Raspberry Pi 3
lctronico
Re: Raspberry Pi 3
Postby lctronico » Thu Apr 07, 2016 12:36 am
I wonder if I can use up to 5 Pi and get them connected to the same server without kick the others out.
Kind of terminal services but having no problems with microsoft licences.
Please let me know.
Thanks.
Re: Raspberry Pi 3
Postby aka » Fri Apr 08, 2016 9:00 am
Please, tell me in more words what do you mean by this. What is the difference between your wish and terminal services?
hbbst
Re: Raspberry Pi 3
Postby hbbst » Mon Apr 11, 2016 10:45 am
Hi Aka,
please calm me down. :)
If I buy Raspberry 3, will you release a working version in this month? Wifi driver is not necessary, I will use only LAN.
Re: Raspberry Pi 3
Postby aka » Mon Apr 11, 2016 11:13 am
We will. And jpxdude выше писал "This is working pretty much the same as it did for the Pi 2, which is great." So it already should work.
hbbst
Re: Raspberry Pi 3
Postby hbbst » Wed Apr 13, 2016 1:35 pm
Hi Aka,
I have Pi2 and Pi3 in network. When you release the new firmware I hope both of them can boot from network (from the same TFTP) so your firmware will recognise the hardware. :?
hbbst
Re: Raspberry Pi 3
Postby hbbst » Thu Apr 21, 2016 10:38 pm
Hi Aka,
please say something, I haven't heard about you for "ages" :-) Did you find the solution for Pi3? Thanks!
Re: Raspberry Pi 3
Postby aka » Fri Apr 22, 2016 3:43 pm
Yeeeees. Version with network boot for PI3 well be very soon.
Thitiphan
Re: Raspberry Pi 3
Postby Thitiphan » Wed Apr 27, 2016 4:45 pm
Hi AKA , Can you tell me, if version 5.4.26 support PI3.
Re: Raspberry Pi 3
Postby aka » Thu Apr 28, 2016 8:06 am
Yes!
OrdH
Re: Raspberry Pi 3
Postby OrdH » Fri Apr 29, 2016 8:09 am
Hi guys,
thanks for the quick implementation efforts to Raspberry Pi 3.
Is the Version 5.4.26, April 24, 2016 working on RPI3 now? I couldn't find anything on the website.
Thanks in advance.
Re: Raspberry Pi 3
Postby aka » Sun May 01, 2016 9:09 am
The version 5.4.26, April 24, 2016 is working on RPI3. We've just updated information on our site.
hbbst
Re: Raspberry Pi 3
Postby hbbst » Tue May 03, 2016 9:56 am
Hi Aka,
maybe it's my fault, but I don't find wifi settings in RPi3. Does it work? When I enter setup I don't see any settings for network and I see only MAC address of LAN.
Re: Raspberry Pi 3
Postby aka » Tue May 03, 2016 4:25 pm
When WTware terminal boots from hard disk or USB flash press Del during boot (when you see "Press Del to enter Setup"), goto terminal management menu and select item "Network Media". Change it from Ethernet to WiFi.
Guest
Re: Raspberry Pi 3
Postby Guest » Tue May 17, 2016 7:37 pm
Been playing around with 5.4.26 on Pi3 for a while now, so far it's pretty stable, everything working fine. One thing I did notice was the perfomance on WiFi. I did expect a lower perfomance than connecting an ethernet cable, but turns out I have a better perfomance using a USB wifi adapter (such as the Encore N150 dongle) than the onboard raspberry wifi.
Maybe its because of its tiny onboard antenna, I dont know. I did test with an open wifi SSID (no encrypt) and results were the same. Its workable, but far worse than cable connection.
Anyone seeing this behavior?
J1mbo
Re: Raspberry Pi 3
Postby J1mbo » Wed May 18, 2016 10:57 am
It is a well documented problem with RPi3 WiFi - the kernel device power management causes the poor performance. I believe in Rasbian this is now disabled for the WiFi card by default.
Who is online
Users browsing this forum: aka and 1 guest
