J1mbo
Posts: 57 Joined: Mon Mar 14, 2016 6:24 pm
Post
by J1mbo » Fri May 13, 2016 3:50 pm
We noticed that RDP audio isn't working with 5.4.30 (was working with Pi3 beta, 5.4.18 based I think). Logs show this:
usbcore: registered new interface driver snd-usb-audio
hardware.cpp ( 1095): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
globalConfig.cpp ( 1631): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
ERROR: Sound card not found. Disable sound.
J1mbo
Post
by J1mbo » Fri May 13, 2016 4:59 pm
Here is the (working) log from 5.4.18:
Unpack /bootmedia/packages/pi2-alsa.
[ gm] [ 12.454845] modprobe snd-bcm2835.
[ gm] [ 12.466010] modprobe snd-usb-audio.
| 0: [ 0] : control
| 16: [ 0- 0]: digital audio playback
| 17: [ 0- 1]: digital audio playback
| 33: : timer
[ KERNEL] [ 12.478037] usbcore: registered new interface driver snd-usb-audio
[ gm] [ 12.478336] /dev/snd/pcmC0D1p character device.
[ gm] [ 12.478393] /dev/snd/pcmC0D0p character device.
[ pfac] [ 12.478449] Run /sbin/rdpsnd sndvol 100 100 50.
[ gm] [ 12.478473] /dev/snd/controlC0 character device.
[ gm] [ 12.478516] /dev/snd/timer character device.
[ pfac] [ 12.478580] Ok, PID 594.
[ gm] [ 12.478611] Preconfigure ALSA.
[ pfac] [ 12.478676] Run /sbin/rdpsnd 1 0 100 0 -1.
[ gm] [ 12.478712] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[ pfac] [ 12.478777] Ok, PID 595.
[ gm] [ 12.478800] Run sound daemon.
[ gm] [ 12.478840] Run '/sbin/rdpsnd 1 0 100 0 -1', log '', env '', pid ''.
[ rdpsnd] [ 12.480915] RDP Sound Redirector, WTware v.5.4.18/Pi2.
[ rdpsnd] [ 12.484249] Card 'ALSA'/'bcm2835 ALSA'.
[ rdpsnd] [ 12.484378] Mixer name: 'Broadcom Mixer'.
[ sndvol] [ 12.484447] Card 'ALSA'/'bcm2835 ALSA'.
[ rdpsnd] [ 12.484472] Components: ''.
[ sndvol] [ 12.484513] Mixer name: 'Broadcom Mixer'.
[ sndvol] [ 12.484554] Components: ''.
[ sndvol] [ 12.484594] Controls: 6.
[ sndvol] [ 12.484634] ALSA: control 'PCM Playback Volume'.
[ sndvol] [ 12.484675] ALSA: control 'PCM Playback Switch'.
[ sndvol] [ 12.484715] ALSA: control 'PCM Playback Route'.
[ sndvol] [ 12.484756] ALSA: control 'IEC958 Playback Default'.
[ sndvol] [ 12.484796] ALSA: control 'IEC958 Playback Con Mask'.
[ sndvol] [ 12.484837] ALSA: control 'IEC958 Playback PCM Stream'.
[ sndvol] [ 12.484877] Inactive control IEC958 Playback PCM Stream'.
[ rdpsnd] [ 12.484945] Controls: 6.
[ rdpsnd] [ 12.485046] ALSA: control 'PCM Playback Volume'.
[ rdpsnd] [ 12.485093] ALSA: control 'PCM Playback Switch'.
[ rdpsnd] [ 12.485136] ALSA: control 'PCM Playback Route'.
[ rdpsnd] [ 12.485177] ALSA: control 'IEC958 Playback Default'.
[ rdpsnd] [ 12.485218] ALSA: control 'IEC958 Playback Con Mask'.
[ rdpsnd] [ 12.485258] ALSA: control 'IEC958 Playback PCM Stream'.
[ rdpsnd] [ 12.485298] Inactive control IEC958 Playback PCM Stream'.
Posts: 939 Joined: Fri Dec 03, 2004 2:05 pm
Post
by aka » Sun May 15, 2016 2:19 pm
Onboard sound at RPi should be enabled in config.txt at SD card now.
J1mbo
Post
by J1mbo » Tue May 17, 2016 12:46 pm
Thanks, so it is:
dtparam=audio=on
kmen
Posts: 2 Joined: Thu May 26, 2016 10:30 am
Post
by kmen » Thu May 26, 2016 11:29 am
and the sound option should be on?
sound=on
J1mbo
Post
by J1mbo » Thu May 26, 2016 11:46 am
Yes. To edit config.txt, you can use a browser, http://[terminal-ip]/
mstorck
Posts: 1 Joined: Mon Aug 15, 2016 1:35 am
Post
by mstorck » Mon Aug 15, 2016 1:43 am
I have set
in configuration file. I also set
in config.txt and finally I also set
in config.txt. But I still have these log entries:
[ gm] [ 77.376233] Unpack /bootmedia/packages/pi2-alsa.
[ gm] [ 77.426514] modprobe snd-bcm2835.
[ gm] [ 77.435422] modprobe snd-usb-audio.
[ KERNEL] [ 77.453718] usbcore: registered new interface driver snd-usb-audio
[ gm] [ 92.457032] hardware.cpp ( 1095): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 92.457184] globalConfig.cpp ( 1624): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 92.457267] ERROR: Sound card not found. Disable sound.
and of course no audio/sound within an RDP session.
I'm running
on RPi3.
Another ThinClient OS for RPi has working sound on the same hardware.
Any ideas to get this working with WTware?
Post
by aka » Mon Aug 15, 2016 11:34 pm
Please, send me whole log and all files on SD in zip to
aka@pxe.ru
nhelder
Posts: 1 Joined: Thu Oct 20, 2016 3:09 am
Post
by nhelder » Tue Oct 25, 2016 6:41 am
Hi, all~
I came across this thread as I was having issues getting audio out of the audio jack for my Pi3 when running WTware.
The eventual combination of settings that did the trick for me, in the config.txt file, were:
# hdmi_drive result
# 1 Normal DVI mode (No sound)
# 2 Normal HDMI mode (Sound will be sent if supported and enabled)
hdmi_drive=1
# Setting this to 1 pretends that all audio formats are unsupported by the display.
# This means ALSA will default to the analogue audio (headphone) jack.
hdmi_ignore_edid_audio=1
dtparam=audio=on
# Enable improved audio driver
# https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=136445
audio_pwm_mode=2
...just thought I would share for others that might run in to a similar issue.
- Nathan
P.S. For completeness, my config file looks simply like:
server=--new--
graphic=adf
sound=on
sound_rate=44100
sleep=20
connect_timeout=5
connection
