I am using this USB SOUND CARD for configuring my VoIP (Elastix):
https://http2.mlstatic.com/adaptador-so ... 2015-F.jpg
From the terminal i can dial and receive callings, but i can just hear audio. The microphone is not working on the terminal (it has been tested in other devices, and it works fine). I am using Windows Server 2012R2 and all the configurations are correct in Server Side (the microphone redirection has been tested from mstsc.exe and it works fine)
My scenario:
CONFIG FILE:
server=192.168.0.100
turnoffmenu=always
sound=on
skin=sample
SIP=1000:Fdcnhs0505!@192.168.0.19
microphone=on
microphone_level=100
connection
CONFIG.TXT (I didnt uncomment the dtparam line once i am using a USB Sound Card)
#dtparam=audio=on
I've tried using USB redirection ("usb = 1234:AB67" parameter), and also tried "sound=remote" in Config File. None of the combinations seems to work.
I've just attached my log, so i hope it could helps us find the problem.
Thank you !
USB SOUND CARD - Elastix. Microphone not working (RPI3)
- log.txt
- (35.41 KiB) Downloaded 876 times
Last edited by estefano.peroza on Tue Dec 06, 2016 2:39 pm, edited 1 time in total.
Re: USB SOUND CARD - Elastix. Microphone not working
There is no sound mixer in wtware. So only one application can use sound and microphone. While using local sip with SIP=, do not redirect sound into RDP session with use sound= and microphone=.
