Restart option in menu
chad
Post by chad »
Is there an option to add a restart item in the menu. Using the turnoffmenu=on, this adds a Turn OFF the computer menu option, but it would be nice to allow the user to restart as well. Essentially, if I make a change to the config file for a particular unit, it needs to be restarted for those changes to take affect. Yes I can do it remotely, but if a user is in the middle of something, it would be beneficial for me to call them up and tell them to restart when they are finished doing whatever they are doing so that the updated config gets pushed to their computer.
Re: Restart option in menu
With current version such config should work:
connection
server=192.169.1.1
connection
application=shutdown
It adds "shutdown" to menu.
If we make reboot in the same way as shutdown, will it be ok for you?
chad
Post by chad »
Yes that would be great, make it the same as shutdown
duri3
Post by duri3 »
I also need a reboot option in infobox. The parameter infobox = reboot instead of infobox = shutdown would be perfect! Will it be in the next update?
duri3
Post by duri3 »
duri3 wrote: Fri Jul 13, 2018 3:55 pm I also need a reboot option in infobox. The parameter infobox = reboot instead of infobox = shutdown would be perfect! Will it be in the next update?
Any updates on this "request"? Any ETA?
Fraal
Post by Fraal »
Just be aware that currently when using a RPi 3+ and booting from network (NO SD), cold restarts or menu based restart commands reset it ok but it then never boots, TFTP fails and strange timeouts occur. A hard reset is required to resume.
Not sure if this is a firmware limitation on the B+, the original RPi 3 Model B never had this issue.
duri3
Post by duri3 »
We boot from SD Card, so no problems there iI guess. Just need that option in Wtware to get started....
Please try this build:
http://wtware.com/testing/201808031706.zip
Button in popup window:
infobox = reboot
Menu item:
connection
connection
application=reboot
duri3
Post by duri3 »
It tried it now and it's working.
i just replaced
infobox = shutdown
with
infobox = reboot
We don't use
application=reboot
since it won't work in combination with chrome.
Thank you very much!
chad
Post by chad »
Has this been added to the most recent build version 5.8.26, or is it just in the testing zip that is provided here?
This has been added to all versions released after testing zip
