Terminal PC sound
pakwichek
Terminal PC sound
Postby pakwichek » Tue Jul 25, 2006 8:59 am
Everything else works perfect, except Terminal PC sound not being redirected as expected. Terminal PC has ES1869 Plug and Play AudioDrive Sound card by ESS Technologies. Is this not supported.
I will like to add that, this same Terminal PC, with this sound card works fine when I run windows 2000 on it and remote Desktop to windows 2003 Terminal Server. Sound is re-directed to my local terminal PC. That is what I want but won't work same with I boot and run WTWare Pro OS on it? I know it is not Windows 2003 Terminal Server configuration since I have enabled sound re-direction and tested to work with windows 2000 client PC
BTW, I added the following lines in the configuration file as per documentation :
Sound=ON
Sound=Remote
Is this a limitation or some settings I am missing something
PLEASE HELP. I AM DESPERATE.
Return to “Other”
Who is online
Users browsing this forum: Baidu [Spider] and 1 guest
