [ 2.055787] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.055797] usb usb1: Product: xHCI Host Controller
[ KERNEL] [ 2.055806] usb usb1: Manufacturer: Linux 4.19.80-v7l xhci-hcd
[ KERNEL] [ 2.055814] usb usb1: SerialNumber: 0000:01:00.0
[ KERNEL] [ 2.056286] hub 1-0:1.0: USB hub found
[ KERNEL] [ 2.056327] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 2.056707] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ KERNEL] [ 2.056732] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ KERNEL] [ 2.056767] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ KERNEL] [ 2.057066] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ KERNEL] [ 2.057081] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.057090] usb usb2: Product: xHCI Host Controller
[ KERNEL] [ 2.057103] usb usb2: Manufacturer: Linux 4.19.80-v7l xhci-hcd
[ KERNEL] [ 2.057112] usb usb2: SerialNumber: 0000:01:00.0
[ KERNEL] [ 2.057560] hub 2-0:1.0: USB hub found
[ KERNEL] [ 2.057601] hub 2-0:1.0: 4 ports detected
[ KERNEL] [ 2.058701] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 2.084257] dwc_otg fe980000.usb: base=(ptrval)
[ KERNEL] [ 2.284444] Core Release: 2.80a
[ KERNEL] [ 2.284455] Setting default values for core params
[ KERNEL] [ 2.284474] Finished setting default values for core params
[ KERNEL] [ 2.484764] Using Buffer DMA mode
[ KERNEL] [ 2.484771] Periodic Transfer Interrupt Enhancement - disabled
[ KERNEL] [ 2.484778] Multiprocessor Interrupt Enhancement - disabled
[ KERNEL] [ 2.484786] OTG VER PARAM: 0, OTG VER FLAG: 0
[ KERNEL] [ 2.484816] Dedicated Tx FIFOs mode
[ KERNEL] [ 2.485484] WARN::dwc_otg_hcd_init FIQ DMA bounce buffers: virt = f3866000 dma = 0x00000000f7548000 len=9024
[ KERNEL] [ 2.485507] FIQ FSM acceleration enabled for :
[ KERNEL] [ 2.485507] Non-periodic Split Transactions
[ KERNEL] [ 2.485507] Periodic Split Transactions
[ KERNEL] [ 2.485507] High-Speed Isochronous Endpoints
[ KERNEL] [ 2.485507] Interrupt/Control Split Transaction hack enabled
[ KERNEL] [ 2.485516] dwc_otg: Microframe scheduler enabled
[ KERNEL] [ 2.485569] WARN::hcd_init_fiq:457: FIQ on core 1
[ KERNEL] [ 2.485585] WARN::hcd_init_fiq:458: FIQ ASM at c04fb97c length 36
[ KERNEL] [ 2.485600] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
[ KERNEL] [ 2.485633] dwc_otg fe980000.usb: DWC OTG Controller
[ KERNEL] [ 2.485660] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[ KERNEL] [ 2.485686] dwc_otg fe980000.usb: irq 37, io mem 0x00000000
[ KERNEL] [ 2.485732] Init: Port Power? op_state=1
[ KERNEL] [ 2.485739] Init: Power Port (0)
[ KERNEL] [ 2.485890] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ KERNEL] [ 2.485902] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.485911] usb usb3: Product: DWC OTG Controller
[ KERNEL] [ 2.485921] usb usb3: Manufacturer: Linux 4.19.80-v7l dwc_otg_hcd
[ KERNEL] [ 2.485930] usb usb3: SerialNumber: fe980000.usb
[ KERNEL] [ 2.486383] hub 3-0:1.0: USB hub found
[ KERNEL] [ 2.486417] hub 3-0:1.0: 1 port detected
[ KERNEL] [ 2.486996] dwc_otg: FIQ enabled
[ KERNEL] [ 2.487002] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 2.487008] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 2.487019] Module dwc_common_port init
[ KERNEL] [ 2.487347] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 2.488131] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ KERNEL] [ 2.488298] bcm2835-cpufreq: min=600000 max=1500000
[ KERNEL] [ 2.488799] sdhci: Secure Digital Host Controller Interface driver
[ KERNEL] [ 2.488805] sdhci: Copyright(c) Pierre Ossman
[ KERNEL] [ 2.489180] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ KERNEL] [ 2.489446] sdhci-pltfm: SDHCI platform and OF driver helper
[ KERNEL] [ 2.489870] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 2.490245] usbcore: registered new interface driver usbhid
[ KERNEL] [ 2.490249] usbhid: USB HID core driver
[ KERNEL] [ 2.490826] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ KERNEL] [ 2.492129] [vc_sm_connected_init]: start
[ KERNEL] [ 2.501479] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 2.501954] NET: Registered protocol family 17
[ KERNEL] [ 2.502050] Registering SWP/SWPB emulation handler
[ KERNEL] [ 2.502298] Loading compiled-in X.509 certificates
[ KERNEL] [ 2.505121] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ KERNEL] [ 2.505543] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ KERNEL] [ 2.505823] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ KERNEL] [ 2.505827] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ KERNEL] [ 2.531382] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ KERNEL] [ 2.547957] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ KERNEL] [ 2.549492] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.551138] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.553897] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ KERNEL] [ 2.555889] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.563342] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ KERNEL] [ 2.563529] of_cfs_init
[ KERNEL] [ 2.563592] of_cfs_init: OK
[ KERNEL] [ 2.587263] Freeing unused kernel memory: 6144K
[ KERNEL] [ 2.623914] random: fast init done
[ KERNEL] [ 2.651345] Run /init as init process
[ KERNEL] [ 2.651918] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ KERNEL] [ 2.653510] mmc1: new high speed SDIO card at address 0001
[ KERNEL] [ 2.696421] mmc0: new ultra high speed DDR50 SDHC card at address 0007
[ KERNEL] [ 2.696771] mmcblk0: mmc0:0007 SD32G 28.8 GiB
[ KERNEL] [ 2.697761] mmcblk0: p1
[ hotplug] [ 2.694092] Block device 179:0. No action.
[ hotplug] [ 2.694131] Block device 179:1. No action.
[ KERNEL] [ 2.836538] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ KERNEL] [ 2.836543] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ KERNEL] [ 2.836547] usb 1-1: Product: USB2.0 Hub
[ KERNEL] [ 2.837869] hub 1-1:1.0: USB hub found
[ KERNEL] [ 2.838132] hub 1-1:1.0: 4 ports detected
[ hotplug] [ 2.915469] Block device 254:0. No action.
[ pfac] [ 2.955193] Run /sbin/initrd.
[ pfac] [ 2.955449] Ok, PID 755.
[ initrd] [ 2.960563] WTware 5.8.72/RPi shell.
[ initrd] [ 2.960868] Load font 'ter-c32b.psf', console 105x32.
[ initrd] [ 2.976439] HDD/MMC/SD boot.
[ KERNEL] [ 2.995587] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ KERNEL] [ 3.025890] usb 2-1: New USB device found, idVendor=0424, idProduct=5744, bcdDevice= 2.86
[ KERNEL] [ 3.025902] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ KERNEL] [ 3.025912] usb 2-1: Product: USB5744
[ KERNEL] [ 3.025922] usb 2-1: Manufacturer: Microchip Tech
[ KERNEL] [ 3.028088] hub 2-1:1.0: USB hub found
[ KERNEL] [ 3.028158] hub 2-1:1.0: 2 ports detected
[ KERNEL] [ 3.155393] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
[ KERNEL] [ 3.286024] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2744, bcdDevice= 2.86
[ KERNEL] [ 3.286036] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 3.286046] usb 1-1.1: Product: USB2744
[ KERNEL] [ 3.286056] usb 1-1.1: Manufacturer: Microchip Tech
[ KERNEL] [ 3.287355] hub 1-1.1:1.0: USB hub found
[ KERNEL] [ 3.287427] hub 1-1.1:1.0: 4 ports detected
[ KERNEL] [ 4.015398] usb 1-1.1.3: new low-speed USB device number 4 using xhci_hcd
[ KERNEL] [ 4.155243] usb 1-1.1.3: New USB device found, idVendor=413c, idProduct=2107, bcdDevice= 1.15
[ KERNEL] [ 4.155255] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 4.155264] usb 1-1.1.3: Product: Dell USB Entry Keyboard
[ KERNEL] [ 4.155274] usb 1-1.1.3: Manufacturer: Dell
[ KERNEL] [ 4.163279] input: Dell Dell USB Entry Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/0003:413C:2107.0001/input/input0
[ KERNEL] [ 4.226418] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-0000:01:00.0-1.1.3/input0
[ KERNEL] [ 4.345387] usb 1-1.1.4: new low-speed USB device number 5 using xhci_hcd
[ KERNEL] [ 4.482041] usb 1-1.1.4: New USB device found, idVendor=0461, idProduct=4d81, bcdDevice= 2.00
[ KERNEL] [ 4.482053] usb 1-1.1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ KERNEL] [ 4.482063] usb 1-1.1.4: Product: USB Optical Mouse
[ KERNEL] [ 4.491358] input: USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.4/1-1.1.4:1.0/00034D81.0002/input/input1
[ KERNEL] [ 4.491698] hid-generic 00034D81.0002: input,hidraw1: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:01:00.0-1.1.4/input0
[ initrd] [ 4.792577] Success: /dev/mmcblk0p1 mounted to /bootmedia.
| #hdmi_enable_4kp60=1
| #hdmi_enable_4k=1
| core_freq_min=500
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=2
| #hdmi_mode=81
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| #gpu_mem_1024=256
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| [pi4]
| max_framebuffers=2
| [all]
| #hdmi_group=2
| #hdmi_mode=58
| # 800x600: hdmi_mode=9
| # 1024x768: hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768: hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900: hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768: hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| #[HDMI:0]
| # hdmi_group=2
| # hdmi_mode=42
| #[HDMI:1]
| # hdmi_group=2
| # hdmi_mode=58
| hdmi_group=2
| hdmi_mode=58
[ initrd] [ 4.836501] Do not cache package files.
[ initrd] [ 4.836600] WTpassword present: c4e1bc6d19f9f2d258c1ee33d89e471a.
[ initrd] [ 4.868389] USB: 0424:5744 Standard Microsystems Corp. Hub.
[ initrd] [ 4.868444] USB: 0424:2744 Standard Microsystems Corp. Hub.
[ initrd] [ 4.868478] USB: 2109:3431 VIA Labs, Inc. Hub.
[ initrd] [ 4.868520] USB: 413c:2107 Dell Computer Corp..
[ initrd] [ 4.868554] USB: 0461:4d81 Primax Electronics, Ltd Dell N889 Optical Mouse.
| clientIP=10.30.81.250
| config=local
| setupPassword=c4e1bc6d19f9f2d258c1ee33d89e471a
| netmedia=ethernet
| routerIP=10.30.81.254
| nameserverIP=10.30.80.50
[ initrd] [ 6.732152] Load Ethernet drivers.
[ initrd] [ 6.732244] modprobe genet.
[ KERNEL] [ 6.745065] bcmgenet fd580000.genet: failed to get enet clock
[ KERNEL] [ 6.745081] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ KERNEL] [ 6.745098] bcmgenet fd580000.genet: failed to get enet-wol clock
[ KERNEL] [ 6.745117] bcmgenet fd580000.genet: failed to get enet-eee clock
[ KERNEL] [ 6.745137] bcmgenet: Skipping UMAC reset
[ KERNEL] [ 6.745471] unimac-mdio unimac-mdio.-19: DMA mask not set
[ KERNEL] [ 6.765364] libphy: bcmgenet MII bus: probed
[ KERNEL] [ 6.808424] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ KERNEL] [ 6.810925] bcmgenet: Skipping UMAC reset
[ KERNEL] [ 6.925672] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ KERNEL] [ 8.005534] bcmgenet fd580000.genet eth0: Link is Down
[ KERNEL] [ 12.165512] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control off
[ initrd] [ 12.228724] WTpassword present: c4e1bc6d19f9f2d258c1ee33d89e471a.
[ pfac] [ 12.230487] Run /sbin/httpd.
[ initrd] [ 12.230543] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[ pfac] [ 12.230652] Ok, PID 810.
[ initrd] [ 12.230708] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[ initrd] [ 12.231724] Common local disk config:
| #turnoffmenu=on
| #connection
| #displayname=CCTV Server
| #server=10.33.80.1
| #usb=068e:00ca
| server=10.30.81.110
| user=
| onerror = quiet
| vhusb = on
| vhusb = UseAVAHI
| vhusb = 068e:00ca
| redraw_delay=100
| scale_factor = 100
| bpp = 32
| #graphic = abcdefg
| #bpp=32
| #connection
| #displayname=Enter server address
| #server=--new--
| onerror=quiet
| vhusb=068e:00ca
| redraw_delay=100
| bpp=32
| displayName=JUNWS003
| server=10.30.81.110
| user=
| scale_factor=100
[ initrd] [ 12.233638] Hostname: "wtwDCA6322F3FD9".
[ initrd] [ 12.233736] [NTP] 42 DHCP option is not set.
[ httpd] [ 12.239106] Internal HTTP Server, WTware 5.8.72/RPi
[ httpd] [ 12.248595] Reread settings.
[ initrd] [ 12.248705] Unpack /bootmedia/packages/pi2-f.
[ httpd] [ 12.248819] Everyone can control terminal by HTTP.
[ KERNEL] [ 12.381416] random: crng init done
[ gm] [ 12.378583] WTware 5.8.72/RPi session manager.
[ gm] [ 12.440114] EV_REL flag found. Add mouse event1: USB Optical Mouse.
[ gm] [ 12.440215] Add keyboard event0: Dell Dell USB Entry Keyboard.
[ gm] [ 12.440303] Display mode: 1680x1050, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 12.730921] Framebuffer device found.
[ gm] [ 12.730967] LINELENBYTES 3360
[ gm] [ 12.731001] VLEN 3528000
[ gm] [ 12.732030] Use /lib/ui16.so.
[ gm] [ 12.744496] Copy /bootmedia/configs/vhusbdarm to /vh/vhusbdarm.
| UseAVAHI=0
[ gm] [ 12.755249] Run '/vh/vhusbdarm -b -c /vh/config.ini -r /tmp/vh.out', log '', env '', pid ''.
[ pfac] [ 12.755311] Run /vh/vhusbdarm -b -c /vh/config.ini -r /tmp/vh.out.
[ pfac] [ 12.755440] Ok, PID 812.
[ VirtualHere] [ 12.808827] Wed Oct 23 00:00:10 2019 LOG_INFO >>> Starting VirtualHere USB Server v4.0.5 (Built: Oct 18 2019, 17:41:59)<<<
[ VirtualHere] [ 12.808868] Wed Oct 23 00:00:10 2019 LOG_INFO Using configuration /vh/config.ini
[ pfac] [ 12.809222] Process pid 812 terminated, status 00000000.
[ gm] [ 12.814516] Run '/sbin/resolver 0x1f5df20 dns [10.30.81.110]', log '', env '', pid ''.
[ pfac] [ 12.814569] Run /sbin/resolver 0x1f5df20 dns [10.30.81.110].
[ pfac] [ 12.814666] Ok, PID 814.
[ gm] [ 12.814716] Nobody can control terminal by VNC.
[ gm] [ 12.816987] 10.30.81.110 => 10.30.81.110.
[ pfac] [ 12.817136] Process pid 814 terminated, status 00000000.
[ gm] [ 12.819991] Free ram before fork terminal client /sbin/rdpclient (session 1): 3942636 Kb.
[ pfac] [ 12.820049] Run /sbin/rdpclient 1.
[ gm] [ 12.820069] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 12.820176] Ok, PID 815.
[ rdpclient 815] [ 12.825128] RDP Terminal Client, WTware 5.8.72/RPi, pipe 1, pid 815.
[ rdpclient 815] [ 12.825491] Use /lib/ui16.so.
[ rdpclient 815] [ 12.826536] Make RDP session with 10.30.81.110, port 3389.
[ rdpclient 815] [ 12.826684] Username: "xxxx".
[ rdpclient 815] [ 12.826779] Password: present.
[ rdpclient 815] [ 12.826823] No PIN.
[ rdpclient 815] [ 12.826866] No domain.
[ rdpclient 815] [ 12.826913] No shell.
[ rdpclient 815] [ 12.826954] No directory.
[ rdpclient 815] [ 12.826997] Window: 1616x1050@16.
[ rdpclient 815] [ 12.827034] PFlags 0x0000002F.
[ rdpclient 815] [ 12.827089] Keyboard 00000409:00000000.
[ rdpclient 815] [ 12.827133] My hostname "wtwDCA6322F3FD9".
[ rdpclient 815] [ 12.827178] TCP: connecting to 10.30.81.110:3389.
[ rdpclient 815] [ 12.830078] TCP: connection with 10.30.81.110:3389 established.
[ rdpclient 815] [ 12.830141] Turn keepalive on.
[ rdpclient 815] [ 12.830710] Free ram after buffers allocation: 3942384 KB.
[ rdpclient 815] [ 12.849113] Reconnect with NLA enabled.
[ rdpclient 815] [ 12.849198] TCP: reconnecting to 10.30.81.110:3389.
[ rdpclient 815] [ 12.850715] TCP: connection with 10.30.81.110:3389 established.
[ rdpclient 815] [ 12.850770] Turn keepalive on.
[ rdpclient 815] [ 12.864472] Server supports GFX Pipeline.
[ rdpclient 815] [ 12.864540] NLA.
[ rdpclient 815] [ 12.864591] SSL/TLS.
[ VirtualHere] [ 12.876102] Wed Oct 23 00:00:10 2019 LOG_INFO Server licensed to=unlicensed max_devices=1
[ VirtualHere] [ 12.876238] Wed Oct 23 00:00:10 2019 LOG_INFO Using large URB's
[ VirtualHere] [ 12.877310] Wed Oct 23 00:00:10 2019 LOG_INFO Listening on all network interfaces at TCP port 7575
[ rdpclient 815] [ 12.945798] Enable font smoothing and Desktop Composition.
[ rdpclient 815] [ 13.191362] GFX codec.
[ rdpclient 815] [ 14.435033] Run 4 tile threads.
[ rdpclient 815] [ 14.499703] errorInfo 0x00000000.
[ rdpclient 815] [ 14.859257] SessionId 0x00000002: xxxx.
| #hdmi_enable_4k=1
| core_freq_min=500
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_group=2
| #hdmi_mode=81
| #hdmi_drive=2
| # no display.
| #arm_freq=800
| disable_splash=1
| #gpu_mem_1024=256
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| [pi4]
| max_framebuffers=2
| [all]
| #hdmi_group=2
| #hdmi_mode=58
| #[HDMI:0]
| # hdmi_group=2
| # hdmi_mode=42
| #[HDMI:1]
| # hdmi_group=2
| # hdmi_mode=58
| hdmi_group=2
| hdmi_mode=58
| config=local
| netmedia=ethernet
| #turnoffmenu=on
| #connection
| #server=10.33.80.1
| #usb=068e:00ca
| server=10.30.81.110
| user=
| onerror = quiet
| vhusb = on
| vhusb = UseAVAHI
| vhusb = 068e:00ca
| redraw_delay=100
| scale_factor = 100
| bpp = 32
| #graphic = abcdefg
| #bpp=32
| #connection
| #server=--new--
| onerror=quiet
| vhusb=068e:00ca
| redraw_delay=100
| bpp=32
| server=10.30.81.110
| user=
| scale_factor=100
| UseAVAHI=0
@aka
Any ideas or anything to try?
thank you
thank you
Try wtware version 5.8.78. Show me the same log if it still doesn't work. Real color depth is in the end of the log, line:
thank you Aka - this seems to have helped with the new version
