keyboard language Problem
Wouwie
Re: keyboard language Problem
Postby Wouwie » Wed Feb 08, 2017 1:43 pm
Do you have this for Belgium Period, Dutch?
Postby aka » Wed Feb 08, 2017 4:38 pm
What is it?
wouwie
Postby wouwie » Wed Feb 08, 2017 6:28 pm
Dutch Azerty Belgium period keyboard layout
https://commons.wikimedia.org/wiki/File ... yboard.svg
Postby aka » Fri Feb 10, 2017 10:44 am
Is it right layout?
http://ascii-table.com/keyboard.php/120
No, wtware doesn't support it now. We can add it if you are ready to test several builds and send us a logs.
wouwie
Postby wouwie » Fri Feb 10, 2017 1:49 pm
Yes, that is the correct layout.
I'd be glad to test it.
This would probably also fix qwerty in chrome modus?
Postby aka » Sun Feb 12, 2017 2:36 am
Please, try wtware 5.4.76.
For login/password in WTware interface:
language = fr-be
For chrome:
chrome_language = fr-be
wouwieke
Postby wouwieke » Mon Feb 13, 2017 11:01 am
Thank you, that's perfect!
Except for the name. There are two languages in Belgium: Ducht (nl) and French (fr)
This is the nl-be layout (the one I need) but you named it fr-be.
Some keys are different like the @ and the !
So just rename it and everybody happy!
Postby aka » Mon Feb 13, 2017 12:53 pm
"Description belgian (french) keyboard layout"
"French (Belgium, Luxembourg)"
https://github.com/bgse/atom-keyboard-l ... /README.md
"Belgian French (fr_BE)" - same as my fr-be, image:
https://upload.wikimedia.org/wikipedia/ ... layout.png
Is there an image where it called nl, not fr?
wouwieke
Postby wouwieke » Mon Feb 13, 2017 1:17 pm
I thought this one was the French layout:
https://en.wikipedia.org/wiki/File:Fren ... yboard.svg
This one is not the one we use in Belgium.
It does not work for Chrome, stays in qwerty
Postby aka » Mon Feb 13, 2017 2:35 pm
This is French: http://ascii-table.com/keyboard.php/189
In WTware, language=fr, but seems it is not correct, need someone with this keyboard to test.
And there is French (Switzerland): http://ascii-table.com/keyboard.php/150F
In WTware, language=fr-ch.
netsuprema
Postby netsuprema » Tue Mar 07, 2017 5:36 pm
I am using thinclient to connect to a server that is running Fedora22, I am having trouble recognizing the abnt2 keyboard, it has some characters that are not recognized, such as: Ç, ^, ~, and others.
Keyboard example:
http://s2.glbimg.com/hlQMZ_E87B3DB_96rV ... ilsvg_.png
Postby akatik » Wed Apr 05, 2017 8:04 am
netsuprema
1. Install and run the latest wtware version.
2. Add to config file:
keyboard_log=on
3. Boot, connect to server.
4. Start logging with configurator as described here:
http://wtware.com/logs.html
5. Press key that did not work several times. Look into log, new line should appear every time you press the key.
6. Send us whole log to support@wtware.com and comment, which lines in log correspond to wrong keys.
Return to “Other”
Who is online
