Please suggest me a valid smartcard reader.
I can'y figure out using a Smartcard reader..
I tried to many kind of hardware but no one is redirected..
can you suggest me some model that is certly tested and functional?
meybe on amazon..
meybe on amazon..
Re: Please suggest me a valid smartcard reader.
In this manual there's the list of supported smartcards:
http://wtware.com/docs5/config.html#smartcard
If any smartcard from this list doesn't work. specify in configuration file:
Then save and send us terminal log file:
http://wtware.com/logs.html
smartcard=<cardname>,debug
So, I think there is definitely a problem with software or drivers..
I bought this smartcard reader:
http://amzn.eu/3dmgOpO
But the result is the same. The certificate card for digital signatures is not read.
Attached here are the logs,
please help
please help
- WTware_log smartcard_readeer.txt
- (117.83 KiB) Downloaded 527 times
Yesonit wrote:..there is definitely a problem with software or drivers..
http://wtware.com/docs5/smartcard.htmlonit wrote:I bought this smartcard reader:
Read from "If yes, let's start:" and send me new log.
I will collect logs again in my next post..
But I already wrote you another mail with other log in 25 May... It was a not supported reader.
and no answer..
Now It's a supported hardware (omnikey 3021), so Where is the problem? The card?
and no answer..
here we are with the logs (you also have an eMail..)
waiting for a feedback
thanks
thanks
- LogsReaderOmnikey3021.zip
- (22.35 KiB) Downloaded 436 times
It is not 3021. Don't believe letters on box. Device itself says it is "OMNIKEY 3x21 Smart Card Reader":
And libccid (linux smart card driver) says "idVendor: 0x076B idProduct: 0x3031" is "OMNIKEY 3x21 Smart Card Reader".
usb 1-1.2: new full-speed USB device number 4 using dwc_otg
usb 1-1.2: New USB device found, idVendor=076b, idProduct=3031
usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.2: Product: OMNIKEY 3x21 Smart Card Reader
usb 1-1.2: Manufacturer: HID Global
Thanks akatik for your reply,
So, Now It's a real problem for me..
in the past 25 may I send you log saying:
and ezzccid - EZCCID, EZ100PU is in your copatibility list...
Now I bought a Omnikey 3021 (It's write in the device and in the Box..) but it's not comptible... (cause wtware say 3x21 is different..
So.. we come back to my first question...
and where to buy them?
Thanks in advance.
gm] [ 11.438312] Run scard daemon. Supported cards:
[ gm] [ 11.438436] EZCCID, EZ100PU.
[ gm] [ 11.447204] Run '/sbin/rdpdr[scard] 0', log '/tmp/rdpdr[scard].out', env '', pid ''.
Thanks in advance.
Please, try this build with http://amzn.eu/3dmgOpO device:
http://pxe.ru/files/testing/201708111620.zip
In config:
In config:
smartcard=omni3x21,debug
Send it once more, please. With recent wtware version.onit wrote:..in the past 25 may I send you log saying:
IT WORKS !!!aka wrote:Please, try this build with http://amzn.eu/3dmgOpO device:
In config:
Question: WTWARE CONFIGURATOR write
smartcard=omni3021,debug
It's correct to edit and write 3x21 or it's the same ?
Here we are.akatik wrote:Send it once more, please. With recent wtware version.onit wrote:..in the past 25 may I send you log saying:
Log attached here and sent via mail
- LogsReaderEZ100PU.zip
- (14.19 KiB) Downloaded 396 times
